External Arduino IDE "Error : Connect Failed"
Discussion in 'UDOO NEO' started by Maurice, Apr 13, 2016.
  1. Maurice
    Maurice Active Member
    Oct 13, 2015
    394
    87
    Both on Windows and Ubuntu I get the following error when I try to upload a program to Arduino via USB:"Error : Connect Failed". I have manually selected /dev/ttyACM0, my account is part of the dailout group.
    If I show the serial monitor I see a login sequence that normally you'd get when ssh-ing:
    Login timed out after 60 seconds.
    UDOObuntu v2.0rc2
    default username: password is [udooer:udooer]
    eskarina login:
  2. ektor5
    Jul 1, 2013
    97
    48
    The uploading method for NEO don't use the USB UART, but the TCP/IP connection provided by the virtualized ethernet via USB.
    So you don't need to select any tty in particular, it'll be automatically ignored. The ttyACM0 is connected to the A9 processor only.
    Instead, check if:
    • your PC is connected to the virtual network with the 192.168.7.1 IP address
    • the address 192.168.7.2 (UDOO NEO) is reachable (open a terminal and ping that)
    Hope this helps,
    Ek5
  3. Philipwu
    Philipwu New Member
    Jan 19, 2016
  4. Philipwu
    Philipwu New Member
    Jan 19, 2016
    I think I have fixed it. I have missed one step "Install Udoo FOTA" in the tutorial.:p
  5. Maurice
    Oct 13, 2015
    394
    87
    I was able to upload the empty 'default' program, so it seems to be working. Can't show the serial though, would like that too. In order to use both the Udoo Neo network and Internet at the same time I had to tweak some network connections though.
  6. BanjoIsland
    BanjoIsland New Member
    May 7, 2016
    Hey guys,
    I'm getting the same Error : Connect Failed message. Anybody got this to work?
    Where do you see this install Udoo FOTA information? I don't see it in the link
  7. waltervl
    I suppose Udoo fota is now preinstalled on udoobuntu 2 rc2 so the instructions have changed.
    BanjoIsland likes this.
  8. waltervl
    Do you use arduino IDE 1.6.5 on your pc?
  9. BanjoIsland
    May 7, 2016
    yes, I'm trying to connect to it using it on my win7 pc. Ok, guess I should just install udoobuntu 2 rc2 now. Was trying to avoid that for a while since I already did a whole bunch of setup stuff on the older udoobuntu version that I'd rather not repeat.
  10. waltervl
  11. BanjoIsland
    May 7, 2016
    yup, installing 2 rc2 fixed this problem. Thanks!
    Andrea Rovai and waltervl like this.
