Fan unit not always activated when temperature raising
Discussion in 'UDOO BOLT' started by marc.d, Aug 12, 2019.
  1. nophead
    nophead UDOOer
    Aug 18, 2015
    87
    14
    When it does spin is it quite noisy and powerfull? Needing to be started manually would imply one coil is not working or it is a 12V fan on 5V. The latter would spin quite slowly.
  2. Karsteb
    Karsteb New Member
    Aug 23, 2019
    I have the same problem. Udoo Bolt V8 Fan under Ubuntu doesn't start while temperature raising. Have to start it manually.
  3. evaloverde
    Apr 29, 2019
    236
    59
    Ciao @Karsteb , please open a ticket regarding this issue. If you could also share whether you see a green dot beside the vent. This would help identify the lot number.
  4. Karsteb
    Karsteb New Member
    Aug 23, 2019
    I have a green dot beside the vent.
  5. Yiks
    Yiks UDOOer
    May 12, 2017
    Idling with only chrome browser and CoreTemp running. Chorme browser on udoo forums. Have uploaded the temp log. Saw temp go up to 114 degCelcius. Tried to open file explorer and it just shutdown.
    I'll raise a ticket. with others chiming in. Definitely an issue.
  6. Yiks
    Yiks UDOOer
    May 12, 2017
    Opened ticket #501378
  7. KraftSaft
    KraftSaft New Member
    Aug 6, 2019
    Opened ticket #789479
  8. marc.d
    marc.d UDOOer
    Aug 10, 2019
    13
    Saturday morning I wanted to find out if the Udoo provided dock with ethernet and 3 usb ports would become active when connecting the dock while the bolt is in a cold state, and then powering on, booting into Linux.
    I did not get that far though, because after only a few minutes I noticed a burning smell so I quickly powered of the bold. The fan was not spinning at that point in time, so it probably is the temperature issue again. The only devices connected were a unifying receiver, an HDMI monitor, and the 'dock' connected to one of the usb-c ports.
    I removed the fan and the heatsink. To my surprise the heatsink came loose very easily, and at the same time I noticed the surface with the thermal paste was dry and hard. I'm not sure this is normal, but in any case, I cleaned the surfaces of the processor and the heatsink using isopropyl alcohol. I ordered an alternative fan unit via amazon, and I will only provide power to the board again once I have it reassembled with the alternative fan unit installed. I hope I removed power quickly enough so that the processor did not get damaged, but I can understand a unit fails after overheating issues, although i don't really understand where that smell came from.
    So again, this seems to be the temperature issue raised before by multiple people. Does raising another ticket for this issue add more weight to this issue? If it does, I also will raise a ticket.
    I'll keep you guys posted, but it might take a while before receiving the alternative fan unit.
    Cheers,
    Marc
  9. evaloverde
    Apr 29, 2019
    236
    59
    Ciao Marc! Yes, opening a ticket is the best course of action. We keep track of the problem(s) raised in every ticket. So having 5 tickets or 30 tickets on an issue helps us to see what we should focus on.
    Share whether you see a green dot on the side of the fan, your OS and any other information that might be relevant please.
  10. KraftSaft
    Aug 6, 2019
    On mine there is a green dot on the side of the fan.
    Also my post are all held back till moderation. Could i be switched to the UDOOer Forumsgroup?
  11. Yetii
    Yetii New Member
    Aug 27, 2019
    I too have a green dot on the side of my fan unit, and have created a ticket. Looking forward to finding a resolution for this :)
  12. evaloverde
    Apr 29, 2019
    236
    59
    Thank you, guys. It truly helps us figure out what the issue is. At the moment we've stopped shipping because of this
  13. Yiks
    Yiks UDOOer
    May 12, 2017
    Green dot on fan near heat sink vents as well.
  14. marc.d
    marc.d UDOOer
    Aug 10, 2019
    13
    No green dot in my case.
    But can someone say what the meaning of that green dot is?
  15. evaloverde
    Apr 29, 2019
    236
    59
    It's a way for us to recognize the vent's lot.
  16. sirrab
    sirrab UDOOer
    Jul 26, 2014
    263
    32
    And what does that mean?
  17. Yetii
    Yetii New Member
    Aug 27, 2019
    Things are usually manufactured in batches for various reasons, in this case it allows the folks at UDOO to determine if the issue lies with the fan unit itself if for example a lot of fans from one batch/lot are having issues then you can assume it was a faulty lot and act accordingly. From marc.d's recent post it looks like it is unlikely to be a bad fan lot, which means they can focus on looking at other possible reasons for the fan issue.
  18. marc.d
    marc.d UDOOer
    Aug 10, 2019
    13
    Oh, I was looking to the side of the fan on the motherboard, not to the side of the fan itself, that's a misunderstanding from my side. Sorry about the confusion, because indeed there is a green dot ... blush
    Marc
  19. nophead
    nophead UDOOer
    Aug 18, 2015
    87
    14
    I have a green dot but my fan works fine.
  20. Yiks
    Yiks UDOOer
    May 12, 2017
    Been monitoring the Fan on and off temps. Typically it switches off around 36.5 degCelcius and switches on around 43.5 degCelcius.
    When it goes above 43.5 degCelcius and the fan doesn't spin. Noticed the fan twitching as though attempting to spin.
    Either fan mechanically a problem or power to the fan is inadequate.
