Embedded Controller SPI
Discussion in 'UDOO BOLT' started by Quincy Jones, Jun 17, 2019.
  1. Quincy Jones
    Quincy Jones New Member
    Jun 16, 2019
    I am looking to preorder a UDOO Bolt from Mouser. It appears that I have to sign a purchase agreement to secure my order which is non-returnable/refundable. I will be using this inside of a robotics project and I really need to be able to access the SPI bus natively from linux(as well as the other GPIO pins) C/C++ program. I'd prefer not to have to UART to the onboard Arduino and then have that translate to SPI. Is this possible?
    Thanks!
    2,224
    561
  3. Quincy Jones
    Jun 16, 2019
    Yes. That is always the X-factor. In theory it should work based on the hardware. Curious about those drivers of course. If this is possible there is nothing that can compete with this board from a robotics implementation perspective especially at this price range with the flexibility of speccing your own memory/storage etc. To have this much power in a board this small with CPU side accessible GPIO/SPI etc will be phenomenal.
  4. Fazlı Faruk Okumuş
    Fazlı Faruk Okumuş UDOOer
    Jun 24, 2020
    Actually ı need answers of the same question. Anybody who tried this can answer this question
  5. waltervl
    2,224
    561
    Since the first question was asked the documentation has changed and something was added:
    You can use the SPI exposed by the EC using the EAPI libraries in your software
    Please checkout the EAPI link.
  6. Fazlı Faruk Okumuş
    Jun 24, 2020
    Acually ı need to control about all pins. I purely use this as a kind of mcu. For example, ı will change the PWM output at 100 Hz
  7. waltervl
    2,224
    561
  8. Maximo
    Maximo UDOOer
    Aug 11, 2017
    14
    As waltervl said you can control most of the CN25 pins with the EAPI libraries.
    Some I think will only work using their corresponding protocol functions: SPI, I2C1, I2C2, UART0, UART1
    The ones labeled as "KEYBOARD SCAN" (pin 13 to 28) can be used as general purpose IO pins.
    I didn't test the SPI, I2C, etc, but I made some simple tests with the KEYBOARD SCAN pins on linux and was able to read/write from them using the sample app provided in the EAPI package: https://www.udoo.org/docs-bolt/BIOS_UEFI_and_Tools/EAPI.html
    What I'm not sure (because I don't have experience) is if the timing control you can have on those pins on a full operating system like Linux is better than handling them directly with a MCU.
    But having the Arduino embedded on board maybe you can mix and let it be in charge of some specific functions where a MCU might be more appropriate for the task and let the CPU give them the orders through UART.
  9. ccs_hello
    452
    168
    EC, in my view, should be used with caution. It is part of the Core system, not an optional adjunct.
    If one did something (sorry about language) stupid, he's throwing few hundred dollar to the drain.
    On the other hand, Arduino is easy to use and even it's cooked, one can still use a few dollar external Arduino to do the work.
    Besides, Arduino device IO library is feature rich, you want PWM, just use a PWM library. That's all it takes.
    On EC side, one will have to use an external circuit, e.g., an I2C--PWM to do the work.
    I would also caution check first if there are already system devices on its SPI or I2C buses.
    (UART1 and UART2 are mapped to Core x86/AMD64's OS' Com1 and Com2 ports anyway.)
    P.S., I'd rather see Arduino related questions use a separate thread. This one is just for EC's external IO interface.
