DHCP is broken?
Discussion in 'UDOO NEO' started by Gorgo, Nov 16, 2016.
  1. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    158
    17
    Hi guys,
    as I told here (http://www.udoo.org/forum/threads/solved-vnc-remote-control.6123/) I want you know about a strange dhcp behaviour in UDOO neo.
    How to reproduce:
    - Flash a Udoobuntu distro in your UDOO Neo;
    - Plug the client (Elementary OS in my case) to the UDOO Neo;
    - The client gets the usb IP;
    - Everything works, I can connect to the webPanel connecting to 192.168.7.2
    - Reboot the client
    - The client doesn't reacquire the IP to connect to UDOO
    ElementaryOS - ifconfig
    gorgo@dago:~$ ifconfig enp0s20u2
    enp0s20u2 Link encap:Ethernet  IndirizzoHW 4e:71:9d:14:b1:2f
              indirizzo inet6: fe80::658a:aef6:b029:a92a/64 Scope:Link
              UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
              RX packets:36 errors:0 dropped:0 overruns:0 frame:0
              TX packets:586 errors:0 dropped:0 overruns:0 carrier:0
              collisioni:0 txqueuelen:1000
              Byte RX:6205 (6.2 KB)  Byte TX:125411 (125.4 KB)
    ElementaryOS - journalctl -fln
    nov 16 16:45:29 dago NetworkManager[870]: <info>  [1479311129.5562] policy: auto-activating connection 'Connessione via cavo 1'
    nov 16 16:45:29 dago NetworkManager[870]: <info>  [1479311129.5575] device (enp0s20u2): Activation: starting connection 'Connessione via cavo 1' (c9b84d27-36ac-3cb7-9f80-1b907ecd432c)
    nov 16 16:45:29 dago NetworkManager[870]: <info>  [1479311129.5578] device (enp0s20u2): state change: disconnected -> prepare (reason 'none') [30 40 0]
    nov 16 16:45:29 dago NetworkManager[870]: <info>  [1479311129.5586] device (enp0s20u2): state change: prepare -> config (reason 'none') [40 50 0]
    nov 16 16:45:29 dago NetworkManager[870]: <info>  [1479311129.5592] device (enp0s20u2): state change: config -> ip-config (reason 'none') [50 70 0]
    nov 16 16:45:29 dago NetworkManager[870]: <info>  [1479311129.5598] dhcp4 (enp0s20u2): activation: beginning transaction (timeout in 45 seconds)
    nov 16 16:45:29 dago NetworkManager[870]: <info>  [1479311129.5668] dhcp4 (enp0s20u2): dhclient started with pid 32220
    nov 16 16:45:29 dago dhclient[32220]: DHCPDISCOVER on enp0s20u2 to 255.255.255.255 port 67 interval 3 (xid=0xcd6f273f)
    nov 16 16:45:29 dago gnome-session[1606]: Failed to register: GDBus.Error:org.freedesktop.DBus.Error.NoReply: Message recipient disconnected from message bus without replying
    nov 16 16:45:31 dago avahi-daemon[806]: Joining mDNS multicast group on interface enp0s20u2.IPv6 with address fe80::658a:aef6:b029:a92a.
    nov 16 16:45:31 dago avahi-daemon[806]: New relevant interface enp0s20u2.IPv6 for mDNS.
    nov 16 16:45:31 dago avahi-daemon[806]: Registering new address record for fe80::658a:aef6:b029:a92a on enp0s20u2.*.
    nov 16 16:45:32 dago dhclient[32220]: DHCPDISCOVER on enp0s20u2 to 255.255.255.255 port 67 interval 7 (xid=0xcd6f273f)
    nov 16 16:45:33 dago gnome-session[1606]: [1:40:1116/164533:ERROR:ffmpeg_demuxer.cc(1595)] OnReadFrameDone result=-541478725 IsMaxMemoryUsageReached=0
    nov 16 16:45:37 dago dhclient[31055]: No DHCPOFFERS received.
