Community Yocto krogoth builds
Discussion in 'Yocto' started by graugans, Nov 7, 2016.
  1. graugans
    Sep 17, 2015
    328
    141
    !!!! BIG FAT WARNING !!!!
    Please note, this is a bleeding-edge community OS for UDOO Boards. It comes without any kind of warranty, so it is recommended only to experienced users. Use it at your own risk!
    After a big rework of the meta-udoo layer I do provide updated QT5 (5.6.2) test images
    UDOO Quad /Dual
    UDOO Neo
    QT5 Toolchain
    Installation:
    umount /dev/sd<disk>?; bzcat /tmp/udoo-image-qt5-udooqdl.wic.bz2 | sudo dd of=/dev/<disk> bs=32M
    danielye, cyrilf and modjo like this.
  2. cyrilf
    cyrilf Active Member
    Feb 19, 2015
    167
    47
    This issue can be solved by updating the defconfig file in the kernel recipe.
    modjo and graugans like this.
  3. graugans
    Sep 17, 2015
    328
    141
    Yes, I know. But frankly I forgot the patch :)
  4. graugans
    Sep 17, 2015
    328
    141
    In the latest version /dev/ttyMCC is available again
  5. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    @graugans , could you just precise the version of Qt you deliver here (i suppose is Qt5.6 --> krogoth branch) and the modules integrate for new users please ? Another point, i think it will be great to "sticky" this post and update it (images) when a new version is available. I think tomorrow i will build an image with your lasted commits but for secoA62 and Qt5.7. If you would we can add this image here (if all work fine ...) ?
    graugans likes this.
  6. graugans
    Sep 17, 2015
    328
    141
    Contribution is always welcome. I just updated the information above. Yes it is the version 5.6.2. You'll have to remove the qtserial_git.bb file when building for Qt 5.7 meta-qt5. In the next days I'll try to start a port for morty Yocto 2.2
    modjo likes this.
  7. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    @graugans , i'm trying to build an image for secoA62 with your news update but i have this error when trying to fetch freescale firmware :
    WARNING: firmware-imx-1_5.4-r0 do_fetch: Failed to fetch URL git://git.freescale.com/imx/imx-firmware.git;branch=master;destsuffix=/home/mls/yocto-modjo/A62Build/tmp/work/cortexa9hf-neon-mx6qdl-poky-linux-gnueabi/firmware-imx/1_5.4-r0/firmware-imx-5.4/git, attempting MIRRORS if available
    ERROR: firmware-imx-1_5.4-r0 do_fetch: Fetcher failure: Fetch command failed with exit code 128, output:
    Cloning into bare repository '/home/mls/yocto-modjo/downloads//git2/git.freescale.com.imx.imx-firmware.git'...
    fatal: read error: Connection reset by peer
    ERROR: firmware-imx-1_5.4-r0 do_fetch: Function failed: Fetcher failure for URL: 'git://git.freescale.com/imx/imx-firmware.git;branch=master;destsuffix=/home/mls/yocto-modjo/A62Build/tmp/work/cortexa9hf-neon-mx6qdl-poky-linux-gnueabi/firmware-imx/1_5.4-r0/firmware-imx-5.4/git'. Unable to fetch URL from any source.
    ERROR: Logfile of failure stored in: /home/mls/yocto-modjo/A62Build/tmp/work/cortexa9hf-neon-mx6qdl-poky-linux-gnueabi/firmware-imx/1_5.4-r0/temp/log.do_fetch.30130
    ERROR: Task 3126 (/home/mls/yocto-modjo/sources/meta-fsl-arm/recipes-bsp/firmware-imx/firmware-imx_5.4.bb, do_fetch) failed with exit code '1'
    Did you meet the same error ?
  8. graugans
    Sep 17, 2015
    328
    141
    Looks like they took down their git server. Hopefully it will be put back online soon. I send a mail to the meta-freescale Mailinglist
    modjo likes this.
  9. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    it seems to be ok now, build running ...
