Does Udoo Bolt support GPU SR-IOV?
Discussion in 'UDOO BOLT' started by Lator, Mar 6, 2021.
  1. Lator
    Lator UDOOer
    Sep 30, 2020
    12
    Hi
    I just saw in the BIOS configuration that you can enable SR-IOV. I woul like to know if enabling it adds SR-IOV capabilities to the GPU.
    Thanks,
    Lator
  2. ccs_hello
    536
    194
    I doubt it. Ryzen embedded APU v3000 uses VEGA 8 GPU core.
    AFAIK, "MxGPU or SR-IOV for GPU" capability has not trickled down to this line of product.
    evaloverde likes this.
  3. Lator
    Lator UDOOer
    Sep 30, 2020
    12
    That is unfortunate. So what does the SR-IOV option in the Udoo Bolt BIOS does if enabled?
  4. ccs_hello
    536
    194
    Please understand, many settings in BIOS options are simply "flags", indicating the "feature/capability supplier" should or should not turn such feature ON or OFF. Granted, some features are native residing in CPU/APU, North Bridge, South Bridge, embedded GPU, etc., some are not. E.g. eGPU, add-on Ethernet controller, etc.
    I.e., see a field in BIOS setting only means you'll have to do some studies on theory of operations. No more and no less.
    On SR-IOV, these are peripheral device capabilities (e.g.,special Network cloud server adapter, special cloud server-grade GPU, etc. typically in high hundreds or $1000-$2000 range.) BIOS setting is just a flag, allowing the system board to support such beast.
    Lator likes this.
