CanOpen communication with Qt on udoo Neo
Discussion in 'UDOO NEO' started by Sassus-Bourda, Mar 17, 2016.
  1. graugans
    Sep 17, 2015
    328
    141
    You have a recommendation for a 3.3V Type. I found one from TI and another one from Maxim
  2. jas-mx
    jas-mx Active Member
    Dec 31, 2013
    407
    118
    Tested the SN65HVD230 , see the other thread to save repeating myself.
    graugans likes this.
  3. Sassus-Bourda
    Sassus-Bourda Member
    Dec 21, 2015
    42
    Hello guys,
    I'm stuck with the example of the qtserialbus example. When i try to compile the program directcly on my udoo quad board but the console display : Unknown module in QT:serialbus..
    Any advices?
  4. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Probably you don't have the qtserialbus build, what distro you use ?
  5. Sassus-Bourda
    Dec 21, 2015
    42
    Problem solved i didn't used the good Qt version.
    Now I have my can example working! Next step is to set up the can pinout with the device tree editor but i don't understand how I neded to plug the gnd..
    Another things you use a can tranceiver it's an obligation to test? because I just have an usb "bridge" for can.
    Thanks for your follow up
  6. graugans
    Sep 17, 2015
    328
    141
    You probably have a peak or ixxat USB bridge they have CAN high/low signals so you'll need the transceiver but take a 3.3v type!!!
    When connecting two can TTL boards there is an application note from Siemens how to do this.
    You'll need to connect GND of both ends because CAN high/low is based on GND
  7. Sassus-Bourda
    Dec 21, 2015
    42
    How can I add a can bakend in the Qt serial bus example?
    I use an usb bridge with the FTDI drivers so the library install is not detect by the program.
    Thanks in advance
  8. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Hi, qtserialbus support only 3 backend for the moment. I don't know what CAN adaptator you use but check my previous link. In my case, i use peak can on Windows OS and socketCan on Neo. You can find more information in Qt doc ...
  9. Sassus-Bourda
    Dec 21, 2015
    42
    Hi, thanks for your answer.
    Yes I see in Qt doc that only 3 backends are supported but I thought that with the fonction plugins() in QCanBus class I was able to add a new backend...
  10. Sassus-Bourda
    Dec 21, 2015
    42
    How can I install the 5.6 version of Qt in the udubuntu OS?
    Thanks
  11. jas-mx
    Dec 31, 2013
    407
    118
    If you asking for the NEO then you need to build (cross compile) it yourself. I don't think there are instructions specifically for the Neo, the nearest is the for the Quad/Dual.
  12. graugans
    Sep 17, 2015
    328
    141
    What are you planning to do? I can provide a qt5 Yocto image + toolchain for cross devel
  13. Sassus-Bourda
    Dec 21, 2015
    42
    It could be awesome !
    I plan to test the can bus example provide by Qt v5.6 on my udoo board to communicate with my pc.
  14. Sassus-Bourda
    Dec 21, 2015
    42
    So can you provide me what you says please Graugans it could be very useful for me.
    Thanks in advance
  15. graugans
    Sep 17, 2015
    328
    141
  16. Sassus-Bourda
    Dec 21, 2015
    42
    Thanks a lot !
    A question about the image on window how can I put the image on an SD Card? Usualy I used the program win32DiskManager but it with .img files.
    Thanks in advance
  17. graugans
    Sep 17, 2015
    328
    141
    You can use it anyway
  18. Sassus-Bourda
    Dec 21, 2015
    42
    I have those errors when I try to build my program :
    General message :
    Cannot read /opt/poky/2.1/sysroots/cortexa9hf-neon-poky-linux-gnueabi/usr/lib/qt5/mkspecs/oe-device-extra.pri: No such file or directory
    Compiler output :
    erreur : [.obj/MyClassName.o] Error 127
    Can you help me please?
    Pierre
  19. graugans
    Sep 17, 2015
    328
    141
    I had a flu the last few days I try to check. The oe-device-extra.pri shouldn't be needed
  20. Sassus-Bourda
    Dec 21, 2015
    42
    OK I hope you good now !
    Let me know if you resolve this error I can't find anything yet to resolve it by myself.
    Thanks in advance,
    Pierre
