Update: Every reboot sets the permissions back to root only. Chmod -R 777 * in the /sys/class/gpio fixes it.
The gpio are owned by the process who creates them, which in this case it must be the board code in the kernel (root) hence the issue.
OK, Thanks for the info. I'm also experience the problem where I get "No Device Found on /dev/ttyUSB0" when I try to program the Due from an external PC (running Linux Mint Debian). If I interupt the UDOO boot process and clear-reset the Due via the two jumpers then I can upload via the external PC. I wasn't clear from the early portion of this thread. Is this problem related, or unrelated, to the Debian Jessie image? Thanks for your help,
For Arduino IDE @ Debian I followed the "Arduino IDE HFP" instructions with default download, but ended up replacing bossac with the version I had from my Ubuntu image (uSD card). This got rid of the "No device found on ttymxc3" messages and meant that I didn't have to use jumpers J22 + J16 to perform erase + reset. This seems to be a custom version that will perform erase + reset every time it is touched (and performs it "successiful" even...): Code: $> arduino-1.5.4/hardware/tools/bossac --port=ttymxc3 --info Inner erase and reset routine: successiful!! Device : ATSAM3X8 Chip ID : 285e0a60 Version : v1.1 Dec 15 2010 19:25:04 ... With this bossac version Arduino sketch upload and serial monitor works as expected every time.
This is a great work. but I have some problem in HDMI - TV resolution setting. My TV's spec. can run 1920x1080i in 60Hz, and I tried udoo official Ubuntu 12.04 LTS and Ubuntu Studio, can get 1360x768 60Hz. it works but HDMI audio complete doesn't work. I use Jessie's rootfs.img (Debian and Xubuntu) it only can run in 1280x720 and xfce's top and bottom panel complete out of range, but HDMI audio works fine. I try to modifiy boot.cmd set resolution 1360x768M60 and run command mkimage -A arm -O linux -T script -n "boot" -d boot.cmd boot.scr, change boot.scr permission to rwx but it still run in 1280x720p. How can I fix this problem? On Xubuntu 13.04 rootfs, udoo's wlan missing. How can I fix this problem? Thanks! Best Regards, Alex CS Huang
Most likely this is a overscan issue, I faced the same issue with one my TVs using the UDOO. Normally the TV should have a menu option to compensate/adjust for overscan. Another option to try, if possible, would be to read the EDID from the your TV, decode it and add the correct mode to the hdmi driver code in the kernel. Can you 'pastebin; the kernel/dmesg log, it should highlight the resolution passed to the kernel and the resolution detected/used by the hdmi driver. You have no audio at 1360x768 because the imx6 hdmi driver treats the resolution as non CEA. You could try adding 1360x768 to the list of CEA modes in the hdmi kernel driver code.
Thanks for the SD image - very helpful For anyone else looking for the user/password it is debian/debian
Thanks jas max I did dmesg and it oupt is: Code: Initializing cgroup subsys cpu Linux version 3.0.35-02693-gfab6bbf (mtx512@mtx512-Inspiron-620) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #367 SMP PREEMPT Tue Jan 7 09:36:10 GMT 2014 CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: SECO i.Mx6 UDOO Board Memory policy: ECC disabled, Data cache writealloc CPU identified as i.MX6Q, silicon rev 1.2 On node 0 totalpages: 229376 free_area_init_node: node 0, pgdat 80b051a0, node_mem_map 8b800000 DMA zone: 368 pages used for memmap DMA zone: 0 pages reserved DMA zone: 46736 pages, LIFO batch:15 Normal zone: 1680 pages used for memmap Normal zone: 180592 pages, LIFO batch:31 PERCPU: Embedded 7 pages/cpu @8c008000 s5504 r8192 d14976 u32768 pcpu-alloc: s5504 r8192 d14976 u32768 alloc=8*4096 pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 227328 Kernel command line: console=ttymxc1,115200 root=/dev/mmcblk0p1 rootwait rw rootfstype=ext4 consoleblank=0 video=mxcfb0:dev=hdmi,1280x720M@60,bpp=32 PID hash table entries: 4096 (order: 2, 16384 