Hi there, I use the Bold Gear with the included Power Supply but for any reason the system does not boot. I see the power LED get green then same seconds later yellow and back to green. No output on any HDMI connectors. The fan is not running and just moved a bit when the LED change to yellow. As memory I use 2 16GB modules from crucial (CT2K16G4SFD824A) which should be compatible as I saw in the forum. Any idea what the problem could be? Thanks
The solution was given by response to a ticket: The UEFI BIOS Default Restore switch was on position 1-2 which cause a reboot loop
