Connect a SATA HDD
Discussion in 'Android' started by mdcostas, Feb 18, 2014.
  1. mdcostas
    mdcostas New Member
    Feb 18, 2014
    14
    Hello.
    I'm a newbie and I have a Quad Udoo with Android operating system and want to connect a SATA HDD that I recognize it as external storage (SD Card Cell).
    This is possible?
    Thank you.
    A greeting.
  2. Decion
    Decion New Member
    Nov 12, 2013
    41
    I'm having the same issue. I have a 2.5' SATA drive here waiting to be used with the Android image but I don't know how to make Android recognize it. I'm able to access the SATA drive from other Udoo images like debian with gparted, however I don't know what to do there to make Android then detect the SATA drive. Please help.
  3. Decion
    Decion New Member
    Nov 12, 2013
    41
    Today I checked via serial USB output the logs of the boot sequences.
    With Ubuntu I see this:
    [ 2.198601] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
    [ 2.208280] ata1.00: ATA-9: WDC WD10JPVX-22JC3T0, 01.01A01, max UDMA/133
    [ 2.214990] ata1.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 31/32)
    [ 2.222085] sitronix_reset_ic
    [ 2.227324] ata1.00: configured for UDMA/133
    [ 2.231897] scsi 0:0:0:0: Direct-Access ATA WDC WD10JPVX-22J 01.0 PQ: 0 ANSI: 5
    [ 2.240565] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
    [ 2.248237] sd 0:0:0:0: [sda] 4096-byte physical blocks
    [ 2.253775] sd 0:0:0:0: [sda] Write Protect is off
    [ 2.258653] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    [ 2.325602] sda: sda1
    So the SATA drive is correctly shown and then also accessible from inside Ubuntu.
    However, when I check the Android Serial Log, there is no such SATA drive detection.
    So I take it that the Udoo team simply did not enable SATA in the Android Kernel.
  4. Decion
    Decion New Member
    Nov 12, 2013
    41
    I filed an official ticket about this and this is the reply:
    So let's see then with Android release v1.4.
  5. dzondo
    dzondo New Member
    Feb 7, 2014
    28
    Its work already with new release???
  6. andcmp
    andcmp New Member
    161
    Not yet, the 1.4 release fixed LVDS and touch related issue. We are still working on SATA support for Android.
  7. Decion
    Decion New Member
    Nov 12, 2013
    41
    Will SATA be available with Android 1.5? It's just that I'd really like to use this peace of hardware (sata drive) I've bought to use it with Udoo.
  8. dzondo
    dzondo New Member
    Feb 7, 2014
    28
    When the SATA and USB GPS will work on UDOO it will be top class!!! Hope the new release will be available soon! And someone could make tutorial how to run that BU-353 GPS ;)
  9. friedlieb
    friedlieb New Member
    May 9, 2014
    The Implementation of SATA to the Raspberry Pi would be faster ;-)
  10. pdblood
    pdblood New Member
    Apr 7, 2014
    12
    It looks like Boundary Devices added SATA support to the Android Jellybean releases for their i.MX6 boards awhile ago, and also documented how they did it. Go to this link and scroll down to the section on "SATA Support":
    http://boundarydevices.com/android-jell ... sclaimers/
    Perhaps this would be useful to the UDOO team (if not already aware of it), or UDOO owners who wish to build their own Android image incorporating the patches described in this post to enable SATA.
  11. unic8
    unic8 New Member
    Oct 31, 2013
    I'd also like to see this feature implemented since the UDOO board has a onboard SATA connector.
    I think it is not only a speed improvment more a kind of extending storage for media capabilities.
  12. primiano
    primiano New Member
    Oct 4, 2014
    15