  10. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    @graugans, the build work fine but the last operation with wic fails, this is the log :
    ERROR: udoo-image-qt5-1.0-r0 do_image_wic: Function failed: do_image_wic (log file is located at /home/mls/yocto-modjo/A62Build/tmp/work/secosbca62-poky-linux-gnueabi/udoo-image-qt5/1.0-r0/temp/log.do_image_wic.16913)
    ERROR: Logfile of failure stored in: /home/mls/yocto-modjo/A62Build/tmp/work/secosbca62-poky-linux-gnueabi/udoo-image-qt5/1.0-r0/temp/log.do_image_wic.16913
    Log data follows:
    | DEBUG: Executing python function set_image_size
    | DEBUG: Python function set_image_size finished
    | DEBUG: Executing shell function do_image_wic
    | Error: exec_cmd: cp /home/mls/yocto-modjo/A62Build/tmp/deploy/images/secosbca62/SPL /home/mls/yocto-modjo/A62Build/tmp/deploy/images/secosbca62/udoo-image-qt5-secosbca62-20161110120528/build/SPL.1 returned '1' instead of 0
    | Checking basic build environment...
    | Done.
    | Creating image(s)...
    | WARNING: exit code 1 from a shell command.
    | ERROR: Function failed: do_image_wic (log file is located at /home/mls/yocto-modjo/A62Build/tmp/work/secosbca62-poky-linux-gnueabi/udoo-image-qt5/1.0-r0/temp/log.do_image_wic.16913)
    ERROR: Task 16 (/home/mls/yocto-modjo/sources/meta-udoo-modjo/qt5-layer/recipes-qt/images/udoo-image-qt5.bb, do_image_wic) failed with exit code '1'
    NOTE: Tasks Summary: Attempted 5051 tasks of which 2661 didn't need to be rerun and 1 failed.
    No currently running tasks (5051 of 5053)
    Summary: 1 task failed:
    Do you have an idea what's the issue ?
  11. graugans
    Sep 17, 2015
    328
    141
    Are you using an up to date git?
  12. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    yes i update my git from yours yesterday.
  13. graugans
    Sep 17, 2015
    328
    141
    Your image needs to be dependant on virtual/bootloader
  14. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    yes, this is that i have on udoo-image-qt5.bb :
    # This requires the meta-qt5 layer in your bblayers.conf !!!!
    # source: http://wiki.wandboard.org/index.php/Building_Qt5_using_yocto_on_Wandboard
    # If you plan to use Qt5 eglfs plugin for accelerated graphics using the framebuffer,
    # you need to discard X11 and wayland so the proper graphics drivers get included.
    # To achieve this add the following to your conf/local.conf :
    # DISTRO_FEATURES_remove = "x11 wayland"
    DESCRIPTION = "A Qt 5.7.0+ image. Tailored for the UDOO boards"
    DEPENDS += "virtual/bootloader"
    IMAGE_FEATURES += "splash ssh-server-openssh package-management debug-tweaks dev-pkgs
    If i try to use wic manually, i have this error :
    mls@KDE-Z400:~/yocto-modjo/A62Build$ wic create udoo-sdcard -e udoo-image-qt5 -o /home/mls/yocto-modjo/A62Build/image/secoA62q
    Done.
    Error: exec_cmd: cp /home/mls/yocto-modjo/A62Build/tmp/deploy/images/secosbca62/SPL /home/mls/yocto-modjo/A62Build/image/secoA62q/build/SPL.1 returned '1' instead of 0
  15. graugans
    Sep 17, 2015
    328
    141
    looks like u-boot is not build. Can you please build it by hand and try again?
  16. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    yes it seems u-boot is missing ! I bitbake u-boot (works fine) and relaunch udoo-image-qt5. The build is complete now.
    In the folder where is the image i have this :
    what file do i need to burn on sd ? (dd if = udoo-sdcard-201611101724-mmcblk.direct ...)
