Domande su UDOO x86 basic
Discussion in 'Italiano' started by Francy2040, Jun 20, 2017.
  1. Francy2040
    Francy2040 New Member
    Jun 20, 2017
    18
    Buonasera,avrei intenzione di comprare un Udoo x86 basic
    Avrei diverse domande da fare :
    Quando potrò comprarlo visto che sullo shop me lo da non disponibile?
    E poi,in che senso "E' compatibile con Arduino"? Posso collegare ad uno di essi un arduino?Se si,cosa posso farci?
    2,162
    551
    @Laura How is your Italian? :) Seems to be a Udoo Team question.
  3. Francy2040
    Jun 20, 2017
    18
    I can speak english,too
    @waltervl
  4. waltervl
    2,162
    551
    When the Udoo X86 can be bought in the shop is a big mystery. The shop says in the next days for some weeks now. You as an Italian can interpret that better then me :)
    The Udoo X86 is a combination of a PC and an Arduino 101(CPU is Intel Curie). So the arduino hardware connections/ pinout is compatible. Also it can be programmed with the standard Arduino IDE.
    The difference between the various X86'S is only the PC part (processor, GPU, RAM, and eMMC (build in SD card)). The Arduino 101 part is the same in all X86'S.
    Edit, typos
  5. Francy2040
    Jun 20, 2017
    18
    So can't I connect an Arduino to a pc?
    @waltervl
  6. waltervl
    2,162
    551
    Yes, you can add an extra Arduino to the PC side of the Udoo X86 if you want to, it has USB ports that are available fo that. But you perhaps don't need to as it has a build in Arduino 101.
    So if you now for example have a PC (or Raspberry Pi) and an Arduino Uno you can replace that with 1 Udoo X86. You have to take care of the 3.3V/5V difference between the Arduino 101 and Arduino Uno but it is very good possible.
    Edit, See also this page for more information: https://www.udoo.org/docs-x86/Arduino_101_(Intel_Curie)/Pinout.html
    Andrea Rovai likes this.
  7. Andrea Rovai
    As far as I know UDOO X86 is protected against 5V overvoltage exactly like Arduino 101, so there shouldn't be this problem - isn't it, @Laura?
    Per quel che ne so UDOO X86 è protetta contro overvoltaggio da 5V esattamente come Arduino 101, dunque non dovrebbe esserci questo problema - non è così, Laura?
  8. waltervl
    2,162
    551
    That is correct but connected devices could not work if they only get 3.3V instead of 5V
    Quote of the documentation:
  9. Francy2040
    Jun 20, 2017
    18
    Thanks to all
    And what can I do with an arduino connected to the Udoo x86?
    Grazie a tutti
    Cosa potrei fare con un arduino connesso all'Udoo x86?
  10. waltervl
    2,162
    551
    :) :) You asked it yourself!! If you need extra functions that the build in Arduino cannot deliver (extra in- or outputs etc).
    Do you have a Arduino now? If so what are you doing with it now?
  11. Francy2040
    Jun 20, 2017
    18
    No,I have not an arduino,but I want to buy one
  12. waltervl
    2,162
    551
    Well, you do not need to buy one if you buy the Udoo X86 :)
  13. Andrea Rovai
    C'è già un Arduino 101 su UDOO X86, non hai bisogno di attaccarcene un altro.
    Con l'Arduino puoi riprogrammare il mondo fisico. In pratica, ci attacchi sensori, motori e altri aggeggi vari che interagiscono con il mondo e "fanno cose". Cose che con un computer normale non puoi fare.
    Qualche spunto su Wired Italia: https://www.wired.it/gadget/computer/2012/03/23/50-progetti-con-arduino/
  14. Francy2040
    Jun 20, 2017
    18
    Grazie mille a tutti
    Ora che è disponibile credo che comprerò un Udoo x86 basic come regalo di compleanno
    Thanks to all
    Now that the udoo x86 is available I think I'll buy an Udoo x86 basic for my birthday
  15. Francy2040
    Jun 20, 2017
    18
    Oggi assieme a mio padre stavamo per comprare un udoo x86 basic , ma ci siamo accorti che il modulo wifi + bluetooth e il case in acrilico non sono disponibili . Quando saranno disponibili?
    Yesterday with my dad we had to buy an udoo x86 basic,but the M.2 Wi-Fi Intel dual band ac Wi-Fi + BT 4.2 5ghz + antenna adhesive isn't available . When will they available?
  16. waltervl
    2,162
    551
    @Laura Another confusing Stock /No Stock issue here.....
    Stock indicator is green but when you really want to add it to your shop basket it will say not available.
  17. Francy2040
    Jun 20, 2017
    18
    Non è disponibile neppure il case in acrilico
    The acrilic case is also not available
  18. Francy2040
    Jun 20, 2017
    18
    Ho risolto , grazie a tutti
    I solved,thanks to all
  19. Francy2040
    Jun 20, 2017
    18
    Un'altra domanda : l'UDOO X86 quante uscite Mini PCI-E ha?
    Another question : the Udoo x86 how many mini pci-e outputs does it have?
  20. waltervl
    2,162
    551
