Hi, I'm trying to setup similar to the tutorial video: Windows 8 with Arduino and ADK library. Following the links posted, I did download the ADK 2012 IDE(adk2012_ide-win32-20120629), and used the repo tool to get access to the ADK/board folders and pasted the ADK2 library from the board folder into Documents/Arduino/libraries, but I can't seem to use it: With the Google ADK 2012 IDE I can compile one of the library samples, although I get warnings: Code: c:/users/hm/downloads/adk2012_ide-win32-20120629/adk2012_ide/hardware/tools/g++_arm_none_eabi/bin/../lib/gcc/arm-none-eabi/4.4.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 4 bytes c:/users/hm/downloads/adk2012_ide-win32-20120629/adk2012_ide/hardware/tools/g++_arm_none_eabi/bin/../lib/gcc/arm-none-eabi/4.4.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 4 bytes c:/users/hm/downloads/adk2012_ide-win32-20120629/adk2012_ide/hardware/tools/g++_arm_none_eabi/bin/../lib/gcc/arm-none-eabi/4.4.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 4 bytes Binary sketch size: 86,268 bytes (of a 524,288 byte maximum) Also, I only see one board definition in the IDE: for the Google ADK 2 Compiling the UDOOArduinoADKDemo sketch gets me these errors: Code: UDOOArduinoADKDemo:16: error: 'USBHost' does not name a type UDOOArduinoADKDemo:17: error: 'Usb' was not declared in this scope UDOOArduinoADKDemo.cpp: In function 'void loop()': UDOOArduinoADKDemo:36: error: 'Usb' was not declared in this scope UDOOArduinoADKDemo:38: error: 'class ADK' has no member named 'isReady' UDOOArduinoADKDemo:39: error: 'class ADK' has no member named 'read' I've manually modified the ADK2012's boards.txt to add one for an Arduino Nano to test(by copying the definition from the Arduino 1.0.5 IDE), but I get these errors: Code: clock:-1: error: bad value (atmega328p) for -mcpu= switch arm-none-eabi-g++: {build.extra_flags}: No such file or directory I've also tried using the ADK2 library with the Arduino 1.0.5 but it looks like a bad idea: Code: In file included from C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/usb_drv.h:56, from C:\Users\HM\Documents\Arduino\libraries\ADK2\accessory.c:19: C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/compiler.h:238: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Status_bool_t' C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/compiler.h:239: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Status_t' C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/compiler.h:248: error: expected specifier-qualifier-list before 'S16' C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/compiler.h:257: error: expected specifier-qualifier-list before 'S32' C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/compiler.h:268: error: expected specifier-qualifier-list before 'S64' C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/compiler.h:281: error: expected specifier-qualifier-list before 'S64' C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/compiler.h:294: error: expected ':', ',', ';', '}' or '__attribute__' before '*' token C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/compiler.h:307: error: expected ':', ',', ';', '}' or '__attribute__' before '*' token C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/compiler.h:320: error: expected ':', ',', ';', '}' or '__attribute__' before '*' token C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/compiler.h:333: error: expected specifier-qualifier-list before 'S64' C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/compiler.h:346: error: expected ':', ',', ';', '}' or '__attribute__' before '*' token