bytes) Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) Memory: 640MB 256MB = 896MB total Memory: 896896k/896896k available, 151680k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xf4600000 - 0xffe00000 ( 184 MB) vmalloc : 0xc0800000 - 0xf2000000 ( 792 MB) lowmem : 0x80000000 - 0xc0000000 (1024 MB) pkmap : 0x7fe00000 - 0x80000000 ( 2 MB) modules : 0x7f000000 - 0x7fe00000 ( 14 MB) .init : 0x80008000 - 0x80038000 ( 192 kB) .text : 0x80038000 - 0x80aab370 (10701 kB) .data : 0x80aac000 - 0x80b062c0 ( 361 kB) .bss : 0x80b062e4 - 0x80b32e84 ( 179 kB) SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 Preemptible hierarchical RCU implementation. NR_IRQS:624 MXC GPIO hardware sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms arm_max_freq=1GHz MXC_Early serial console at MMIO 0x21e8000 (options '115200') bootconsole [ttymxc1] enabled Console: colour dummy device 80x30 Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 Initializing cgroup subsys cpuacct Initializing cgroup subsys devices Initializing cgroup subsys freezer CPU: Testing write buffer coherency: ok hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available CPU1: Booted secondary processor CPU2: Booted secondary processor CPU3: Booted secondary processor Brought up 4 CPUs SMP: Total of 4 processors activated (6324.22 BogoMIPS). devtmpfs: initialized print_constraints: dummy: NET: Registered protocol family 16 print_constraints: vddpu: 725 <--> 1300 mV at 1150 mV fast normal print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal > UDOO quad > rev C Called set_gpios_direction Test and set gpios directions and values by Gionji feat. Ekirei test Resetting ethernet physical layer. hw-breakpoint: found 6 breakpoint and 1 watchpoint registers. hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step. hw-breakpoint: maximum watchpoint size is 4 bytes. L310 cache controller enabled l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32070000, Cache size: 1048576 B bio: create slab <bio-0> at 0 mxs-dma mxs-dma-apbh: initialized print_constraints: vmmc: 3300 mV vgaarb: loaded SCSI subsystem initialized libata version 3.00 loaded. usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb Freescale USB OTG Driver loaded, $Revision: 1.55 $ imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7) imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7) MIPI CSI2 driver module loaded Advanced Linux Sound Architecture Driver Version 1.0.24. Bluetooth: Core ver 2.16 NET: Registered protocol family 31 Bluetooth: HCI device and connection manager initialized Bluetooth: HCI socket layer initialized Bluetooth: L2CAP socket layer initialized Bluetooth: SCO socket layer initialized cfg80211: Calling CRDA to update world regulatory domain i2c-core: driver [max17135] using legacy suspend method i2c-core: driver [max17135] using legacy resume method Switching to clocksource mxc_timer1 NET: Registered protocol family 2 IP route cache hash table entries: 32768 (order: 5, 131072 bytes) TCP established hash table entries: 131072 (order: 8, 1048576 bytes) TCP bind hash table entries: 65536 (order: 7, 786432 bytes) TCP: Hash tables configured (established 131072 bind 65536) TCP reno registered UDP hash table entries: 512 (order: 2, 16384 bytes) UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) NET: Registered protocol family 1 PCI: CLS 0 bytes, default 32 PMU: registered new PMU device of type 0 Static Power Management for Freescale i.MX6 wait mode is enabled for i.MX6 cpaddr = c0880000 suspend_iram_base=c08fc000 PM driver module loaded IMX usb wakeup probe the wakeup pdata is 0xbfe38a80 add wake up source irq 75 IMX usb wakeup probe the wakeup pdata is 0xbfe8a840 cpu regulator mode:ldo_enable i.MXC CPU frequency driver JFFS2 version 2.2. (NAND) \xffffffc2\xffffffa9 2001-2006 Red Hat, Inc. fuse init (API version 7.16) msgmni has been set to 1751 alg: No test for stdrng (krng) io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) MIPI DSI driver module loaded mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver hdmi mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0xa:0xa0:0xc1 fbcvt: 1280x720@60: CVT Name - .921M9 imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7) Console: switching to colour frame buffer device 160x45 imx-sdma imx-sdma: loaded firmware 1.1 imx-sdma imx-sdma: initialized Display is GTF capable fbcvt: 1280x720@60: CVT Name - .921M9 Serial: IMX driver imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX console [ttymxc1] enabled, bootconsole disabled imx-uart.3: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX loop: module loaded No sata disk. GPMI NAND driver registered. (IMX) vcan: Virtual CAN interface driver CAN device driver interface flexcan netdevice driver FEC Ethernet Driver fec_enet_mii_bus: probed usbcore: registered new interface driver rt2800usb ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1 fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000 fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected add wake up source irq 72 fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2 fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200 fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00 hub 2-0:1.0: USB hub found hub 2-0:1.0: 1 port detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. usbcore: registered new interface driver usbserial usbserial: USB Serial Driver core ARC USBOTG Device Controller driver (1 August 2005) g_ether gadget: using random self ethernet address g_ether gadget: using random host ethernet address usb0: MAC 1a:5d:af:23:01:84 usb0: HOST MAC 7a:92:61:f0:e9:8e g_ether gadget: controller 'fsl-usb2-udc' not recognized; trying CDC Ethernet (ECM) g_ether gadget: Ethernet Gadget, version: Memorial Day 2008 g_ether gadget: g_ether ready Suspend udc for OTG auto detect USB Host suspend begins will suspend roothub and its children ehci_fsl_bus_suspend begins, DR ehci_fsl_bus_suspend ends, DR host suspend ends USB Gadget resume begins fsl_udc_resume, Wait for wakeup thread finishes dr_controller_run: udc out low power mode USB Gadget resume ends fsl-usb2-udc: bind to driver g_ether mousedev: PS/2 mouse device common for all mice i2c-core: driver [isl29023] using legacy suspend method i2c-core: driver [isl29023] using legacy resume method snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0 i2c /dev entries driver Linux video capture interface: v2.00 mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16 mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17 i2c-core: driver [mag3110] using legacy suspend method i2c-core: driver [mag3110] using legacy resume method imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1) Bluetooth: Virtual HCI driver ver 1.3 Bluetooth: HCI UART driver ver 2.2 Bluetooth: HCIATH3K protocol initialized Bluetooth: Generic Bluetooth USB driver ver 0.6 usbcore: registered new interface driver btusb sdhci: Secure Digital Host Controller Interface driver sdhci: Copyright(c) Pierre Ossman sdhci sdhci-esdhc-imx.2: no write-protect pin available! sdhci sdhci-esdhc-imx.2: no card-detect pin available! mmc0: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed VPU initialized mxc_asrc registered Galcore version 4.6.9.6622 Thermal calibration data is 0x56f4db69 Thermal sensor with ratio = 179 Anatop Thermal registered as thermal_zone0 anatop_thermal_probe: default cooling device is cpufreq! usbcore: registered new interface driver usbhid usbhid: USB HID core driver usbcore: registered new interface driver snd-usb-audio mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio asoc: mxc-hdmi-soc <-> imx-hdmi-soc-dai.0 mapping ok ALSA device list: #0: imx-hdmi-soc NET: Registered protocol family 26 TCP cubic registered NET: Registered protocol family 17 can: controller area network core (rev 20090105 abi 8) NET: Registered protocol family 29 can: raw protocol (rev 20090105) can: broadcast manager protocol (rev 20090105 t) Bluetooth: RFCOMM TTY layer initialized Bluetooth: RFCOMM socket layer initialized Bluetooth: RFCOMM ver 