    nov 16 16:45:37 dago dhclient[31055]: No working leases in persistent database - sleeping.
    nov 16 16:45:39 dago dhclient[32220]: DHCPDISCOVER on enp0s20u2 to 255.255.255.255 port 67 interval 7 (xid=0xcd6f273f)
    nov 16 16:45:43 dago gnome-session[1606]: [1:40:1116/164543:ERROR:ffmpeg_demuxer.cc(1595)] OnReadFrameDone result=-541478725 IsMaxMemoryUsageReached=0
    nov 16 16:45:46 dago dhclient[32220]: DHCPDISCOVER on enp0s20u2 to 255.255.255.255 port 67 interval 9 (xid=0xcd6f273f)
    nov 16 16:45:53 dago smartd[791]: Device: /dev/sda [SAT], SMART Usage Attribute: 190 Airflow_Temperature_Cel changed from 38 to 37
    nov 16 16:45:54 dago gnome-session[1606]: [1:40:1116/164553:ERROR:ffmpeg_demuxer.cc(1595)] OnReadFrameDone result=-541478725 IsMaxMemoryUsageReached=0
    nov 16 16:45:55 dago dhclient[32220]: DHCPDISCOVER on enp0s20u2 to 255.255.255.255 port 67 interval 9 (xid=0xcd6f273f)
    nov 16 16:46:04 dago gnome-session[1606]: [1:40:1116/164604:ERROR:ffmpeg_demuxer.cc(1595)] OnReadFrameDone result=-541478725 IsMaxMemoryUsageReached=0
    nov 16 16:46:04 dago dhclient[32220]: DHCPDISCOVER on enp0s20u2 to 255.255.255.255 port 67 interval 9 (xid=0xcd6f273f)
    nov 16 16:46:08 dago gnome-session[1606]: (gnome-settings-daemon:1723): GLib-CRITICAL **: Source ID 21123 was not found when attempting to remove it
    nov 16 16:46:13 dago dhclient[32220]: DHCPDISCOVER on enp0s20u2 to 255.255.255.255 port 67 interval 15 (xid=0xcd6f273f)
    nov 16 16:46:14 dago gnome-session[1606]: [1:40:1116/164614:ERROR:ffmpeg_demuxer.cc(1595)] OnReadFrameDone result=-541478725 IsMaxMemoryUsageReached=0
    nov 16 16:46:14 dago NetworkManager[870]: <warn>  [1479311174.5213] dhcp4 (enp0s20u2): request timed out
    nov 16 16:46:14 dago NetworkManager[870]: <info>  [1479311174.5214] dhcp4 (enp0s20u2): state changed unknown -> timeout
    nov 16 16:46:14 dago NetworkManager[870]: <info>  [1479311174.5380] dhcp4 (enp0s20u2): canceled DHCP transaction, DHCP client pid 32220
    nov 16 16:46:14 dago NetworkManager[870]: <info>  [1479311174.5381] dhcp4 (enp0s20u2): state changed timeout -> done
    nov 16 16:46:14 dago NetworkManager[870]: <info>  [1479311174.5387] device (enp0s20u2): state change: ip-config -> failed (reason 'ip-config-unavailable') [70 120 5]
    nov 16 16:46:14 dago NetworkManager[870]: <warn>  [1479311174.5391] device (enp0s20u2): Activation: failed for connection 'Connessione via cavo 1'
    nov 16 16:46:14 dago NetworkManager[870]: <info>  [1479311174.5395] device (enp0s20u2): state change: failed -> disconnected (reason 'none') [120 30 0]
    nov 16 16:46:14 dago avahi-daemon[806]: Withdrawing address record for fe80::658a:aef6:b029:a92a on enp0s20u2.
    nov 16 16:46:14 dago avahi-daemon[806]: Leaving mDNS multicast group on interface enp0s20u2.IPv6 with address fe80::658a:aef6:b029:a92a.
    nov 16 16:46:14 dago avahi-daemon[806]: Interface enp0s20u2.IPv6 no longer relevant for mDNS.
