Fading LED example resets UDOO board
Discussion in 'Arduino IDE' started by Chris Morris, Aug 3, 2018.
Tags:
  1. Chris Morris
    Chris Morris New Member
    Jul 24, 2018
    Hello!
    First off, I'm a software engineer. I don't do hardware! As you can see, I can't even fade a LED...
    I am trying to run the "Fading" example project as provided by the Arduino IDE, https://www.arduino.cc/en/Tutorial/Fading
    Using the UDOO documentation showing the Arduino pin out, https://www.udoo.org/docs-x86/Arduino_101_(Intel_Curie)/Pinout.html, I connect my LED & resistor between pins identified as GND and PWM9 in the PWM section as shown on the UDOO pin out diagram. As soon as I make the connection, the entire module (including the x86) resets. I guess that I shouldn't make that connection and I should stick to software!
    If I make the LED connection between GND and LED as identified on the UDOO image, I can control the LED using the digitalWrite function without any problem.
    My question is, the pin-out shown in the UDOO documentation:
    [​IMG]
    is different to the pin out shown in the Fading guide on the Arduino site:
    [​IMG]
    Are the UDOO pins supposed to be the same as the Arduino pins? Have I missed some UDOO documentation somewhere which says "UDOO pins are the same as Arduino pins except for the following..."?
    Regards,
    Chris
  3. Chris Morris
    Jul 24, 2018
    Hi waltervl,
    Disabling the Curie Power Management in the BIOS as described in the link you posted fixed my problem.
    Thank you.
