@graugans @prakash.m @SECO_FAE I just tried to copy an image of my working sd card on secoA62 emmc. Before to do it i read this post and follow the guide on seco wiki. on the card, if i enter fdisk -l i saw that my emmc is based in mmcblk3 Code: root@secosbca62:~# fdisk -l Disk /dev/mtdblock0: 1 MiB, 1048576 bytes, 2048 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/mmcblk0: 29.7 GiB, 31914983424 bytes, 62333952 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x8893b96c Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 8192 24575 16384 8M c W95 FAT32 (LBA) /dev/mmcblk0p2 24576 62333951 62309376 29.7G 83 Linux Disk /dev/mmcblk3: 3.7 GiB, 3959422976 bytes, 7733248 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x8893b96c Device Boot Start End Sectors Size Id Type /dev/mmcblk3p1 8192 24575 16384 8M c W95 FAT32 (LBA) /dev/mmcblk3p2 24576 1802239 1777664 868M 83 Linux Disk /dev/mmcblk3rpmb: 512 KiB, 524288 bytes, 1024 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/mmcblk3boot1: 2 MiB, 2097152 bytes, 4096 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/mmcblk3boot0: 2 MiB, 2097152 bytes, 4096 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes I decided to install the yocto image on it (i test to do that on mmcblk0, but in this case i erase the sdcard ...) i did this Code: root@secosbca62:~# dd if=/dev/zero of=/dev/mmcblk3 bs=512 count=2000 2000+0 records in 2000+0 records out 1024000 bytes (1.0 MB, 1000 KiB) copied, 0.242504 s, 4.2 MB/s root@secosbca62:~# sync root@secosbca62:~# zcat yoctoSA62_Qt5_6_sdCard.gz | sudo dd of=/dev/mmcblk3 bs=32M 0+18894 records in 0+18894 records out 926941184 bytes (927 MB, 884 MiB) copied, 97.0979 s, 9.5 MB/s root@secosbca62:~# sync root@secosbca62:~# fdisk -l Disk /dev/mtdblock0: 1 MiB, 1048576 bytes, 2048 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/mmcblk0: 29.7 GiB, 31914983424 bytes, 62333952 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x8893b96c Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 8192 24575 16384 8M c W95 FAT32 (LBA) /dev/mmcblk0p2 24576 62333951 62309376 29.7G 83 Linux Disk /dev/mmcblk3: 3.7 GiB, 3959422976 bytes, 7733248 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x8893b96c Device Boot Start End Sectors Size Id Type /dev/mmcblk3p1 8192 24575 16384 8M c W95 FAT32 (LBA) /dev/mmcblk3p2 24576 1802239 1777664 868M 83 Linux Disk /dev/mmcblk3rpmb: 512 KiB, 524288 bytes, 1024 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/mmcblk3boot1: 2 MiB, 2097152 bytes, 4096 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/mmcblk3boot0: 2 MiB, 2097152 bytes, 4096 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes as you can see, the yocto image seems to be correctly installed on emmc ! But now, if i reboot the card (remove j27 jumper) i have this error (in debug) : U-Boot SPL 2016.01-seco-a62-v2016.01+g654be7a (Oct 06 2016 - 10:43:35) Trying to boot from MMC Card did not respond to voltage select! spl: mmc init failed with error: -17 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### Did i make a mistake ? Do you have an idea how to resolve this ?
I have an idea. Due to the fact I used UDOO as reference emmc might be not supported by my u-boot branch. Since there is support for A62 with SPL in official udoo u-boot we can compare stuff. Gesendet von meinem FP2 mit Tapatalk
There are multiple options as far as I remember there is also a spi nor with one or two mega bytes an option could be to install u-boot there. Or we have to check the SPL code if if checks both mmc options emmc and sd card Gesendet von meinem FP2 mit Tapatalk
From the wiki it is a S25FL208K this means 1MB. Enough for u-boot Gesendet von meinem FP2 mit Tapatalk
Graugan, you talk about this 2 files : quad seco A62 I suppose in yocto you use quad for A62 at moment ?
It is a bit more complicated we use U-Boot SPL https://github.com/UDOOboard/uboot-imx/blob/2015.04.imx/board/udoo/a62/spl.c SPL allows us to use one image to rule them all. I am unsure how emmc is handled in SPL at the moment Gesendet von meinem FP2 mit Tapatalk
Ok, i would like to help more on it but i didn't know anything on uboot and SPL for the moment ... need to read more doc about this !
Can you said me where is defined on your layer the source of uboot, i found this but i didn't understand where you define the source of code (git seco or udoo) ?
For A62 I use my own u-boot. Because when I started there was no SPL u-boot for A62 only for UDOO boards. The source is defined here https://github.com/graugans/meta-udoo/blob/krogoth/recipes-bsp/u-boot/u-boot-seco_2016.01.bb Gesendet von meinem FP2 mit Tapatalk
The source itself you find here https://github.com/graugans/u-boot-seco I will try to install to emmc tomorrow night Gesendet von meinem FP2 mit Tapatalk
I just make a try this morning with udoo uboot copy directly on seco emmc with dd. I have this error (just for information) : Code: U-Boot 2014.04-g8373ccd (Nov 05 2015 - 18:48:41) CPU: Freescale i.MX6Q rev1.2 at 792 MHz CPU: Temperature 30 C, calibration data: 0x5714db69 Reset cause: POR Board: Seco SBC-i.MX6 (SBC) - A62 I2C: ready DRAM: 1 GiB Boot: eMMC MMC: FSL_SDHC: 0, FSL_SDHC: 1 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: using phy at 6 FEC [PRIME] Normal Boot Hit any key to stop autoboot: 0 Running in Remote... ## Error: "set_ip" not defined MMC: no card present mmc1(part 0) is current device MMC: no card present ** Bad device mmc 1 ** MMC: no card present mmc1(part 0) is current device MMC: no card present ** Bad device mmc 1 ** Bad Linux ARM zImage magic!
