Can i use this sata cable?
Discussion in 'General Discussion' started by fatpixellin, Dec 20, 2013.
  1. fatpixellin
    fatpixellin New Member
    Dec 5, 2013
    Hi, i'm new to udoo, and i'm searching the right sata cable.
    Can i use this one?
    [​IMG]
    in the Udoo Quad there is a DC-IN connector or not?
    Thanks everybody.
  2. EBrown
    EBrown New Member
    Dec 9, 2013
    48
    There is. It's just behind the Gigabit Ethernet port.
    Thanks,
    EBrown
  3. fatpixellin
    Dec 5, 2013
    Ok, thank you.
  4. Lifeboat_Jim
    Lifeboat_Jim New Member
    Sep 16, 2013
    399
    Yep, that cable looks fine (as much as you can tell from a photo).
  5. pko
    pko New Member
    Sep 13, 2013
    19
    If the cable is for the Cubieboard, then it cannot be used as is. The cable in the photo has the data connector and the power connector for 5V DC only. The power connector of that cable is a JST -HX type which is the type used for J25 (DC-in 12V) on the Udoo but the SATA power connector (5V only) on the Udoo is J12 which is a JST-PH connector. The two types of JST connectors are very similar but just different enough to be not interchangeable. To use the cable you will have to replace the power connector with the right one - see the discussion in this post for details viewtopic.php?f=22&t=123.
    Note: the cable in the photo does not have the 12V connector and can only power SATA disk that required only 5V supply.
  6. fatpixellin
    Dec 5, 2013
    It's possible to buy directly from SECO only the sata cable or i have to buy the entire starter kit? (i need only the sata cable)
  7. delba
    1,064
    You have to buy the entire kit, sorry about that.
  8. malaga
    malaga UDOOer
    Jun 19, 2018
    20
    hello dear Folks
    can any body send me a link where i can obtain the cable?
    Love to hear from you
  9. Laura
    Laura UDOOer
    Apr 22, 2016
    374
    155
  10. malaga
    malaga UDOOer
    Jun 19, 2018
    20
    hello dear Laura, many thanks for the reply
    i definitley am willing to buy / create me such a cable -
    many thanks for all your help here.
    greetings
