Has anyone installed FreeBSD in UdooBOLT ?
Discussion in 'UDOO BOLT' started by stecolumna, Apr 25, 2020.
  1. stecolumna
    stecolumna UDOOer
    May 20, 2016
    152
    38
    Has anyone installed FreeBSD in UdooBOLT ? I only managed to install FreeBSD on UdooX86
    [italiano]
    Qualcuno ha installato FreeBSD in UdooBOLT ? Io sono riuscito ad installare FreeBSD solo in UdooX86
  2. jorgy
    jorgy UDOOer
    Sep 15, 2017
    I was thinking I would install FreeNAS (which is FreeBSD based). I will let you know if I get it working or not.
    stecolumna likes this.
  3. stecolumna
    stecolumna UDOOer
    May 20, 2016
    152
    38
    Dearest jorgy,
    thank you very much.
  4. jorgy
    jorgy UDOOer
    Sep 15, 2017
    I created a FreeBSD 12.1 bootable USB stick and booted from it successfully, and started a live CD on my UDOO Bolt. It ran just fine, so I have every reason to believe that installing it would be fine too.
  5. stecolumna
    stecolumna UDOOer
    May 20, 2016
    152
    38
    Dearest jorgy,
    I also created a usb stick with FreeBSD-12.1-RELEASE-amd64-memstick.img and also with FreeBSD-12.1-RELEASE-amd64-disc1.iso but unfortunately the boot stopped and the computer went into freeze.
    Thanks for yor reply
  6. jorgy
    jorgy UDOOer
    Sep 15, 2017
    Interesting, I was successful with FreeBSD-12.1-RELEASE-amd64-disc1.iso.
  7. ccs_hello
    528
    192
    Usually the culprit is the boot-time eMMC support (assuming OS is installed there as the system drive.)
    Find a patch would be the workaround, if that is the issue and if such patch exists.
  8. stecolumna
    stecolumna UDOOer
    May 20, 2016
    152
    38
    Dearest jorgy,
    Really I was unable to complete the boot even with the SATA disk. However, I will try again as soon as I have free time.
    Best regards
  9. stecolumna
    stecolumna UDOOer
    May 20, 2016
    152
    38
    Dearest ccs_hello,
    If you were able to install FreeBSD in the EMMC I would be happy because now I have installed Manjaro in the M2 Nvme, Debian in the M2 Transcend and Ubuntu in the SATA then only the EMMC remains free where I currently have a second Ubuntu installation.
    Thank you very much
  10. waltervl
  11. waltervl
    Stupid me, FreeBSD uses its own kernel so you will have to check if the AMD eMMC driver is implemented.