  17. graugans
    Sep 17, 2015
    328
    141
    $ MACHINE=secosbca62 bitbake udoo-image-qt5
    $ tree tmp/deploy/images/secosbca62/
    ├── modules--3.14.56-r0-secosbca62-20161109202051.tgz
    ├── modules-secosbca62.tgz -> modules--3.14.56-r0-secosbca62-20161109202051.tgz
    ├── README_-_DO_NOT_DELETE_FILES_IN_THIS_DIRECTORY.txt
    ├── SPL -> SPL-secosbca62-v2016.07+gitAUTOINC+e6b42411ab-r0-sd-v2016.07+gitAUTOINC+e6b42411ab-r0
    ├── SPL-sd -> SPL-secosbca62-v2016.07+gitAUTOINC+e6b42411ab-r0-sd-v2016.07+gitAUTOINC+e6b42411ab-r0
    ├── SPL-secosbca62 -> SPL-secosbca62-v2016.07+gitAUTOINC+e6b42411ab-r0-sd-v2016.07+gitAUTOINC+e6b42411ab-r0
    ├── SPL-secosbca62-sd -> SPL-secosbca62-v2016.07+gitAUTOINC+e6b42411ab-r0-sd-v2016.07+gitAUTOINC+e6b42411ab-r0
    ├── SPL-secosbca62-v2016.07+gitAUTOINC+e6b42411ab-r0-sd-v2016.07+gitAUTOINC+e6b42411ab-r0
    ├── u-boot.img -> u-boot-sd-v2016.07+gitAUTOINC+e6b42411ab-r0.img
    ├── u-boot.img-sd -> u-boot-sd-v2016.07+gitAUTOINC+e6b42411ab-r0.img
    ├── u-boot-sd-v2016.07+gitAUTOINC+e6b42411ab-r0.img
    ├── u-boot-secosbca62.img -> u-boot-sd-v2016.07+gitAUTOINC+e6b42411ab-r0.img
    ├── u-boot-secosbca62.img-sd -> u-boot-sd-v2016.07+gitAUTOINC+e6b42411ab-r0.img
    ├── udoo-image-full-cmdline-secosbca62-20161106191851.rootfs.manifest
    ├── udoo-image-full-cmdline-secosbca62-20161106191851.rootfs.wic.bz2
    ├── udoo-image-full-cmdline-secosbca62.manifest -> udoo-image-full-cmdline-secosbca62-20161106191851.rootfs.manifest
    ├── udoo-image-full-cmdline-secosbca62.wic.bz2 -> udoo-image-full-cmdline-secosbca62-20161106191851.rootfs.wic.bz2
    ├── udoo-image-qt5-secosbca62-20161109150059.rootfs.manifest
    ├── udoo-image-qt5-secosbca62-20161109150059.rootfs.wic.bz2
    ├── udoo-image-qt5-secosbca62-20161109193035.rootfs.manifest
    ├── udoo-image-qt5-secosbca62-20161109193035.rootfs.wic.bz2
    ├── udoo-image-qt5-secosbca62-20161109200414.rootfs.manifest
    ├── udoo-image-qt5-secosbca62-20161109200414.rootfs.wic.bz2
    ├── udoo-image-qt5-secosbca62-20161109202051.rootfs.manifest
    ├── udoo-image-qt5-secosbca62-20161109202051.rootfs.wic.bz2
    ├── udoo-image-qt5-secosbca62-20161109203103.rootfs.manifest
    ├── udoo-image-qt5-secosbca62-20161109203103.rootfs.wic.bz2
    ├── udoo-image-qt5-secosbca62.manifest -> udoo-image-qt5-secosbca62-20161109203103.rootfs.manifest
    ├── udoo-image-qt5-secosbca62.wic.bz2 -> udoo-image-qt5-secosbca62-20161109203103.rootfs.wic.bz2
    ├── zImage -> zImage--3.14.56-r0-secosbca62-20161109202051.bin
    ├── zImage--3.14.56-r0-imx6dl-seco_A62-20161109202051.dtb
    ├── zImage--3.14.56-r0-imx6dl-seco_A62-hdmi-20161109202051.dtb
    ├── zImage--3.14.56-r0-imx6dl-seco_A62-lvds15-20161109202051.dtb
