GPIO on UDOObuntu 2.0 Beta 2
Discussion in 'Linux Ubuntu' started by psaitz, Oct 15, 2015.
  1. psaitz
    psaitz New Member
    Oct 22, 2013
  2. Andrea Rovai
    Dear psaitz,
    in the previous version those folder were exposed. The command to have those folder exposed is:
    where XX is a number related to the GPIO that can take from this image (check the number on the white label)
    http://udoo.org/download/files/pinout/Udoo_pinout_diagram.pdf
  3. psaitz
    psaitz New Member
    Oct 22, 2013
    Thanks Andrea, echo XXX > export works fine.
    But after a reboot, the exported gpioXXX directories are lost and I have to export the required pins again. Another disadvantage is: export requires root priviledges and the created directory/files are assigned to root/root. So I have to chgrp and chmod too. Otherwise standard users have no access to GPIO pins.
    SO_yeah likes this.
  4. igorpec
    igorpec UDOOer
    Jan 25, 2015
    28
    13
    This is the usual / standard way of dealing with GPIOs as seen on other boards. Perhaps it's not ideal but it's standard.
    If you change this, people will need to adjust/port existing scripts. I can imagine the anger ;)
