Cant comm with Arduino through Linux after uploading sketch
Discussion in 'Arduino IDE' started by jaykudo, Mar 11, 2014.
  1. jaykudo
    jaykudo New Member
    Jan 12, 2014
    17
    Hi everyone,
    Bit of an obscure issue, but very easily replicated.
    I am running Linaro Ubuntu 12.04 on the UDOO. When attempting to communicate through Linux to the Arduino (using /dev/ttymxc3 serial interface) after a fresh Linux boot, everything works fine.
    root@udoo:~# stty -F /dev/ttymxc3
    speed 9600 baud; line = 0;
    -brkint -imaxbel
    root@udoo:~# stty -F /dev/ttymxc3 115200
    root@udoo:~# cat /dev/ttymxc3
    [TEMP] - Temperature is 43.41 C
    [SERIAL] - Input char
    [FAN] - Timer started. Fan will run for 320 seconds, unless temp drops below 30C first
    [TEMP] - Temperature is 43.18 C
    ^C
    root@udoo:~#
    (the serial output from the Arduino is seen after the 'cat' command. Everything is working fine here)
    [​IMG]
    I can reset the Arduino (by way of using the RESET pin and some code (as seen in STEP 1, here: http://www.instructables.com/id/two-way ... -software/) and all is still working fine.
    But then, when I upload the sketch to the Arduino (using USB cable to my PC and J18 disconnected) 'cat' no longer shows any output. It remains this way until I reboot Linux. Then it works again until I upload a sketch to Arduino again.
    Has anyone else had this same issue? Any way to fix this?
    Thanks.
  2. jaykudo
    jaykudo New Member
    Jan 12, 2014
    17
    Re: Cant comm with Arduino through Linux after uploading ske
    Anyone able to help me out here? I have a suspicion that I may have posted this in the wrong sub-forum. If so, can someone please point me on the right direction. Thanks!