    ├── zImage--3.14.56-r0-imx6dl-seco_A62-lvds7-20161109202051.dtb
    ├── zImage--3.14.56-r0-imx6dl-seco_A62-lvds7hdmi-20161109202051.dtb
    ├── zImage--3.14.56-r0-imx6q-seco_A62-20161109202051.dtb
    ├── zImage--3.14.56-r0-imx6q-seco_A62-hdmi-20161109202051.dtb
    ├── zImage--3.14.56-r0-imx6q-seco_A62-lvds15-20161109202051.dtb
    ├── zImage--3.14.56-r0-imx6q-seco_A62-lvds7-20161109202051.dtb
    ├── zImage--3.14.56-r0-imx6q-seco_A62-lvds7hdmi-20161109202051.dtb
    ├── zImage--3.14.56-r0-secosbca62-20161109202051.bin
    ├── zImage-imx6dl-seco_A62.dtb -> zImage--3.14.56-r0-imx6dl-seco_A62-20161109202051.dtb
    ├── zImage-imx6dl-seco_A62-hdmi.dtb -> zImage--3.14.56-r0-imx6dl-seco_A62-hdmi-20161109202051.dtb
    ├── zImage-imx6dl-seco_A62-lvds15.dtb -> zImage--3.14.56-r0-imx6dl-seco_A62-lvds15-20161109202051.dtb
    ├── zImage-imx6dl-seco_A62-lvds7.dtb -> zImage--3.14.56-r0-imx6dl-seco_A62-lvds7-20161109202051.dtb
    ├── zImage-imx6dl-seco_A62-lvds7hdmi.dtb -> zImage--3.14.56-r0-imx6dl-seco_A62-lvds7hdmi-20161109202051.dtb
    ├── zImage-imx6q-seco_A62.dtb -> zImage--3.14.56-r0-imx6q-seco_A62-20161109202051.dtb
    ├── zImage-imx6q-seco_A62-hdmi.dtb -> zImage--3.14.56-r0-imx6q-seco_A62-hdmi-20161109202051.dtb
    ├── zImage-imx6q-seco_A62-lvds15.dtb -> zImage--3.14.56-r0-imx6q-seco_A62-lvds15-20161109202051.dtb
    ├── zImage-imx6q-seco_A62-lvds7.dtb -> zImage--3.14.56-r0-imx6q-seco_A62-lvds7-20161109202051.dtb
    ├── zImage-imx6q-seco_A62-lvds7hdmi.dtb -> zImage--3.14.56-r0-imx6q-seco_A62-lvds7hdmi-20161109202051.dtb
    └── zImage-secosbca62.bin -> zImage--3.14.56-r0-secosbca62-20161109202051.bin
    0 directories, 52 files
    I recommend to not run wic by hand. With the latest changes wic is executed automatically. The resulting image is as before in the tmp/deploy/images/<MASCHINE>/ folder and ends with .wic.bz2
    In the example above: tmp/deploy/images/secosbca62/udoo-image-full-cmdline-secosbca62.wic.bz2
  18. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Ok this worked fine. The card boot fine on hdmi. When i try to use lvds7 (configure with uEnv.txt), the card boot on hdmi. It seems that the network didn't work and debug also ! --> need to test more. Otherwise Qt5.7 work fine. Tomorrow, i will make more test and let you know.
  19. graugans
    Sep 17, 2015
    328
    141
    Interesting. What do you mean by Debugging? Debugging via Ethernet? Due to the fact I switched to latest Kernel maybe some stuff is not yet fully supported in A62. I'll take care of Ethernet during the weekend....
  20. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    I talk about uart debuging ... but today i will make some other tests.
