Hi im trying to use GPIO42 i set on mode OUT and a HIGH Value if i put a led on these port nothing happend but if i do on GPIO47 works OK and the led turn on Btw im using the I.mx6 procesor any idea of why its not working?
Hi there Zer0Byte, is there an Arduino sketch that is using this pin? Because is set LOW by Arduino. In case the answer is yes, try putting it in input on the Arduino side.