1.11 Bluetooth: BNEP (Ethernet Emulation) ver 1.3 Bluetooth: BNEP filters: protocol multicast Bluetooth: HIDP (Human Interface Emulation) ver 1.2 lib80211: common routines for IEEE802.11 drivers lib80211_crypt: registered algorithm 'NULL' lib80211_crypt: registered algorithm 'WEP' lib80211_crypt: registered algorithm 'CCMP' lib80211_crypt: registered algorithm 'TKIP' VFP support v0.3: usb 2-1: new high speed USB device number 2 using fsl-ehci implementor 41 architecture 3 part 30 variant 9 rev 4 Bus freq driver module loaded Bus freq driver Enabled mmc0: host does not support reading read-only switch. assuming write-enable. mxc_dvfs_core_probe DVFS driver module loaded snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0) Waiting for root device /dev/mmcblk0p1... mmc0: new high speed SDHC card at address aaaa mmcblk0: mmc0:aaaa SU08G 7.40 GiB mmcblk0: p1 EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null) VFS: Mounted root (ext4 filesystem) on device 179:1. hub 2-1:1.0: USB hub found hub 2-1:1.0: 4 ports detected devtmpfs: mounted Freeing init memory: 192K usb 2-1.1: new full speed USB device number 3 using fsl-ehci USB Gadget resume begins fsl_udc_resume, Wait for wakeup thread finishes input: Logitech USB Receiver as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.1/2-1.1:1.0/input/input0 generic-usb 0003:046D:C52E.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-fsl-ehci.1-1.1/input0 input: Logitech USB Receiver as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.1/2-1.1:1.1/input/input1 generic-usb 0003:046D:C52E.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-fsl-ehci.1-1.1/input1 usb 2-1.3: new high speed USB device number 4 using fsl-ehci ieee80211 phy0: Selected rate control algorithm 'minstrel_ht' Registered led device: rt2800usb-phy0::radio Registered led device: rt2800usb-phy0::assoc Registered led device: rt2800usb-phy0::quality udevd[1511]: starting version 175 init: plymouth main process (1428) killed by ABRT signal init: plymouth-splash main process (2028) terminated with status 2 init: failsafe main process (2513) killed by TERM signal init: plymouth-stop pre-start process (2577) terminated with status 1 my EDID Code: Code: 00 ff ff ff ff ff ff 00 06 af 2c 32 00 00 00 00 00 13 01 03 80 1d 10 78 0a 15 85 97 58 53 8a 26 25 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 26 1b 56 64 50 00 16 30 30 20 36 00 25 a4 10 00 00 18 00 00 00 0f 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 fe 00 41 55 4f 0a 20 20 20 20 20 20 20 20 20 00 00 00 fe 00 42 31 33 33 58 57 30 33 20 56 32 20 0a 00 49
dmesg output shows that uboot didn't pass the kernel the correct resolution, most likely your boot.scr changes weren't picked up.
Updated original post with links to newer experimental rootfs with 3.10.17 BSP support + gstreamer 1.0 plugins + webcam interfacing.
The following is my u-boot environment setting: Code: U-Boot 2013.10-rc3-gb48999b (Jan 07 2014 - 09:57:07) CPU: Freescale i.MX6Q rev1.2 at 792 MHz Reset cause: WDOG Board: UDOO DRAM: 1 GiB MMC: FSL_SDHC: 0 auto-detected panel HDMI Display: HDMI (1024x768) In: serial Out: serial Err: serial Net: using phy at 6 FEC [PRIME] Hit any key to stop autoboot: 0 UDOO board => printenv baudrate=115200 boot_fdt=try bootcmd=mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loaduimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi bootdelay=5 bootscript=echo Running bootscript from mmc ...; source console=ttymxc1 ethact=FEC ethaddr=00:c0:08:88:9c:d7 ethprime=FEC fdt_addr=0x11000000 fdt_file=imx6q-udoo.dtb fdt_high=0xffffffff initrd_high=0xffffffff ip_dyn=yes loadaddr=0x12000000 loadbootscript=ext2load mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script}; loadfdt=ext2load mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file} loaduimage=ext2load mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage} mmcargs=setenv bootargs console=${console},${baudrate} root=${mmcroot} ${hdmi_pa tch} fbmem=24M video=mxcfb0:dev=hdmi,1360x768M@60,bpp=32 