Building Android 4.3 does not boot
Discussion in 'Android' started by badccode, Sep 9, 2014.
  1. badccode
    badccode New Member
    Sep 9, 2014
    I have a Udoo quad, and I can successfully download the Android image and boot it. I downloaded the Android code, and followed the instructions here:
    http://elinux.org/UDOO_compile_Android_4.2.2_from_sources#Boot_Android_from_SD to build the code.
    However, the result is a system that does not boot and produces no serial logs, so it seems as though it is not even entering uboot. I verified that the serial connection is valid with the downloaded image, and I could get the logs and enter the uboot shell. I am using the same microsd for both the downloaded image and the built image, so I am confident the sd card is good.
    When flashing the builds to the sd cards I even called sync after doing the make_sd.sh just to make sure the block caches were flushed to disk:
    $ sudo -E ./make_sd.sh /dev/sdc
    $ sudo sync
    At this point I would remove the sdcard, place into the UDOO and power the system on. At the first use of sync the system booted, so I though that was the issue, however when I tried to reproduce to make sure I could consistently build and flash, I ended up with a non-booting system again.
    I captured the build logs from the following actions:
    Android build:
    https://bitbucket.org/billcroberts/udoo/downloads/android.log
    Flashing with make_sd.sh:
    https://bitbucket.org/billcroberts/udoo/downloads/flash.log
    Uboot Build:
    https://bitbucket.org/billcroberts/udoo/downloads/uboot.log
    I also uploaded the binaries:
    boot.img:
    https://bitbucket.org/billcroberts/udoo/downloads/boot.img
    system.img:
    https://bitbucket.org/billcroberts/udoo/downloads/system.img
    recovery.img:
    https://bitbucket.org/billcroberts/udoo/downloads/recovery.img
    uboot.bin:
    https://bitbucket.org/billcroberts/udoo/downloads/u-boot.bin
    Host Details:
    $ uname -a
    Linux SRA2120 3.8.0-44-generic #66~precise1-Ubuntu SMP Tue Jul 15 04:01:04 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
  2. gionji
    gionji Member
    Jun 28, 2013
    38
    unfortunately make_sd.sh script on some machine configuration, sdcard, sdreader... can have a huge fail ratio.
    If you want to find at what stage does your distro fail (uboot, kernel, filesystem) youcan try each stage separately.
    first of all you can try to write again your uboot file. Opening your make_sd script you'll find something like this:
    sudo dd if=./bootable/bootloader/uboot-imx/u-boot.bin of=/dev/sdc bs=1K skip=1 seek=1 conv=fsync
    sudo dd if=/dev/zero of=/dev/sdc bs=512 seek=1536 count=16 conv=fsync
    sudo dd if=./out/target/product/udoo/boot.img of=/dev/sdc1 bs=4M conv=fsync
    sudo dd if=./out/target/product/udoo/recovery.img of=/dev/sdc2 bs=4M conv=fsync
    sudo dd if=./out/target/product/udoo/system.img of=/dev/sdc5 bs=4M conv=fsync
    Executing the first two command you'll write again the bootloader on sdcard.
    sudo sync
    If bootloader is compiled correcly and with the right configuration, at bootyou should see something in serial output.
    This is the first stage, trythis and let us know.
    Regards
  3. badccode
    badccode New Member
    Sep 9, 2014
    I was able to verify that if I just dd the built images, it all works. However, the issues seem to lie within the MBR.
    Comparing the sfdisk -l output between built and downloaded:
    Download (Boots):
    Disk /dev/sdc: 1005 cylinders, 245 heads, 62 sectors/track
    sfdisk: ERROR: sector 75950 does not have an msdos signature
    Units = cylinders of 7777280 bytes, blocks of 1024 bytes, counting from 0
       Device Boot Start     End   #cyls    #blocks   Id  System
    /dev/sdc1          1       2       2      15190   83  Linux
    /dev/sdc2          3       4       2      15190   83  Linux
    /dev/sdc3          5     150     146    1108870    5  Extended
    /dev/sdc4        151     912     762    5787390   83  Linux
    Built (No Boot):
    Disk /dev/sdc: 1021 cylinders, 241 heads, 62 sectors/track
    Units = cylinders of 7650304 bytes, blocks of 1024 bytes, counting from 0
    /dev/sdc1          1       2       2      14942   83  Linux
    /dev/sdc2          3       4       2      14942   83  Linux
    /dev/sdc3          5     153     149    1113179    5  Extended
    /dev/sdc4        154    1019     866    6469886   83  Linux
    /dev/sdc5          5+     75      71-    530440+  83  Linux
    /dev/sdc6         76+    146      71-    530440+  83  Linux
    /dev/sdc7        147+    148       2-     14941+  83  Linux
    /dev/sdc8        149+    150       2-     14941+  83  Linux
    My favorite part is that the downloaded MBR has x86 code in the MBR code section! See below for the details.
    My questions are:
    1. Is the MBR to blame here as suspected?
    2. What was the exact system and method used to generate the downloadable image?
    Downloaded (Boots):
    https://bitbucket.org/billcroberts/udoo/downloads/download.boot.img
    0000000: fab8 0010 8ed0 bc00 b0b8 0000 8ed8 8ec0  ................