    UDOO - ps -aux | grep dhcp
    udooer@udooneo:~$ ps -aux | grep dhcp
    dhcpd      964  0.0  0.4   5844  4204 ?        Ss    2015   0:00 dhcpd -user dhcpd -group dhcpd -f -q -4 -pf /run/dhcp-server/dhcpd.pid -cf /etc/dhcp/dhcpd.conf
    UDOO - ifconfig usb0
    usb0      Link encap:Ethernet  HWaddr 4e:71:9e:14:b1:2f
              inet addr:192.168.7.2  Bcast:192.168.7.3  Mask:255.255.255.252
              inet6 addr: fe80::4c71:9eff:fe14:b12f/64 Scope:Link
              RX packets:630 errors:0 dropped:0 overruns:0 frame:0
              TX packets:71 errors:0 dropped:0 overruns:0 carrier:0
              collisions:0 txqueuelen:1000
              RX bytes:98135 (98.1 KB)  TX bytes:16459 (16.4 KB)
    Possible workaround:
    - Extend subnet range in /ect/dhcp/dhcpd.conf to
    subnet 192.168.7.0 netmask 255.255.255.0 {
            option routers          192.168.7.2;
            option subnet-mask      255.255.255.0;
            range 192.168.7.1       192.168.7.100;
    and in /etc/network/interfaces, change the usb0 netmask to netmask 255.255.255.0
    - Set static IP to the client
    I set 192.168.7.1, netmask 255.255.255.252 and gateway 193.168.7.0 in NetworkManager
    Question to devs:
    Is it correct this behaviour? Shouldn't the UDOO's DHCP renew the client's IP if it reboots? Do you have this problem too?
  2. Andrea Rovai
    With other clients - like Ubuntu 16.04 - we don't get the same behaviour. The IP assigned is hold after reboot and is 192.168.7.1
    Is anyone else registering this behaviour?
  3. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    158
    17
    Ciao Andrea,
    We tested it with a MacOS+VM(Ubuntu 16.04) too.
    If we plug the UDOO, Ubuntu says that It's trying to connect but eventually fails.
    uname -a:
    Linux ubuntu 4.4.0-47-generic #68-Ubuntu SMP Wed Oct 26 19:39:52 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
    ifconfig:
    ens33     Link encap:Ethernet  HWaddr 00:0c:29:80:8c:58
              RX packets:186 errors:0 dropped:0 overruns:0 frame:0
              TX packets:319 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:28951 (28.9 KB)  TX bytes:36718 (36.7 KB)
    ens35u1   Link encap:Ethernet  HWaddr 4e:71:9d:b9:52:4b
              inet6 addr: fe80::6be9:dc7f:1499:6b47/64 Scope:Link
              RX packets:28 errors:0 dropped:0 overruns:0 frame:0
              TX packets:111 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:4407 (4.4 KB)  TX bytes:25162 (25.1 KB)
    lo        Link encap:Local Loopback
              inet addr:127.0.0.1  Mask:255.0.0.0
              inet6 addr: ::1/128 Scope:Host
              UP LOOPBACK RUNNING  MTU:65536  Metric:1
              RX packets:991 errors:0 dropped:0 overruns:0 frame:0
              TX packets:991 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:74645 (74.6 KB)  TX bytes:74645 (74.6 KB)
  4. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    158
    17
    MacOS+VM(OpenSuse tumbleweed)
    uname -a
    Linux linux-k01o 4.8.6-2-default #1 SMP PREEMPT Thu Nov 3 13:00:34 UTC 2016 (1d89b44) x86_64 x86_64 x86_64 GNU/Linux
    ifconfig
    no167777 Link encap:Ethernet  HWaddr 00:0C:29:1A:5D:08
              UP BROADCAST MULTICAST  MTU:1500  Metric:1
              RX packets:31448 errors:0 dropped:0 overruns:0 frame:0
              TX packets:18693 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:43239198 (41.2 Mb)  TX bytes:1117257 (1.0 Mb)
              Interrupt:19 Base address:0x2000
    ens35u2   Link encap:Ethernet  HWaddr D6:72:1A:A8:1E:3B
              inet6 addr: fe80::2bae:d7c8:d76a:344/64 Scope:Link
              RX packets:35 errors:0 dropped:0 overruns:0 frame:0
              RX bytes:6111 (5.9 Kb)  TX bytes:18079 (17.6 Kb)
              RX packets:2086 errors:0 dropped:0 overruns:0 frame:0
              TX packets:2086 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:168716 (164.7 Kb)  TX bytes:168716 (164.7 Kb)
    It tries and it says "Wired connection deactivated. IP configuration unavailable" eventually.
