Default password for user ubuntu
Discussion in 'UDOO 101' started by rotorbudd, Oct 19, 2013.
  1. rotorbudd
    rotorbudd UDOOer
    Oct 18, 2013
    Anyone know what this password is?
    Somehow I've got the Ubuntu login screen with 2 choices, Guest and ubuntu.
    I've tried ubuntu, password, etc.
    Logging in as quest gets me nothing as I can't sudo without the password.
  2. Jstaud
    Jstaud New Member
    Oct 19, 2013
  3. Jstaud
    Jstaud New Member
    Oct 19, 2013
    1) Open up a terminal and type sudo passwd root
    2) Follow the onscreen instructions to set and confirm your new password
  4. rotorbudd
    rotorbudd UDOOer
    Oct 18, 2013
    The problem is: Logging in as quest gets me nothing as I can't sudo without the password.
    I haven't setup anyother users, changed root's password. I just need the default root/ubuntu password.
  5. josolanes
    josolanes New Member
    Oct 14, 2013
    64
    fwiw - using the v1.2 for quad I was able to login to guest and change ubuntu's password in the terminal upon startup. I did, however, notice that the keyring still uses password "ubuntu"
    But I believe the default user password on mine was ubuntu and changing it using sudo was not an issue, sudo did not ask for a password when I tried, just what password I would like to change it to
  6. Jstaud
    Jstaud New Member
    Oct 19, 2013
    Yeah ubuntu should be the default password. Somehow I was able to sudo without a password and change it. I had the same issue.
