hello, I want to try the interface thermistor sensor at A0 pin on udoo neo board and try to get data from "/sys/bus/iio/devices/iio\:device0/in_voltage0_raw" location for this I change both uEnv.txt file line "m4_enabled=false" from sd card partition /data and /systems After changes, I fire "cat /sys/bus/iio/devices/iio:device0/in_voltage0_raw" command for read pin value but it gives wrong data linke :64,0,0,0,234,564,23,45 ..... random value so how to solve this things I follow https://www.udoo.org/docs-neo/Hardware_&_Accessories/ADC.html links for use adc pin but there is not any clear guide, I thinks there are some changes must be done in kernel side or in dts file but I don't know how I start work on adc pin or how to use adc, and how to disable m4 core please help me Thanks,
I see fom another topic that you run on Android. That will make things a little bit more difficult as there is no one known that does this kind of interfacing with Android.
Try it on udoobuntu first, and see what happens. Android has never been so developed on the Neo due to its complex architecture with a combined A9M4 CPU sharing it's GPIO
