Connection between iMX6 and SAM3X
Discussion in 'Arduino IDE' started by SchumyAlex, Aug 27, 2014.
  1. SchumyAlex
    SchumyAlex New Member
    Aug 26, 2014
    Arduino SAM3X chipset it's very easy to program with Arduino IDE,and the Freescale IMX6 it's very powerful, but how i make a connection between them?to send data in both direction?It's a protocol?
  2. ekirei
    ekirei Administrator
    78
    There are lots of connection between the two processors. For example there's a serial connection always on that you can manage in all programming language with a library (for example pySerial for python, librxtx for Java, php Serial, etc.) or directly managing the serial dev ttymxc3 under linux. In this way you can easily exchange message with the Serial object of Arduino. Take a look to the tutorials and projects in the Discover section in the website.
    For example:
    http://www.udoo.org/ProjectsAndTutorial ... lioID=1394
    http://www.udoo.org/ProjectsAndTutorial ... oo-part-1/
    http://www.udoo.org/ProjectsAndTutorial ... udoo-pt-3/
    Another connection between the two processors is an USB OTG bus that is usually used when imx6 run Android. For examples you can check here:
    http://www.udoo.org/ProjectsAndTutorial ... lioID=1368
    Another way to communicate between the processors is with two programs that manage the shared pins.
  3. SchumyAlex
    Aug 26, 2014