    [​IMG]
    Note:
    UDOO Neo is only connected via USB to the laptop.
    UDOO uname -a
    Linux udooneo 3.14.56-udooneo-02023-g8d371df #5 SMP PREEMPT Thu Jul 28 15:48:30 UTC 2016 armv7l armv7l armv7l GNU/Linux
  5. Andrea Rovai
    Thanks for reporting so thoroughly. Tomorrow we'll double-check it together.
  6. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    158
    17
    You can contact me if you need a live feedback with our configuration ;)
    Buona serata!
    Andrea Rovai likes this.
  7. krl
    krl New Member
    Nov 8, 2016
    11
    I've had these problems with UDOObuntu 2.1 as well, particularly after installing the udoo-softap meta package as per http://www.udoo.org/docs-neo/Wireless_Communication/WiFi_SoftAP.html and then uninstalling it again.
    Solution was to rm /var/lib/dhcp/dhcp.leases.
    Background seems to be that there is exactly one lease to give by default, and after the occasional reboot, in my case it was still marked as being held by "hardware ethernet 4e:71:9d:aa:bb:cc;" rather than "hardware ethernet 4e:71:9d:8b:e3:fd;" and with a different UID than my client decided to register for.
    An alternative work-around would be to fix the address and delete the UID line.
    Not sure what a best practice would be, but i guess that single USB lease (and copies of it) should always be removed from the leases file upon boot, while leaving other leases untouched.
  8. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    158
    17
    I'm facing the problem without installing package from WiFi_SoftAP page
  9. krl
    krl New Member
    Nov 8, 2016
    11
    Yes, that was just a sure way for me to trigger the problem. It surfaced under other circumstances as well, but i didn't investigate at that time and just re-wrote the clean image to start over again. Anyhow, does deleting dhcp.leases work for you?
  10. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    158
    17
    Up.
    Another very annoying problem Udoo has is that it "overwrites" the laptop route and it stops its connection.
    I'm not an expert of this dynamics, but I'll try to explain the problem and the annoying workaround:
    - Udoobuntu image on a sd into the Udoo FULL.
    - Plug the Udoo to a laptop with a usb cable
    - When the laptop gets the usb connection it looses the right route.
    Before udoo:
    gorgo@dago:~$ ip r
    default via 192.168.1.254 dev wlo1  proto static  metric 600
    172.17.0.0/16 dev docker0  proto kernel  scope link  src 172.17.0.1 linkdown
    172.18.0.0/16 dev br-466d62c4cc01  proto kernel  scope link  src 172.18.0.1 linkdown
    192.168.1.0/24 dev wlo1  proto kernel  scope link  src 192.168.1.110  metric 600
    After:
    default via 192.168.7.2 dev enp0s20u9  proto static  metric 100
    192.168.7.0/30 dev enp0s20u9  proto kernel  scope link  src 192.168.7.1  metric 100
    And in order to restore wifi connection I have to:
    gorgo@dago:~$ sudo ip r del default via 192.168.7.2
    EVERYTIME.
    This doesn't happen with other boards I tried (that they use some dhcp procedure).
  11. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    158
    17
    I tried to delete the dhcp.leases but it doesn't always work :/
