Building Android Sources
Discussion in 'Android' started by stefanpini, Sep 8, 2015.
  1. stefanpini
    stefanpini New Member
    Feb 16, 2015
    14
    Hi, I'm trying to compile the source code of Android KitKat 4.4.2.
    I'm using Ubuntu 10.04 and I'm following the guide provided from this docs:
    http://www.udoo.org/docs/Advanced_Setup/Compile_Android_From_Sources
    I can't execute the command "croot" as said in the section "Use the new Android system images".
    Do you have any suggestion?
  2. iddqd
    iddqd Member
    Mar 24, 2014
    56
    11
    [del]chroot[/del]
    I am wrong, sorry
  3. Andrea Rovai
    Hi there stefanpini,
    you should recompile the driver. Here it is a guide. It's a bit outdated honestly, I don't know if everything works.
    EDIT: this is more updated.
