Documentation
Discussion in 'UDOO 101' started by sirrab, Jan 12, 2015.
  1. sirrab
    sirrab UDOOer
    Jul 26, 2014
    264
    32
    Tried compiling from sources, using UDOO documentation, and get errors. For "ncurses-dev", use libncurses5-dev now? And "uboot-mkimage" use u-boot-tools? I was using 0.4 version of the UDOO documentation. Is there a better source of documentation?
  2. sirrab
    sirrab UDOOer
    Jul 26, 2014
    264
    32
    And there needs to be better documentation on using "make ARCH=arm menuconfig" software/command.
  3. delba
    1,064
    We're working to upgrade the documentation (as well as the website). The new version will be (hopefully) error-free.
  4. sirrab
    sirrab UDOOer
    Jul 26, 2014
    264
    32
    Documentation still hasn't been updated! Jeesh peoples. When you do update it, be sure to add use the wireless connection first on a fresh install. And do a "sudo apt-get update" command in a terminal. There is a 2nd one that should be run as well.... Which is....??????
  5. sirrab
    sirrab UDOOer
    Jul 26, 2014
    264
    32
    The second command is "sudo apt-get dist-upgrade". And to fix some "totem" issues, "sudo apt-get install -f". (Thanks jrullan!)
  6. sirrab
    sirrab UDOOer
    Jul 26, 2014
    264
    32
    After a fresh install of UDOObutu v1.1, and the commands "apt-get update" and "apt-get dist-upgrade" the desktop icon for Lubuntu Software Center has a "?" for the icon. And it will not run. What's up with that?
  7. Andrea Rovai
    Hi there sirrab,
    your problem is that with sudo apt-get dist-upgrade you lose the GPU graphic acceleration.
