Help Calibrating my 15.6 Touch Screen
Discussion in 'Troubleshooting' started by jerichodee, Jan 30, 2014.
  1. jerichodee
    jerichodee UDOOer
    Jan 5, 2014
    19
    I just recieved my 15.6 3M 78-0006-1625-6 Rev B touch Panel and after running the touch screen calibration in Ubuntu 12.04 SD Image my Y and X axis are reversed. I been digging on how to fix this in the 99-calibration.conf file and can't get it to properly work after saving the configuration after logging off or rebooting.
    I've followed the steps on connecting the LVDS screen and running the setenv command from delbas post and it still won't work properly. I'm getting display on the LCD just fine, it just every gesture is reversed.
    Someone please assist.
    Thanks,
    Jerichodee
  2. henriks
    henriks New Member
    Jan 29, 2014
    10
    i didn't get the touch screen to work properly until i attached a usb mouse, try that and then start calibration
  3. jerichodee
    jerichodee UDOOer
    Jan 5, 2014
    19
    I can now get it configured correctly but I'm having 1 problem. Upon rebooting it doesn't seem to keep the configuration. Is the proper path for 99-calibration.cong under /etc/X11/xorg.conf.d or should it be under /usr/share/X11/xorg.conf.d/ ? I've tried importing the settings in both files and rebooting and it won't stick. Is there any other calibration program I can use by a third party?
  4. thomasation
    thomasation New Member
    Jan 21, 2015
    Hello jerichodee,
    I am using the 3M 78-0006-1625-6 Rev B touch Panel on 19" monitor. I am facing the same problem and I am not able to calibrate. How did you solve the problem?
