CanOpen communication with Qt on udoo Neo
Discussion in 'UDOO NEO' started by Sassus-Bourda, Mar 17, 2016.
  1. Sassus-Bourda
    Sassus-Bourda Member
    Dec 21, 2015
    42
    I have an issue with compilation that I don't understand :
    Failed to upload file "/home/pierre/build-CAN_test-UDOO-Debug/CAN_test": Could not open for reading.
    Any ideas ?
  2. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    It 's an issue with upload, perhap's you already have an app already running with qtcreator on neo ...
  3. Sassus-Bourda
    Dec 21, 2015
    42
    OK si I succeed to run your class !
    But I just have a blank window of course !
    To test it I have to call the functions with button for example is that right ?
    modjo likes this.
  4. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Yes you can use button to create connections (signal and slot) with the methods. In the debug you will see some messages.
  5. Sassus-Bourda
    Dec 21, 2015
    42
    OK thanks I let you know !
  6. Sassus-Bourda
    Dec 21, 2015
    42
    Somebody know how to solve the problem of this errors :
    Still a mystery for me
  7. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Can you deploy the app on the card ? did you test the com with Qt creator like that :
  8. Sassus-Bourda
    Dec 21, 2015
    42
    So I finally move forward my compilation issue.
    So with your class I connect the signal data to the slot checkMessage bu when I do a cansend I already enter in the condition frame.payload().isEmpty() of checkmessage method..
    Does I'm right with this process ?
  9. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    No, you can't do this ! this signal is emit in this slot (checkMessages) --> you create an infinite loop ! The signal is emited automatically when a Can frame are received ! This signal is use full to connect the QCan class to another, for exemple a class that send data over ethernet ...
    QObject::connect(m_canDevice1,SIGNAL(data(structCan)),m_eth,SLOT(sendData(structCAn)));
    m_canDevice is a QCan device pointer
    m_eth is a ethernetClass device pointer for exemple ...
  10. Sassus-Bourda
    Dec 21, 2015
    42
    OK i'm stupid !! So it's ok now I receive the view with the frame send in loopback via cansend but that's all I can't send to my pc with udoo and vice versa
    modjo likes this.
  11. Sassus-Bourda
    Dec 21, 2015
    42
    Any advice on how send/receive frame on board connected to PC ? I'm run out of test
  12. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Perhaps you can already control with an oscilloscope what you have all the signals. I think you have a problem with your hardware ...
  13. Sassus-Bourda
    Dec 21, 2015
    42
    Yes I will check that!
    But I test with a new card and it's the same story..
  14. Sassus-Bourda
    Dec 21, 2015
    42
    Here my bench test ! What is your opinion on it ?
  15. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    It's difficult to have an opinion about your config with just a photo ... It's like i send you a photo of my motor car and now you will find the problem !
    Control your signal with an oscilloscope before you enter in the card (after your pc adapter) and on the tx and rx pin on neo.
    Sassus-Bourda likes this.
  16. Sassus-Bourda
    Dec 21, 2015
    42
    Yes you right sorry !
    Ok I try with an oscilloscope I let you know !
  17. Sassus-Bourda
    Dec 21, 2015
    42
    So I check with a volmeter, my oscilloscop is just too old !
    And surprise nothing go out from the board.. And it's a new one
  18. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    You cannot check with a voltmeter, the signal is too fast for it ! Use an oscillo
  19. Sassus-Bourda
    Dec 21, 2015
    42
    Ok I will do it as soon as possible !
  20. fred33
    fred33 New Member
    May 30, 2017
    Hi Graugans,
    I'm Pierre colleague.
    We were using the Image you sent him some months ago as everything is working fine.
    Now we would like to activate the touch screen from our UDOO Neo board (LVDS7 screen)
    From what I know, it seems some parameter has to be added to your image.
    Can you tell me which one? and do you think we can do it by ourself ?
    Thank you
    Fred
