Fan unit not always activated when temperature raising
Discussion in 'UDOO BOLT' started by marc.d, Aug 12, 2019.
  1. Yiks
    Yiks UDOOer
    May 12, 2017
    additionally overheat normally occurs when idle in win10. Opening a page with activity. eg goldprice.org seems to avoid the overheat. Sure seems like when idle some low power mode kicks in causing low power delivered to the fan as well. Guessing at this moment. will test it out to confirm.
  2. Yetii
    Yetii New Member
    Aug 27, 2019
    I seem to have resolved the issue! No fan issues for 3 days now, below is text I added to my ticket but figured people may find it useful.
    I'm sure if anyone else with the issue is willing to confirm or unconfirm my hypothesis (and add pictures!) it would be a great help in getting this issue resolved.
  3. nophead
    nophead UDOOer
    Aug 18, 2015
    86
    13
    Was the stray loop from the coil near the driver chip? Brushless fan drivers usually have a Hall effect sensor to magnetically sense the position of the rotor. If there was a loop of wire near the sensor it might confuse it.
  4. Yiks
    Yiks UDOOer
    May 12, 2017
    Ok. so much for the guessing. Anyway it's highly likely the fan hardware. When fan failed to spin. I shutdown system. Waited a day making sure I don't bump the machine. Started it up. And the fan wouldnt turn on. I see the twitching. So likely have to take fan apart as in previous two posts. Likely when fan stops in certain positions it may never spin again without help.
  5. Yetii
    Yetii New Member
    Aug 27, 2019
    It's possible, it was on the on the inside end of the coil and I did notice that on that particular coil I saw 4 wires coming out rather than the 2 I would have expected to see on a coil.
  6. KraftSaft
    KraftSaft New Member
    Aug 6, 2019
    I have got a response from the Ticket i opened. They will send me a replacement Fan. I hope that its just a faulty fan. That shopuld be easy to replace.
    If that is the case i may change the fan to one from Noctua or not if it is not to loud.
  7. David Beauchamp
    David Beauchamp New Member
    Sep 2, 2019
    Marc,
    What fan did you end up getting? I broke a blade on mine last night.
  8. marc.d
    marc.d UDOOer
    Aug 10, 2019
    13
    David,
    I ordered an Acoustifan 6025, that is whisper quiet and works out fine at 5V, although not at it's full potential speed (which it gets when power supply is 12V). This gives me temperatures between about 39 (idle) to 65 (full load) degrees Celcius. This comes with the drawback that it's height is about double the height of the original Cofan fan-unit, so it won't fit the case if you have one.
    If you open a ticket for the temperature/fun-unit issue, then udoo is willing to send you a replacement fan-unit.
    Good luck,
    Marc
  9. David Beauchamp
    Sep 2, 2019
    Thanks Marc,
    I have the case so that won't work out so well for me. I did DM Eva asking to purchase a replacement because it was totally my fault the blade broke. I also reached out to COFAN regarding the part, they have the v. 2 of the fan listed on their site but not the v. 4 that was installed on the Bolt. But they look like they are set up for business to business transactions not retail.
  10. Xeyrruken
    Xeyrruken UDOOer
    Jun 6, 2019
    37
    Hey did any of you have received word from udoo customer care regarding the fan, they ask me some info and told me the following:
    we apologize for the inconvenience.
    A new fan will be shipped as soon as possible, we are arranging shipments at our expenses to all backers who have received a defective one and doing our best to speed up the process.
    We will email you the tracking number as soon as assigned.
    That was more than a month ago.
  11. Herbert Hotz
    Herbert Hotz UDOOer
    Jul 9, 2017
    10
    Hi Xeyrruken,
    I had the same issue and opened a ticket like you did and I got the same response.
    After about 2 weeks after I opened the ticket, I've got a replacement fan (same type, same manufacturer) which did not have the reported problem. Keep waiting - they will send you one! ;)
    Best regards,
    Herbert
    Xeyrruken likes this.
  12. Xeyrruken
    Xeyrruken UDOOer
    Jun 6, 2019
    37
    Lets, it has been a Month since they wrote to me that, and two weeks since I Order the case, they have told me that there are problems with shipping logistics or something like that. @evaloverde any updates regarding the shipping issue?
  13. Alan Wong
    Alan Wong New Member
    Aug 17, 2019
    It took a bit longer than I thought it would but I did get the replacement fan and power cord (separate issue) and everything seems to be fine now.
    evaloverde likes this.
  14. OlivierP
    OlivierP UDOOer
    Mar 15, 2020
    yep same here - green dot. I will open a ticket...
    evaloverde and waltervl like this.
  15. waltervl
    2,306
    578
