How do I set HDMI display scan range?
Discussion in 'UDOO X86' started by Earth Engine, May 1, 2017.
  1. Earth Engine
    Earth Engine New Member
    Apr 28, 2017
    In my TV, UDOO x86 display area is bigger than the screen, making some lines in the console invisible.
  2. FirstGenGeek
    FirstGenGeek Member
    May 25, 2016
    66
    26
    The first thing you should try, especially with Samsung TV's, is the Picture Option settings on the TV. There should be a setting for Picture Size which can be set to "auto" or "scan" to use the HDMI output values to determine the display resolution.
    If that doesn't work it would help others to know which OS you are running.
  3. Kilrah
    Kilrah Member
    Apr 20, 2017
    31
    16
    Yep it's a TV issue, not a PC issue. You need to switch it into "PC mode".
    Alexander Chang likes this.
  4. Earth Engine
    Apr 28, 2017
    Following John's advise I have it resolved.
    However, this is not the way I resolve it when using Raspberry Pi. Rpi have overscan settings when booting up. So I didn't need to worry about it.
