Can't upload sketches the UDOO X86 Curie
Discussion in 'UDOO X86' started by Trinova, Oct 19, 2017.
  1. Trinova
    Trinova New Member
    Oct 19, 2017
    I can't upload sketches from the Arduino IDE (1.8.4, Windows 10 x64) to the UDOO X86 Curie.
    I have installed the BIOS version 1.03 on the UDOO X86 Advanced Plus.
    In the UEFI BIOS setup, the parameter "Curie Reset on PowerON <Enabled>" is set.
    During the Arduino IDE upload, the Windows Device manager shows that the COM3 port is temporairly disabled.
    the Arduino IDE logging shows the following:
    Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino 101"
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\michi\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\michi\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\michi\Documents\Arduino\libraries -fqbn=Intel:arc32:arduino_101 -vid-pid=0X8087_0X0AB6 -ide-version=10805 -build-path C:\Users\michi\AppData\Local\Temp\arduino_build_765042 -warnings=none
    arduino101load 2.0.1 - compiled with go1.7.5
    Starting download script...
    Serial Port: COM3
    BIN FILE C:\Users\michi\AppData\Local\Temp\arduino_build_765042/Blink.ino.bin
    Waiting for device...
    Flashing is taking longer than expected
    Try pressing MASTER_RESET button
    ERROR: Timed out waiting for Arduino 101 on COM3
    Note: See attached file for full logging.
    Is there anyone out there who could help me on how to upload sketches the UDOO X86 Curie?
    Many thanks in advance!!
    Arduino Curie wants to update the Bluetooth module on the Curie first which fails for some reason.
    I got it running by:
    1. Reboot Udoo X86
    2. Start Arduino IDE on Udoo X86
    3. Press Curie MASTER_RESET Button
    4. Compile and upload blink example. A notification of BLE firmware update should be shown and it continues uploading the sketch.
    Now I could keep on uploading sketches if required, no more hickups
    If that fails: Completely remove Arduino IDE including the Curie files in your user profile (C:\Users\michi\AppData\Local\Arduino15) and reinstall Arduino including Curie board manager.
    Edit: extended the procedure for future reference
  3. Trinova
    Trinova New Member
    Oct 19, 2017
    @waltervl
    I followed the procedure you described "Completely remove Arduino IDE including the Curie files in your user profile (C:\Users\michi\AppData\Local\Arduino15) and reinstall Arduino including Curie board manager."
    After reinstalling the Arduino IDE and Curie board manager, I was able to upload a sketch!!
    The logging showed the following:
    Sketch uses 48712 bytes (31%) of program storage space. Maximum is 155648 bytes.
    ATTENTION: BLE firmware is being flashed
    DO NOT DISCONNECT THE BOARD
    SUCCESS: Sketch will execute in about 5 seconds.
    The main difference with the first tests is the message: "ATTENTION: BLE firmware is being flashed"
    Although I don't understand why this software re-installation did make the difference, I can progress now.
    Many thanks!
  4. waltervl
    Good to know it works.
    BLE = Bluetooth Low Energy
    For some (also for me unknown) reason this BLE firmware update fails. With me the first procedure was good enough. And sometimes the second procedure is need :)
