How can I use tone() instruction on UDOO
Discussion in 'Arduino IDE' started by hushunghung, Dec 25, 2013.
  1. hushunghung
    hushunghung New Member
    Dec 2, 2013
    Dear All
    After receiving UDOO, I found it is Arduino Due Model.
    But I practicing the sounder experience, I need tone() instruction.
    But it seems can't work for this model.
    So How can I replace this instruction or have something new ideas?
    float sinVal;
    int toneVal;
    void setup() {
      // put your setup code here, to run once:
      pinMode(8,OUTPUT);
    void loop() {
      // put your main code here, to run repeatedly:
      for(int x=0;x<180;x++){
        sinVal = (sin(x*(3.1412/180)));
        toneVal = 2000+(int(sinVal*1000));
        tone(8,toneVal);
        delay(2);
  2. miousername
    miousername New Member
    Jun 23, 2013
    73
    Which is the problem?The application doesn't compile or when you launch the application you can't hear sound?
  3. hushunghung
    Dec 2, 2013
    My problem is
    1. use tone can't compile, how to solve arduino due rev can't use tone and notone,even though I've import its library. (# include <Tone.h>)
    2. I've check /opt/arduino-1.5.4/hardware/cores/arduino/ Tone.h and Arduino.h and I check its content with entry for "Tone.h". In network, I found the method, but its not work.(tone.h rename to arduino.h)
    3. How can I find a new instruction method for replacing tone and notone?
  4. francescomm
    francescomm Member
    Dec 14, 2013
    80
    3: if I remember well, this example plays tones without using tone();
    http://www.arduino.cc/en/Tutorial/PlayMelody
    It is just a matter of turning a pin current hi, waiting the correct time, then low, waiting the correct time, then hi, etc..
    You are manually generating the wave. Correct wait times for some notes are listed in the script (if I remember well).
    You can adjust volume (0-255) too by using analog output instead of digital hi vs low (if I remember well).
    [P.S:. of course on UDOO you can play (much better) audio on the Linux side easily, but you probably know]
  5. sgygax
    sgygax New Member
    Jul 22, 2016
    Dear all
    tone() is not supported. If I compile a Sketch with tone() I get error message:
    - error: 'tone' was not declared in the scope
    There is nothing written about it in chapter "Arduino differences".
    Is there a solution?
    Best regards!
  6. waltervl
    What Udoo are you on? This discussion started for a Udoo Dual/Quad.
    I think you have a Udoo Neo right? Then you have to use something like TimerFreeTone
    For more info alo look here https://bitbucket.org/teckel12/arduino-timer-free-tone/wiki/Home