mmcboot=echo Booting from mmc ...; run mmcargs; if test ${boot_fdt} = yes || tes t ${boot_fdt} = try; then if run loadfdt; then bootm ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then bootm; else echo WARN: Cannot load the DT; fi; fi; else bootm; fi; mmcdev=0 mmcpart=1 mmcroot=/dev/mmcblk0p1 rootwait rw netargs=setenv bootargs console=${console},${baudrate} root=/dev/nfs ${hdmi_patc h} ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp netboot=echo Booting from net ...; run netargs; if test ${ip_dyn} = yes; then se tenv get_cmd dhcp; else setenv get_cmd tftp; fi; ${get_cmd} ${uimage}; if test $ {boot_fdt} = yes || test ${boot_fdt} = try; then if ${get_cmd} ${fdt_addr} ${fdt _file}; then bootm ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; th en bootm; else echo WARN: Cannot load the DT; fi; fi; else bootm; fi; script=boot.scr splashpos=m,m uimage=/boot/uImage update_sd_firmware=if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else seten v get_cmd tftp; fi; if mmc dev ${mmcdev}; then if ${get_cmd} ${update_sd_firmwar e_filename}; then setexpr fw_sz ${filesize} / 0x200; setexpr fw_sz ${fw_sz} + 1; mmc write ${loadaddr} 0x2 ${fw_sz}; fi; fi update_sd_firmware_filename=u-boot.imx Environment size: 2078/8188 bytes this is my boot.cmd Code: setenv bootargs 'console=ttymxc1,115200 root=/dev/mmcblk0p1 rootwait rw rootfsty pe=ext4 consoleblank=0 video=mxcfb0:dev=hdmi,1360x768M@60,bpp=32' run loaduimage bootm After I run a command mkimage script Code: mkimage -A arm -O linux -T script -n "boot" -d boot.cmd boot.scr boot.scr Code: 'VX�*SLϒ��Vj�boot�setenv bootargs 'console=ttymxc1,115200 root=/dev/mmcblk0p1 rootwait rw rootfstype=ext4 consoleblank=0 video=mxcfb0:dev=hdmi,1360x768M@60 ,bpp=32' run loaduimage bootm I changed boot.scr permission to 777 and put it in root directory but its resolution does not work in 1360x768.
Unfortunately as I'm developing on/supporting a number of different imx6 boards, I don't always have time to put images together. May be someone can put one together.
Thx for your work! When needing egl for compiling programs like QT5 header files like gl2.h are missing. Because of this the whole package for gpu driver has to be installed which is gpu-viv-bin-mx6q-3.10.9-1.0.0.tar.gz -> http://repository.timesys.com/buildsour ... 0.9-1.0.0/ INFO: Default tarball is linked using framebuffer. So check correct linking of files (eg for framebuffer): root@udoo-1-quad:/usr/lib# ls -la libEGL* -rwxr-xr-x 1 root root 582460 Sep 10 2013 libEGL-dfb.so -rwxr-xr-x 1 root root 347691 Sep 10 2013 libEGL-fb.so lrwxrwxrwx 1 root root 12 Sep 10 2013 libEGL.so -> libEGL-fb.so lrwxrwxrwx 1 root root 12 Sep 10 2013 libEGL.so.1 -> libEGL-fb.so lrwxrwxrwx 1 root root 12 Sep 10 2013 libEGL.so.1.0 -> libEGL-fb.so lrwxrwxrwx 1 root root 13 Dec 15 18:10 libEGL.so.1.0.0 -> libEGL-x11.so -rwxr-xr-x 1 root root 361183 Sep 10 2013 libEGL-wl.so -rwxr-xr-x 1 root root 329808 Sep 10 2013 libEGL-x11.so root@udoo-1-quad:/usr/lib# ls -la libGAL* -rwxr-xr-x 1 root root 3858397 Sep 10 2013 libGAL-dfb.so -rwxr-xr-x 1 root root 3787878 Sep 10 2013 libGAL-fb.so lrwxrwxrwx 1 root root 12 Sep 10 2013 libGAL.so -> libGAL-fb.so -rwxr-xr-x 1 root root 3800797 Sep 10 2013 libGAL-wl.so -rwxr-xr-x 1 root root 3960240 Sep 10 2013 libGAL-x11.so root@udoo-1-quad:/usr/lib# ls -la libVIVANTE* -rwxr-xr-x 1 root root 3691204 Sep 10 2013 libVIVANTE-dfb.so -rwxr-xr-x 1 root root 3620875 Sep 10 2013 libVIVANTE-fb.so lrwxrwxrwx 1 root root 16 Sep 10 2013 libVIVANTE.so -> libVIVANTE-fb.so -rwxr-xr-x 1 root root 3634865 Sep 10 2013 libVIVANTE-wl.so -rwxr-xr-x 1 root root 3687996 Sep 10 2013 libVIVANTE-x11.so
Updated rootfs to 3.10.17 GA release, see original post for link. You need to create a new kernel with my udoo patches from my beta branch.
Dear jas-mx, thanks for this really cool piece of software. My question is, if it is possible to boot your image in QEMU or mount it otherwise to make some modifications to the rootfs without re-building it? Thanks for your help, Chris