    0000010: fbbe 007c bf00 06b9 0002 f3a4 ea21 0600  ...|.........!..
    0000020: 00be be07 3804 750b 83c6 1081 fefe 0775  ....8.u........u
    0000030: f3eb 16b4 02b0 01bb 007c b280 8a74 018b  .........|...t..
    0000040: 4c02 cd13 ea00 7c00 00eb fe00 0000 0000  L.....|.........
    0000050: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    0000060: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    0000070: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    0000080: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    0000090: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    00000a0: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    00000b0: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    00000c0: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    00000d0: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    00000e0: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    00000f0: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    0000100: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    0000110: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    0000120: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    0000130: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    0000140: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    0000150: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    0000160: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    0000170: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    0000180: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    0000190: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    00001a0: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    00001b0: 0000 0000 0000 0000 7368 0c00 0000 0000  ........sh......
    00001c0: 0101 83f4 3e02 563b 0000 ac76 0000 0000  ....>.V;...v....
    00001d0: 0103 83f4 3e04 02b2 0000 ac76 0000 0000  ....>......v....
    00001e0: 0105 05f4 3e96 ae28 0100 0cd7 2100 0000  ....>..(....!...
    00001f0: 0197 83f4 fe90 baff 2200 fc9d b000 55aa  ........".....U.
    Built (No Boot):
    https://bitbucket.org/billcroberts/udoo/downloads/built.boot.img
    0000000: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    0000010: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    0000020: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    0000030: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    0000040: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    00001b0: 0000 0000 0000 0000 0000 0000 0000 0000  ................
    00001c0: 0101 83f0 3e02 5e3a 0000 bc74 0000 0000  ....>.^:...t....
    00001d0: 0103 83f0 3e04 1aaf 0000 bc74 0000 0000  ....>......t....
    00001e0: 0105 05f0 3e99 d623 0100 b6f8 2100 0000  ....>..#....!...
    00001f0: 019a 83f0 be2e 8c1c 2300 b656 5c00 55aa  ........#..V\.U.
  4. badccode
    badccode New Member
    Sep 9, 2014
    I had to delete the udoo repository from Bitbucket due to some technical issues, so the links above are no longer active.
  5. gionji
    gionji Member
    Jun 28, 2013
    38
    What is your host configuration? (Os, Virtual Machine, 32 or 64 bits... etc)
  6. badccode
    badccode New Member
    Sep 9, 2014
    Ubuntu 12.04 No Virtual Machine.
    sfdisk version:
    sfdisk from util-linux 2.20.1
    uname -a:
    3.5.0-47-generic #71~precise1-Ubuntu SMP Wed Feb 19 22:02:52 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
    I even tried taking on older version of sfdisk from ubuntu 10.04 but got similar results.
  7. gionji
    gionji Member
    Jun 28, 2013
    38
    When you launch the compilation did you find this parameters?
    udoo@ubuntu:~/android-dev/UDOO.Android$ make -j 5
    PLATFORM_VERSION_CODENAME=REL
    PLATFORM_VERSION=4.2.2
    TARGET_PRODUCT=full
    TARGET_BUILD_VARIANT=eng
    TARGET_BUILD_TYPE=release
    TARGET_BUILD_APPS=
    TARGET_ARCH=arm
    TARGET_ARCH_VARIANT=armv7-a
    HOST_ARCH=x86
    HOST_OS=linux
    HOST_OS_EXTRA=Linux-2.6.32-38-generic-x86_64-with-Ubuntu-10.04-lucid
    HOST_BUILD_TYPE=release
    BUILD_ID=JDQ39
    OUT_DIR=out
  8. badccode
    badccode New Member
    Sep 9, 2014
    Pretty much. Its building with neon since its a Cortext A9
    TARGET_ARCH=arm
    TARGET_ARCH_VARIANT=armv7-a-neon
    TARGET_CPU_VARIANT=cortex-a9
    Does it strike anyone as odd that the downloaded image from Udoo's website has x86 code in the MBR code section?
  9. gionji
    gionji Member
    Jun 28, 2013
    38
    I can suppose that image was created by a non-brand new SD. The main problem is that you didn't have the same compilation configuration on your host machine. We spent few days looking for a correct system configuration to meke it work.
    We tested different host OS version and distros, 32 or 64 bits...
    We are checking immeditely for MBR issue.
    For the moment thank you for your help, people like you are he very helpful for us!
    I suggest you to try the VM way to complile the android distro, it also help us to verify the procedure correctness.
    Thank you again :)
  10. badccode
    badccode New Member
    Sep 9, 2014
    Sorry for the delay, do you have a VM image for me to test with?
    I am having someone else verify the system following my instructions and they are having the same issues on their end.
  11. badccode
    badccode New Member
    Sep 9, 2014
    All the images boot /run if I don't re-format the block device. It seems to me that the issue is generating a correct MBR that the ROM code can read and jump to. Is the ROM not able to correctly read Extended Partition tables?
