Can I use the wifi/bluetooth and dual ethernet M2 boards at the same time?
Discussion in 'UDOO X86' started by jimmayhugh, Aug 27, 2017.
  1. jimmayhugh
    jimmayhugh New Member
    Nov 23, 2013
    I want to use both, is it possible?? Thought I'd check before buying.
  2. x1800MODMY360x
    x1800MODMY360x Member
    Mar 29, 2017
    55
    I believe the Ethernet adapter uses the ssd slot. So you can use the WiFi and Ethernet adapter at the same time.
  3. ccs_hello
    466
    170
    They should work independently without interfering with each other.
    WiFi+BT M.2 card is a "key A+E" card which sits on the lower slot, while
    dual Fast-E M.2 card is a "key B" card, which sits on the higher slot.
    ccs_hello
    jimmayhugh likes this.
  4. jimmayhugh
    Nov 23, 2013
    Thanks for the info.
