Dual ethernet module
Discussion in 'UDOO X86' started by Firewall, Aug 16, 2017.
  1. Firewall
    Firewall New Member
    Aug 16, 2017
    Hi all.
    Before I commit to buy udoo and use it as a bsd firewall I need to make sure that
    1. Udoo will be able to install opensense
    2. Udoo will be able to run it fast and secure. ( got 1 gb fiber net)
    3. Will I be able to fit the dual ethernet module together with the m2 ssd module. It looks like that the connector on the ethernet module take up the space that the ssd would have to use.
    Have anyone tried this combo? Will udoo work for my intended use?
  2. Markus Laire
    Markus Laire Active Member
    Mar 9, 2017
    225
    91
    You can't use both dual-ethernet and m2-ssd at the same time since they both use same Key-B M.2 slot.
  3. Gronis
    Gronis New Member
    May 6, 2017
    10
    10
    I want to add that you can install an ssd through SATA if there is any interest in that, and still use the m.2 key-b slot for dual ethernet.
  4. Firewall
    Firewall New Member
    Aug 16, 2017
    But with sata ssd then I would need an external powersupply just for the sata?
  5. Benjamin
    Benjamin New Member
    Mar 29, 2017
    12
  6. Benjamin
    Benjamin New Member
    Mar 29, 2017
    12
    You can also always use a USB ethernet adapter, USB3 is capable of handling a 1gb network card fine.
  7. samholton
    samholton New Member
    May 22, 2017
    26
    Depending on your case and power consumption, you can probably grab the 12v from the existing power supply. I split the incoming power cable and have a 3.5" mechanical drive running off of it. Even under heavy load its not reaching the 3A limit of the supply.
    Or if you are worried you could always use a single 12v supply with higher current.
  8. Rune Andresen
    Rune Andresen New Member
    Jun 16, 2016
    I'm currently running OPNsense 17.7 on a UDOO. Unfortunatly, I couldn't make the BSD that OPNsense uses see the eMMC .. but I think/hope that will be fixed once OPNsense updates to FreeBSD 12.
    I've already ordered the dual ethernet module, so I can give you an answer on the 1G fiber, when it arrives and I get it installed .. :)
    Regards,
    Rune Andresen
  9. Firewall
    Firewall New Member
    Aug 16, 2017
    Hi Rune, fellow norwegian.
    I have 1 gb fiber internet and several servers, users on my network. That's why I need a fast, powerful firewall. I like to find hardware that's able to do that. I hope udoo will do everything I ask of it.
    I'll await your ethernet module reply
    Cheers
  10. JamesGardiner
    JamesGardiner New Member
    Nov 2, 2017
    Any progress on using extra Ethernet adapters?
    I am interested to know how it works as a router
  11. Rune Andresen
    Jun 16, 2016
    Hi James
    I got sidetracked and left the UDOO running OPNsense from a SD-card and with VLAN-tagging. It worked fine (until the SD-card broke), so I didn't get around to tinker with the dual port[1] :-/
    Regards,
    Rune Andresen
    [1]: If it ain't broken, don't 'fix' it .. ;-)
