Camera's SurfaceView can't use
Discussion in 'Android' started by FJUUDOO, Apr 7, 2014.
  1. FJUUDOO
    FJUUDOO New Member
    Feb 17, 2014
    We write an app to use camera's SurfaceView .
    We can use it on our phone .
    When we use it on UDOO dual , it always break .
    And it shows "program no response".
    We guess the problem is that we have no permission to use camera.
    When we use the SurfaceView , the program run to "Start.View()" . It beaks .
    Is there have other way to deal this solution ?
  2. udoid
    udoid New Member
    Mar 2, 2014
    12
    Have you tried running the debugger on it whilst running your app. on the Udoo? What is the output of logcat?
  3. delba
    1,064
  4. FJUUDOO
    FJUUDOO New Member
    Feb 17, 2014
    05-30 14:47:09.844: D/CameraCaptureActivity(797): getCameraInstance()Camera:: null
    05-30 14:47:09.855: D/CameraCaptureActivity(797): getCameraInstance()open:: null
    05-30 14:47:09.855: D/CameraCaptureActivity(797): mCamera:: null
    05-30 14:47:09.895: D/CameraCaptureActivity(797): mCamera :: null
    05-30 14:47:09.895: D/CameraCaptureActivity(797): mSurfaceHolder :: android.view.SurfaceView$4@40d06ef8
    05-30 14:47:09.924: D/CameraCaptureActivity(797): mCameraPreview :: com.example.demo.CameraPreview{40d06860 V.E..... ......I. 0,0-0,0}
    05-30 14:47:09.924: D/CameraCaptureActivity(797): FrameLayout :: android.widget.FrameLayout{40cfa7d8 V.E..... ......I. 0,0-0,0 #7f080000 app:id/camera_preview}
    05-30 14:47:09.954: D/CameraCaptureActivity(797): captureButton :: android.widget.Button{40cfad50 VFED..C. ......I. 0,0-0,0 #7f080001 app:id/button_capture}
    05-30 14:47:04.327: D/AndroidRuntime(797): Shutting down VM
    05-30 14:47:04.327: W/dalvikvm(797): threadid=1: thread exiting with uncaught exception (group=0x40a71930)
    05-30 14:47:04.458: E/AndroidRuntime(797): FATAL EXCEPTION: main
    05-30 14:47:04.458: E/AndroidRuntime(797): java.lang.NullPointerException
    05-30 14:47:04.458: E/AndroidRuntime(797):  at com.example.demo.CameraPreview.surfaceCreated(CameraPreview.java:33)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at android.view.SurfaceView.updateWindow(SurfaceView.java:569)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at android.view.SurfaceView.access$000(SurfaceView.java:86)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at android.view.SurfaceView$3.onPreDraw(SurfaceView.java:174)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at android.view.ViewTreeObserver.dispatchOnPreDraw(ViewTreeObserver.java:680)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:1842)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:989)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:4351)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at android.view.Choreographer$CallbackRecord.run(Choreographer.java:749)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at android.view.Choreographer.doCallbacks(Choreographer.java:562)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at android.view.Choreographer.doFrame(Choreographer.java:532)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:735)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at android.os.Handler.handleCallback(Handler.java:725)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at android.os.Handler.dispatchMessage(Handler.java:92)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at android.os.Looper.loop(Looper.java:137)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at android.app.ActivityThread.main(ActivityThread.java:5041)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at java.lang.reflect.Method.invokeNative(Native Method)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at java.lang.reflect.Method.invoke(Method.java:511)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:793)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:560)
    05-30 14:47:04.458: E/AndroidRuntime(797):  at dalvik.system.NativeStart.main(Native Method)
    we find the problem is Camera can't catch
  5. Suppaman
    Suppaman New Member
    Oct 29, 2013
    25
    Is just an hypothesis but remember UDOO have only one camera not two as standard smartphones. These cameras are classified as front-camera and back-camera. It will be possible SurfaceView need to use, for example, front-camera and android UDOO have back-camera only or something similar? The "official" android app detect and show the camera correctly this mean the device is working...
  6. FJUUDOO
    FJUUDOO New Member
    Feb 17, 2014
    Do you know any example , or any information about it?
    Thanks for your help.
  7. Suppaman
    Suppaman New Member
    Oct 29, 2013
    25
    Sorry, no example, I just tried to hypotize. In your case the official android camera app is workign as expected?
  8. FJUUDOO
    FJUUDOO New Member
    Feb 17, 2014
    offcial Android camera app is working as expected.
  9. FJUUDOO
    FJUUDOO New Member
    Feb 17, 2014
  10. misterdj
    misterdj New Member
    Oct 9, 2014
    mismo problema no se hable la camara de la udoo con el surface alguna solucion gracias
  11. delba
    1,064
    misterdj please answer in english so the other users can understand you! Cheers
