Using 'apt-get install vsftpd' did not work. Download vsftpd from https://security.appspot.com/vsftpd.html Untar file using 'tar xvzf vsftpd-3.0.2.tar.gz' Change directory to vsftpd-3.0.2 Edit builddef.h with your favorite editor, after editing file looked like this. Code: #ifndef VSF_BUILDDEFS_H #define VSF_BUILDDEFS_H #undef VSF_BUILD_TCPWRAPPERS #define VSF_BUILD_PAM #undef VSF_BUILD_SSL #endif /* VSF_BUILDDEFS_H */ Defining VSF_BUILD_SSL did not compile but I did not need it, so left it out. Edit Makefile and add line LIBS += -lcrypt Make it with 'make' Once built you need to follow the instructions in the INSTALL file starting with Step 2, 2a, 2b and 2c I installed the binary and man pages manually and did not use Step 3 Code: sudo cp vsftpd /usr/local/sbin/vsftpd sudo cp vsftpd.conf.5 /usr/local/man/man5 sudo cp vsftpd.8 /usr/local/man/man8 sudo cp vsftpd.conf /etc Edit /etc/vsftpd.conf and make the following changes. I did not want anonymous access. Code: #anonymous_enable=YES local_enable=YES write_enable=YES Can test it by starting it manually 'sudo /usr/local/sbin/vsftpd &' Will let you decide how you want start it automatically, the INSTALL will help with that.
