HDMI 1280x800 on UDOO QUAD / Android
Discussion in 'UDOO QUAD' started by montella, Apr 15, 2016.
  1. montella
    montella New Member
    Sep 6, 2014
    15
    Dear All,
    I bought this LCD monitor able to display at 1280x800@60 (I tested it as external hdmi screen and it worked with 1280x800@60):
    http://www.amazon.com/Toguard-Monit...&redirect=true&ref_=oh_aui_detailpage_o02_s01
    Using U-BOOT I set the env in this way:
    setenv bootargs console=ttymxc1,115200 init=/init video=mxcfb0:dev=hdmi,1280x800@60,if=RGB24,bpp=32 video=mxcfb1:off video=mxcfb2:off fbmem=28M vmalloc=400M androidboot.console=ttymxc1 androidboot.hardware=freescale mem=1024M
    and then
    saveenv
    Nevertheless the Android boots at 640x480@60 regardless the setup.
    This is what happens at kernel boot:
    MIPI DSI driver module loaded
    mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver hdmi
    mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0xa:0xa0:0xc1
    imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
    mxc_sdc_fb mxc_sdc_fb.1: Can't get fb option for mxcfb1!
    mxc_sdc_fb mxc_sdc_fb.2: Can't get fb option for mxcfb2!
    Any suggestion?
    -- Raffaele
  2. ektor5
    Jul 1, 2013
    97
    48
    Hi there,
    Well, maybe it's missing an "M" specification?
    Try this:
    setenv bootargs console=ttymxc1,115200 init=/init video=mxcfb0:dev=hdmi,1280x800M@60,if=RGB24,bpp=32 video=mxcfb1:off video=mxcfb2:off fbmem=28M vmalloc=400M androidboot.console=ttymxc1 androidboot.hardware=freescale mem=1024M
    ek5
  3. montella
    montella New Member
    Sep 6, 2014
    15
    Thank you for the answer.
    Unfortunately doesn't work.
    These are the messages at boot:
    fbcvt: 1280x800@60: CVT Name - 1.024MA
    -- Raffaele
    edit: please use [ code ] tags for code snippets
  4. montella
    montella New Member
    Sep 6, 2014
    15
    Update:
    I tried with the M specification and even using 1280x720 with no results.
    Is it possible the resolution is not supported by Android 4.4.2 ?
    The monitor works perfectly with the UDOO Neo on both Linux and Android 5.
    Now I'll try the UDOO QUAD with the latest Linux.
    -- Raffaele
  5. montella
    montella New Member
    Sep 6, 2014
    15
    Update:
    Apparently it is a Android 4.4.2 limitation: using the latest ubuntu by udoo the monitor works perfectly with really remarkable results using the Udoo QUAD.
    I hope the next Android version for Udoo QUAD (when will be available) will fix the 1280x800 resolution.
    -- Raffaele