C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/compiler.h:359: error: expected ':', ',', ';', '}' or '__attribute__' before '*' token C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/compiler.h:372: error: expected ':', ',', ';', '}' or '__attribute__' before '*' token C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/compiler.h:1221: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Byte' In file included from C:\Users\HM\Documents\Arduino\libraries\ADK2\accessory.c:19: C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/usb_drv.h:60:18: error: chip.h: No such file or directory In file included from C:\Users\HM\Documents\Arduino\libraries\ADK2\accessory.c:19: C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/usb_drv.h:1592: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'host_set_p_txpacket' C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/usb_drv.h:1593: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'host_write_p_txpacket' C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/usb_drv.h:1594: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'host_read_p_rxpacket' In file included from C:\Users\HM\Documents\Arduino\libraries\ADK2\accessory.c:20: C:\Users\HM\Documents\Arduino\libraries\ADK2\utility/usb_ids.h:282: error: expected specifier-qualifier-list before 'U8' C:\Users\HM\Documents\Arduino\libraries\ADK2\accessory.c: In function 'accessory_init': C:\Users\HM\Documents\Arduino\libraries\ADK2\accessory.c:180: error: 'ID_SMC' undeclared (first use in this function) C:\Users\HM\Documents\Arduino\libraries\ADK2\accessory.c:180: error: (Each undeclared identifier is reported only once C:\Users\HM\Documents\Arduino\libraries\ADK2\accessory.c:180: error: for each function it appears in.) Update Here is the tree structure of the repo synced using the ADK instructions: Code: +---.repo | +---manifests | | \---.git | +---manifests.git | | +---hooks | | +---info | | +---logs | | | \---refs | | | \---remotes | | | +---m | | | \---origin | | +---objects | | | +---8b | | | +---9a | | | +---d6 | | | +---info | | | \---pack | | +---refs | | | +---heads | | | +---remotes | | | | \---m | | | \---tags | | +---rr-cache | | \---svn | +---project-objects | | +---device | | | \---google | | | \---accessory | | | +---adk2012.git | | | | +---hooks | | | | +---info | | | | +---objects | | | | | +---info | | | | | \---pack | | | | +---refs | | | | | +---heads | | | | | \---tags | | | | +---rr-cache | | | | \---svn | | | +---adk2012_demo.git | | | | +---hooks | | | | +---info | | | | +---objects | | | | | +---info | | | | | \---pack | | | | +---refs | | | | | +---heads | | | | | \---tags | | | | +---rr-cache | | | | \---svn | | | +---arduino.git | | | | +---hooks | | | | +---info | | | | +---objects | | | | | +---04 | | | | | +---22 | | | | | +---30 | | | | | +---45 | | | | | +---59 | | | | | +---6a | | | | | +---d1 | | | | | +---d4 | | | | | +---dd | | | | | +---e2 | | | | | +---info | | | | | \---pack | | | | +---refs | | | | | +---heads | | | | | \---tags | | | | +---rr-cache | | | | \---svn | | | \---demokit.git | | | +---hooks | | | +---info | | | +---objects | | | | +---03 | | | | +---3c | | | | +---49 | | | | +---96 | | | | +---9b | | | | +---a1 | | | | +---bd | | | | +---d7 | | | | +---e5 | | | | +---ed | | | | +---f4 | | | | +---info | | | | \---pack | | | +---refs | | | | +---heads | | | | \---tags | | | +---rr-cache | | | \---svn | | \---platform | | \---external | | +---arduino-ide.git | | | +---hooks | | | +---info | | | +---objects | | | | +---info | | | | \---pack | | | +---refs | | | | +---heads | | | | \---tags | | | +---rr-cache | | | \---svn | | \---codesourcery.git | | +---hooks | | +---info | | +---objects | | | +---info | | | \---pack | | +---refs | | | +---heads | | | \---tags | | +---rr-cache | | \---svn | +---projects | | +---adk1 | | | +---app.git | | | | +---logs | | | | | \---refs | | | | | \---remotes | | | | | +---aosp | | | | | \---m | | | | \---refs | | | | +---heads | | | | +---remotes | | | | | +---aosp | | | | | \---m | | | | \---tags | | | \---board.git | | | +---logs | | | | \---refs | | | | \---remotes | | | | +---aosp | | | | \---m | | | \---refs | | | +---heads | | | +---remotes | | | | +---aosp | | | | \---m | | | \---tags | | +---adk2012 | | | +---app.git | | | | +---logs | | | | | \---refs | | | | | \---remotes | | | | | +---aosp | | | | | \---m | | | | \---refs | | | | +---heads | | | | +---remotes | | | | | +---aosp | | | | | \---m | | | | \---tags | | | \---board.git | | | +---logs | | | | \---refs | | | | \---remotes | | | | +---aosp | | | | \---m | | | \---refs | | | +---heads | | | +---remotes | | | | +---aosp | | | | \---m | | | \---tags | | \---external | | +---ide.git | | | +---logs | | | | \---refs | | | | \---remotes | | | | +---aosp | | | | \---m | | | \---refs | | | +---heads | | | +---remotes | | | | +---aosp | | | | \---m | | | \---tags | | \---toolchain.git | | +---logs | | | \---refs | | | \---remotes | | | +---aosp | | | \---m | | \---refs | | +---heads | | +---remotes | | | +---aosp | | | \---m | | \---tags | \---repo | +---.git | | +---hooks | | +---info | | +---logs | | | \---refs | | | +---heads | | | \---remotes | | | \---origin | | +---objects | | | +---info | | | \---pack | | \---refs | | +---heads | | +---remotes | | | \---origin | | \---tags | +---docs | +---hooks | +---subcmds | \---tests | \---fixtures +---adk1 | +---app | | +---.git | | +---app | | | +---res | | | | +---drawable-hdpi | | | | +---drawable-mdpi | | | | +---drawable-nodpi | | | | +---drawable-xlarge-nodpi | | | | +---layout | | | | +---layout-xlarge-land | | | | +---values | | | | \---xml | | | \---src | | | \---com | | | \---google | | | \---android | | | \---DemoKit | | +---firmware | | | \---demokit | | \---hardware | | +---eng | | | +---m256c | | | \---shield | | \---fab | | +---m256c | | \---shield | \---board | +---.git | +---AndroidAccessory | \---USB_Host_Shield +---adk2012 | +---app | | +---.git | | +---res | | | +---drawable | | | +---drawable-hdpi | | | +---drawable-ldpi | | | +---drawable-mdpi | | | +---drawable-xhdpi | | | +---layout | | | +---menu | | | +---values | | | \---xml | | \---src | | \---com | | \---google | | \---android | | \---apps | | \---adk2 | | +---activity | | +---views | | \---widget | \---board | +---.git | +---hardware | +---library | | \---ADK2 | | +---examples | | | +---BluetoothScan | | | +---clock | | | \---usbaccessory | | \---utility | +---MakefileBasedBuild | | +---app | | \---Atmel | | \---sam3x | | \---sam3x-ek | | +---build | | | \---gcc | | \---libraries | | +---build | | | \---gcc | | +---libboard_sam3x-ek | | | +---board | | | +---build | | | | \---gcc | | | +---include | | | +---resources | | | | \---gcc | | | | +---sam3x2 | | | | +---sam3x4 | | | | \---sam3x8 | | | \---source | | +---libchip_sam3x | | | +---build | | | | \---gcc | | | +---cmsis | | | +---include | | | \---source | | +---libfatfs | | | +---build | | | | \---gcc | | | \---fatfs | | | +---doc | | | | +---en | | | | +---img | | | | \---ja | | | \---src | | | \---option | | +---liblwip | | | +---build | | | | \---gcc | | | \---sam3-specific | | | \---arch | | +---libqtouch | | | \---include | | +---libuip | | | \---sam3-specific | | +---memories | | | +---build | | | | \---gcc | | | +---include | | | +---nandflash | | | +---norflash | | | +---sdmmc | | | \---spi-flash | | +---usb_device | | | +---class | | | | +---audio | | | | | \---device | | | | | +---example | | | | | | \---atxmega128a1u_xplain_a1_mkii | | | | | \---module_config | | | | +---cdc | | | | | \---device | | | | | +---example | | | | | | +---at32uc3a0512_evk1100 | | | | | | +---atxmega128a1u_xplain_a1_mkii | | | | | | +---atxmega128b1_xmega_b1_xplained | | | | | | \---atxmega256a3bu_stk600-rc064x | | | | | \---module_config | | | | +---composite | | | | | \---device | | | | | +---example1 | | | | | | +---at32uc3a0512_evk1100 | | | | | | \---atxmega128a1u_xplain_a1_mkii | | | | | +---example2 | | | | | | +---atxmega128a1u_xplain_a1_mkii | | | | | | \---driver | | | | | \---module_config | | | | +---dfu | | | | | \---device | | | | | +---atmel | | | | | | +---isp | | | | | | | +---avr32 | | | | | | | | +---at32uc3a0_a1 | | | | | | | | | \---iar | | | | | | | | +---at32uc3c | | | | | | | | | +---iar | | | | | | | | | \---releases | | | | | | | | | +---at32uc3c-isp-1.1.0 | | | | | | | | | +---at32uc3c-isp-1.1.1 | | | | | | | | | \---at32uc3c-isp-1.1.2 | | | | | | | | \---at32uc3d | | | | | | | | +---iar | | | | | | | | \---releases | | | | | | | | +---at32uc3d-isp-1.1.0 | | | | | | | | | \---flip | | | | | | | | +---at32uc3d-isp-1.1.1 | | | | | | | | \---at32uc3d-isp-1.1.2 | | | | | | | \---xmega | | | | | | | +---atxmega128a1u | | | | | | | | +---iar | | | | | | | | \---releases | | | | | | | | \---atxmega128a1u-bootloader-usb-dfu-1.0.1 | | | | | | | +---atxmega128b1 | | | | | | | | +---iar | | | | | | | | \---releases | | | | | | | | \---atxmega128b1-bootloader-usb-dfu-1.0.1 | | | | | | | +---atxmega256a3bu | | | | | | | | \---iar | | | | | | | \---atxmega64a1u | | | | | | | \---iar | | | | | | \---module_config | | | | | \---standard | | | | +---hid | | | | | \---device | | | | | +---generic | | | | | | +---example | | | | | | | +---atxmega128a1u_xplain_a1_mkii | | | | | | | +---atxmega128b1_xmega_b1_xplained | | | | | | | \---atxmega256a3bu_stk600-rc064x | | | | | | \---module_config | | | | | +---kbd | | | | | | +---example | | | | | | | +---at32uc3b0256_evk1101 | | | | | | | +---atxmega128a1u_xplain_a1_mkii | | | | | | | \---atxmega128b1_xmega_b1_xplained | | | | | | \---module_config | | | | | \---mouse | | | | | +---example | | | | | | +---at32uc3a0512_evk1100 | | | | | | +---at32uc3a0512_evk1105 | | | | | | +---at32uc3a3256_evk1104 | | | | | | +---at32uc3b0256_evk1101 | | | | | | +---at32uc3c0512_uc3c_ek | | | | | | +---at32uc3c2512c_uc3_c2_xplained | | | | | | +---atuc128d3_evk1101 | | | | | | | \---gcc | | | | | | +---atuc256l3_stk600_rcuc3l3_l4 | | | | | | +---atxmega128a1u_xplain_a1_mkii | | | | | | +---atxmega128b1_xmega_b1_xplained | | | | | | +---atxmega256a3bu_stk600-rc064x | | | | | | +---mxt768e_stk600-rcmxt768e | | | | | | \---zephyr | | | | | | \---iar | | | | | \---module_config | | | | +---msc | | | | | \---device | | | | | +---example | | | | | | +---at32uc3a0512_evk1100 | | | | | | +---at32uc3a0512_evk1105 | | | | | | +---at32uc3a3256_evk1104 | | | | | | +---at32uc3b0256_evk1101 | | | | | | +---at32uc3c0512_uc3c_ek | | | | | | +---atxmega128a1u_xplain_a1_mkii | | | | | | +---atxmega128a1_stk600-rc100x | | | | | | \---atxmega256a3bu_stk600-rc064x | | | | | \---module_config | | | | \---phdc | | | | +---device | | | | | +---example | | | | | | +---atxmega128a1u_xplain_a1_mkii | | | | | | \---atxmega256a3bu_stk600-rc064x | | | | | \---module_config | | | | \---ieee11073-personal_health_devices | | | +---drivers | | | | +---usbb | | | | \---usbc | | | +---memory | | | | +---media_mem | | | | +---nandflash | | | | +---sdmmc | | | | | \---sdmmc_mci | | | | \---virtual_mem | | | +---udc | | | \---utils | | | +---fifo | | | | \---enhc_fifo | | | \---storage | | | \---ctrl_access | | \---usb_host | | +---class | | | +---hid | | | | \---host_hid | | | \---mass_storage | | | \---scsi_decoder | | +---enum | | | +---device | | | \---host | | \---example_enum | | \---enum | | \---device | \---tools | +---adk2inst | +---adk2tool | \---bossac \---external +---ide | +---.git | +---.settings | +---app | | +---.settings | | +---lib | | \---src | | \---processing | | \---app | | +---debug | | +---helpers | | | \---filefilters | | +---linux | | +---macosx | | +---preproc | | +---syntax | | | \---im | | +---tools | | | \---format | | | +---src | | | \---tool | | \---windows | +---build | | +---cmd | | | \---dist | | +---javadoc | | | +---core | | | | +---processing | | | | | +---core | | | | | \---xml | | | | \---resources | | | \---everything | | | +---antlr | | | | \---java | | | +---processing | | | | +---app | | | | | +---debug | | | | | +---linux | | | | | +---macosx | | | | | +---preproc | | | | | +---syntax | | | | | +---tools | | | | | \---windows | | | | +---candy | | | | +---core | | | | +---dxf | | | | +---net | | | | +---opengl | | | | +---pdf | | | | +---serial | | | | +---video | | | | \---xml | | | \---resources | | +---linux | | | \---dist | | | +---lib | | | \---tools | | +---macosx | | | +---dist | | | \---template.app | | | \---Contents | | | +---MacOS | | | \---Resources | | | \---Java | | +---shared | | | +---examples | | | | +---01.Basics | | | | | +---AnalogReadSerial | | | | | +---BareMinimum | | | | | +---Blink | | | | | +---DigitalReadSerial | | | | | +---Fade | | | | | \---ReadAnalogVoltage | | | | +---02.Digital | | | | | +---BlinkWithoutDelay | | | | | +---Button | | | | | +---Debounce | | | | | +---DigitalIputPullup | | | | | +---StateChangeDetection | | | | | +---toneKeyboard | | | | | +---toneMelody | | | | | +---toneMultiple | | | | | \---tonePitchFollower | | | | +---03.Analog | | | | | +---AnalogInOutSerial | | | | | +---AnalogInput | | | | | +---AnalogWriteMega | | | | | +---Calibration | | | | | +---Fading | | | | | \---Smoothing | | | | +---04.Communication | | | | | +---ASCIITable | | | | | +---Dimmer | | | | | +---Graph | | | | | +---MIDI | | | | | +---MultiSerialMega | | | | | +---PhysicalPixel | | | | | +---ReadASCIIString | | | | | +---SerialCallResponse | | | | | +---SerialCallResponseASCII | | | | | +---SerialEvent | | | | | \---VirtualColorMixer | | | | +---05.Control | | | | | +---Arrays | | | | | +---ForLoopIteration | | | | | +---IfStatementConditional | | | | | +---switchCase | | | | | +---switchCase2 | | | | | \---WhileStatementConditional | | | | +---06.Sensors | | | | | +---ADXL3xx | | | | | +---Knock | | | | | +---Memsic2125 | | | | | \---Ping | | | | +---07.Display | | | | | +---barGraph | | | | | \---RowColumnScanning | | | | +---08.Strings | | | | | +---CharacterAnalysis | | | | | +---StringAdditionOperator | | | | | +---StringAppendOperator | | | | | +---StringCaseChanges | | | | | +---StringCharacters | | | | | +---StringComparisonOperators | | | | | +---StringConstructors | | | | | +---StringIndexOf | | | | | +---StringLength | | | | | +---StringLengthTrim | | | | | +---StringReplace | | | | | +---StringStartsWithEndsWith | | | | | +---StringSubstring | | | | | +---StringToInt | | | | | \---StringToIntRGB | | | | +---09.USB(Leonardo) | | | | | +---Keyboard | | | | | | +---KeyboardLogout | | | | | | +---KeyboardMessage | | | | | | +---KeyboardReprogram | | | | | | \---KeyboardSerial | | | | | +---KeyboardAndMouseControl | | | | | \---Mouse | | | | | +---ButtonMouseControl | | | | | \---JoystickMouseControl | | | | \---ArduinoISP | | | +---lib | | | | \---theme | | | \---tools | | | \---Mangler | | | \---src | | \---windows | | +---dist | | | \---drivers | | | \---FTDI USB Drivers | | | +---amd64 | | | +---i386 | | | \---Static | | | +---amd64 | | | \---i386 | | \---launcher | | \---launch4j | | +---.settings | | +---bin | | +---demo | | | +---ConsoleApp | | | | +---l4j | | | | +---lib | | | | \---src | | | | \---net | | | | \---sf | | | | \---launch4j | | | | \---example | | | \---SimpleApp | | | +---l4j | | | +---lib | | | \---src | | | \---net | | | \---sf | | | \---launch4j | | | \---example | | +---head | | +---head_src | | | +---consolehead | | | \---guihead | | +---lib | | +---manifest | | +---src | | | +---images | | | \---net | | | \---sf | | | \---launch4j | | | +---ant | | | +---binding | | | +---config | | | +---form | | | \---formimpl | | +---w32api | | \---web | +---core | | +---.settings | | +---methods | | | +---demo | | | \---src | | +---preproc | | | +---demo | | | \---src | | | \---processing | | | \---build | | \---src | | \---processing | | +---core | | \---xml | +---hardware | | +---arduino | | | \---sam | | | +---bootloaders | | | | \---sam3_samba | | | | \---linker_script | | | +---cores | | | | \---arduino | | | | +---build_gcc | | | | +---build_iar | | | | +---prod_test_due | | | | | +---build_gcc | | | | | \---build_iar | | | | +---USB | | | | +---validation | | | | | +---build_gcc | | | | | \---build_iar | | | | \---validation_usb_device | | | | \---build_gcc | | | +---libraries | | | | +---SPI | | | | | \---examples | | | | | +---BarometricPressureSensor | | | | | +---DigitalPotControl | | | | | \---DueX_ATFlashSignatureCheck | | | | \---Wire | | | | \---examples | | | | +---digital_potentiometer | | | | +---master_reader | | | | +---master_writer | | | | +---SFRRanger_reader | | | | +---slave_receiver | | | | \---slave_sender | | | +---system | | | | +---AndroidAccessory | | | | | \---examples | | | | | +---_01_digitalRead_adk | | | | | +---_02_digitalWrite_adk | | | | | +---_03_analogRead_adk | | | | | +---_04_analogWrite_adk | | | | | \---_05_test_adk | | | | +---CMSIS | | | | | +---CMSIS | | | | | | +---Documentation | | | | | | | \---DSP_Lib | | | | | | | \---html | | | | | | | \---search | | | | | | +---DSP_Lib | | | | | | | +---Examples | | | | | | | | +---arm_class_marks_example | | | | | | | | | +---ARM | | | | | | | | | \---GCC | | | | | | | | +---arm_convolution_example | | | | | | | | | +---ARM | | | | | | | | | \---GCC | | | | | | | | +---arm_dotproduct_example | | | | | | | | | \---ARM | | | | | | | | +---arm_fft_bin_example | | | | | | | | | \---ARM | | | | | | | | +---arm_fir_example | | | | | | | | | \---ARM | | | | | | | | +---arm_graphic_equalizer_example | | | | | | | | | \---ARM | | | | | | | | +---arm_linear_interp_example | | | | | | | | | \---ARM | | | | | | | | +---arm_matrix_example | | | | | | | | | \---ARM | | | | | | | | +---arm_signal_converge_example | | | | | | | | | \---ARM | | | | | | | | +---arm_sin_cos_example | | | | | | | | | \---ARM | | | | | | | | +---arm_variance_example | | | | | | | | | \---ARM | | | | | | | | \---Common | | | | | | | | +---Include | | | | | | | | \---Source | | | | | | | \---Source | | | | | | | +---ARM | | | | | | | +---BasicMathFunctions | | | | | | | +---CommonTables | | | | | | | +---ComplexMathFunctions | | | | | | | +---ControllerFunctions | | | | | | | +---FastMathFunctions | | | | | | | +---FilteringFunctions | | | | | | | +---GCC | | | | | | | +---iar | | | | | | | +---MatrixFunctions | | | | | | | +---StatisticsFunctions | | | | | | | +---SupportFunctions | | | | | | | \---TransformFunctions | | | | | | +---Include | | | | | | \---Lib | | | | | | +---ARM | | | | | | \---GCC | | | | | +---Device | | | | | | +---ARM | | | | | | | +---ARMCM0 | | | | | | | | +---Include | | | | | | | | \---Source | | | | | | | | \---Templates | | | | | | | | +---ARM | | | | | | | | +---GCC | | | | | | | | +---GCC_ARM | | | | | | | | \---IAR | | | | | | | +---ARMCM3 | | | | | | | | +---Include | | | | | | | | \---Source | | | | | | | | \---Templates | | | | | | | | +---ARM | | | | | | | | +---GCC | | | | | | | | +---GCC_ARM | | | | | | | | \---IAR | | | | | | | \---ARMCM4 | | | | | | | +---Include | | | | | | | \---Source | | | | | | | \---Templates | | | | | | | +---ARM | | | | | | | +---GCC | | | | | | | +---GCC_ARM | | | | | | | \---IAR | | | | | | +---ATMEL | | | | | | | +---sam3n | | | | | | | | +---html | | | | | | | | | +---css | | | | | | | | | \---images | | | | | | | | +---include | | | | | | | | | +---component | | | | | | | | | +---instance | | | | | | | | | \---pio | | | | | | | | +---source | | | | | | | | | +---as_gcc | | | | | | | | | +---gcc | | | | | | | | | +---gcc_arm | | | | | | | | | +---gcc_atmel | | | | | | | | | \---iar | | | | | | | | \---svd | | | | | | | +---sam3s | | | | | | | | +---html | | | | | | | | | +---css | | | | | | | | | \---images | | | | | | | | +---include | | | | | | | | | +---component | | | | | | | | | +---instance | | | | | | | | | \---pio | | | | | | | | +---source | | | | | | | | | +---as_gcc | | | | | | | | | +---gcc | | | | | | | | | +---gcc_arm | | | | | | | | | +---gcc_atmel | | | | | | | | | \---iar | | | | | | | | \---svd | | | | | | | +---sam3sd8 | | | | | | | | +---html | | | | | | | | | +---css | | | | | | | | | \---images | | | | | | | | +---include | | | | | | | | | +---component | | | | | | | | | +---instance | | | | | | | | | \---pio | | | | | | | | +---source | | | | | | | | | +---as_gcc | | | | | | | | | +---gcc | | | | | | | | | +---gcc_arm | | | | | | | | | +---gcc_atmel | | | | | | | | | \---iar | | | | | | | | \---svd | | | | | | | +---sam3u | | | | | | | | +---html | | | | | | | | | +---css | | | | | | | | | \---images | | | | | | | | +---include | | | | | | | | | +---component | | | | | | | | | +---instance | | | | | | | | | \---pio | | | | | | | | +---source | | | | | | | | | +---as_gcc | | | | | | | | | +---gcc | | | | | | | | | +---gcc_arm | | | | | | | | | +---gcc_atmel | | | | | | | | | \---iar | | | | | | | | \---svd | | | | | | | +---sam3xa | | | | | | | | +---html | | | | | | | | | +---css | | | | | | | | | \---images | | | | | | | | +---include | | | | | | | | | +---component | | | | | | | | | +---instance | | | | | | | | | \---pio | | | | | | | | +---source | | | | | | | | | +---as_gcc | | | | | | | | | +---gcc | | | | | | | | | +---gcc_arm | | | | | | | | | +---gcc_atmel | | | | | | | | | \---iar | | | | | | | | \---svd | | | | | | | \---sam4s | | | | | | | +---html | | | | | | | | +---css | | | | | | | | \---images | | | | | | | +---include | | | | | | | | +---component | | | | | | | | +---instance | | | | | | | | \---pio | | | | | | | +---source | | | | | | | | +---as_gcc | | | | | | | | +---gcc | | | | | | | | +---gcc_arm | | | | | | | | +---gcc_atmel | | | | | | | | \---iar | | | | | | | \---svd | | | | | | \---_Template_Vendor | | | | | | \---Vendor | | | | | | \---Device | | | | | | +---Include | | | | | | \---Source | | | | | | \---Templates | | | | | | \---ARM | | | | | \---Examples | | | | | \---cmsis_example | | | | | +---gcc | | | | | +---gcc_arm | | | | | \---gcc_atmel | | | | +---libsam | | | | | +---build_gcc | | | | | +---build_iar | | | | | +---include | | | | | \---source | | | | \---USBHost | | | | \---examples | | | | +---board_test | | | | +---conf_descr_dump | | | | \---descriptor_parser | | | \---variants | | | \---adk2 | | | +---build_gcc | | | +---debug_scripts | | | | \---gcc | | | \---linker_scripts | | | +---gcc | | | \---iar | | \---tools | \---libraries | \---Ethernet | \---examples | +---CosmClient | +---CosmClientString | \---WebClientRepeating \---toolchain +---.git \---arm-2010q1-188-arm-none-eabi Also, in the adk1 folder I've found two more libraries: AndroidAccessory and USB_Host_Shield. Tried to compiled the UDOO example again, this time making these changes: Code: #include <adk.h> to #include <ADK.h> added #include <UsbHost.h> changed USBHost Usb; to UsbHost Usb; but still get errors: Code: In file included from C:\Users\HM\Documents\Arduino\libraries\UsbHost/Max3421e.h:10, from C:\Users\HM\Documents\Arduino\libraries\UsbHost/UsbHost.h:6, from UDOOArduinoADKDemo.cpp:4: C:\Users\HM\Documents\Arduino\libraries\UsbHost/Max3421e_constants.h:29: error: #error The currently selected board needs to have its SPI pin definitions added to this file. In file included from C:\Users\HM\Documents\Arduino\libraries\UsbHost/UsbHost.h:6, from UDOOArduinoADKDemo.cpp:4: C:\Users\HM\Documents\Arduino\libraries\UsbHost/Max3421e.h: In static member function 'static void MAX3421E::spi_init()': C:\Users\HM\Documents\Arduino\libraries\UsbHost/Max3421e.h:35: error: 'SCK_PIN' was not declared in this scope C:\Users\HM\Documents\Arduino\libraries\UsbHost/Max3421e.h:36: error: 'MOSI_PIN' was not declared in this scope C:\Users\HM\Documents\Arduino\libraries\UsbHost/Max3421e.h:37: error: 'MISO_PIN' was not declared in this scope C:\Users\HM\Documents\Arduino\libraries\UsbHost/Max3421e.h:38: error: 'SS_PIN' was not declared in this scope C:\Users\HM\Documents\Arduino\libraries\UsbHost/Max3421e.h:41: error: 'SPCR' was not declared in this scope C:\Users\HM\Documents\Arduino\libraries\UsbHost/Max3421e.h:42: error: 'SPSR' was not declared in this scope C:\Users\HM\Documents\Arduino\libraries\UsbHost/Max3421e.h:45: error: 'SPDR' was not declared in this scope UDOOArduinoADKDemo.cpp: At global scope: UDOOArduinoADKDemo:18: error: no matching function for call to 'ADK::ADK(UsbHost*, char [8], char [9], char [19], char [4], char [20], char [2])' C:\Users\HM\Documents\Arduino\libraries\ADK2/ADK.h:99: note: candidates are: ADK::ADK() C:\Users\HM\Documents\Arduino\libraries\ADK2/ADK.h:99: note: ADK::ADK(const ADK&) UDOOArduinoADKDemo.cpp: In function 'void loop()': UDOOArduinoADKDemo:39: error: 'class ADK' has no member named 'isReady' UDOOArduinoADKDemo:40: error: 'class ADK' has no member named 'read' This is using the Google ADK2 board definition in the ADK 2012 IDE. I think I'm not using the right IDE and especially not the right version of the libraries. So...what's your setup guys ? How did you managed to get this up and running ? Can you use the ADK library working with the typical Arduino IDE and any Arduino board ? If so, how ? Any tips/hints appreciated. Thanks!
Re: Error compiling Arduino code for "Simple Hello World" le I just got my udoo board and get the exact same problem. Could someone give us some hint?
Re: Error compiling Arduino code for "Simple Hello World" le Got it to work... If some one else is having this problem, the way I fixed it was to download the latest nightly Arduino code. Patch it with Bossac fix, then the hello program compiled and loaded successfully onto the arduino board.
