Braswell GPIO Number correction
Discussion in 'UDOO X86' started by Quack, Aug 2, 2020.
  1. Quack
    Quack UDOOer
    Jun 27, 2020
    15
    The pinout for the Braswell Gpio numbers in the documentation https://www.udoo.org/docs-x86II/ has 2 errors. It maps physical pin # 36 to GPIO 490 and pin # 37 to GPIO 492.
    The correct mapping is pin # 37 to GPIO 490 and pin # 36 to GPIO # 492.
    This is on X86II I haven't verified it on the X86.
  2. Quack
    Quack UDOOer
    Jun 27, 2020
    15
    Is there any body there!
  3. Quack
    Quack UDOOer
    Jun 27, 2020
    15
    Look it's easy to verify. Take a digital volt meter, attach it to ground and pin 36 . Then type:
    echo 492 | sudo tee /sys/class/gpio/export
    echo out | sudo tee /sys/class/gpio/direction
    Then toggle the output using:
    echo 0 sudo tee /sys/class/gpio/value
    echo 1 | sudo tee /sys/class/gpio/value
    Watch the volt meter.
    LDighera likes this.
  4. Quack
    Quack UDOOer
    Jun 27, 2020
    15
    Correction, the 5th line should read :
    echo 0 | sudo tee /sys/class/gpio/value
    In the spirit of updating the documentation, there are 2 places in the docs which report Braswell pinouts. Under the Hardware & Accessories/GPIO/Braswell it lists 2 options after kernel 4.15 and before 4.15. As noted above the post 4.15 are essentially accurate.
    If however you click on Hardware Reference/Pinout Braswell, it just lists the pre-4.15 kernel #s.
    BTW the sysfs method of access shown above has been depreciated in favor of the libgpiod library. https://git.kernel.org/pub/scm/libs/libgpiod/libgpiod.git/. Iwill be posting more on that later in another thread.
