GPIO From Apache/PHP web server
Discussion in 'UDOO NEO' started by dlevans, Jan 5, 2018.
  1. dlevans
    dlevans New Member
    Jan 5, 2018
    Hey, guys! I'm finally getting around to using my Udoo Neo I got way back from the Kickstarter for my R2-D2 project. I'm going to try and use the Udoo to drive the sound and control the servos to make things open/close on R2.
    Here's how I got the AP setup:
    https://www.udoo.org/docs-neo/Wireless_Communication/WiFi_SoftAP.html
    Here's how I'm running the web server:
    https://www.udoo.org/tutorial/udoo-web-server/
    I've got everything working but can't figure out how to send commands to the GPIO / Arduino. In order to play audio on the Udoo (and not my phone) I'm using the PHP command "exec" to play an MP3. Ideally, I would like to do something similar to control the GPIO or to call an Arduino function.
    I found this guide but it uses Python and I'd like to avoid that if at all possible.
    https://www.udoo.org/forum/threads/how-to-control-neo-arduino-from-web-page.6242/
  3. dlevans
    dlevans New Member
    Jan 5, 2018
    I'll check it out. Thanks!
  4. dlevans
    dlevans New Member
    Jan 5, 2018
    Alright, I think I finally found the right files (the help site you sent me to says to upload an Arduino sketch but there's no mention of what sketch or how to find it).
    I found this:
    https://github.com/UDOOboard/serial_libraries_examples
    Uploaded this sketch:
    https://github.com/UDOOboard/serial...ino_serial_example/arduino_serial_example.ino
    Then I cloned the GitHub repo onto my Udoo Neo and did this:
    sudo ln -s /dev/ttyMCC /dev/ttyS0
    udooer@R2-D2:~$ cd serial_libraries_examples/
    udooer@R2-D2:~/serial_libraries_examples$ cd php
    udooer@R2-D2:~/serial_libraries_examples/php$ php -S 0.0.0.0:8081
    I was only able to get the example to work by running that php command with sudo. I'm running another web server on port 8080. Is there a way to add this php example to that existing port without running it as sudo?
  5. waltervl
    Sorry I had to link you to 1 level higher page of the documentation: https://www.udoo.org/docs-neo/Serial_Libraries/index.html
    Regarding sudo en webserver, you are the PHP expert of us both :) But I suspect you have to merge the code of the communication example into your existing PHP site.
    Using sudo is normally because something has to be done where a user has no rights to. You could make a user group with the right permissions and add the user to that group.
  6. dlevans
    dlevans New Member
    Jan 5, 2018
    I finally figured it out. For some reason I had to change define("PORT","/dev/ttyS0"); in the serial_libraries_examples/php/index.php file to define("PORT","/dev/ttyMCC"); and it worked!
    Thanks again for all your help. This project is moving along nicely.
