How to use eGalax USB touchscreen and compile kernel
Discussion in 'Troubleshooting' started by mushketer888, Feb 11, 2015.
  1. mushketer888
    mushketer888 New Member
    Jan 13, 2015
    20
    Recently i had problems using eGalax usb touchscreen
    To be able to use it you must recompile kernel
    Heres also little tutorial how to compile kernel(can be useful, because i didnt find good information on this forum about this)
    you will need ethernet connection
    it is useful to have wicd-curses utility (install it with apt-get install wicd-curses)
    To make compiling easiet-compile inside Udoo
    CD to directory (you can choose other dir)
    # cd /usr/src
    # apt-get install git
    # apt-get install ncurses-dev aptitude
    # aptitude
    In aptitude remove packages: udoo-config u-boot-env
    and install uboot-mkimage
    (It conficts)
    Use keys:
    / and n for search
    + for install
    - for deinstall
    g for apply
    # git clone https://github.com/UDOOboard/Kernel_Unico.git
    # cd Kernel_Unico
    # make UDOO_defconfig
    # make menuconfig
    and there you must check options:
    Device Drivers -> Input Device Support -> Touchscreens -> check all eGalax with *
    (EETI maybe also)
    (PS you can enable other drivers, for example you can change UDOO usb ethernet to usb serial Drivers->usb support->usb gadget etc and check usb_serial rather than usb_ethernet)
    now exit and compile everything
    # make -j4 uImage
    when it is done it will output something like:
    # make -j4 modules
    # make modules_install
    # make firmware_install
    now backup your old kernel and copy new
    # cp /boot/uImage /boot/uImage.bak
    #cp arch/arm/boot/uImage /boot/
    if comething goes wrong you can boot old backuped kernel:
    when bootloader starts hit Enter
    check all by
    #printenv
    now
    #setenv uImage uImage.bak
    (as i remember)
    #boot
    ...Hope it will be useful
    Such approach can be done with other ARM boards like Beaglebone,Olinuxino,Rapberry etc...
    his likes this.
  2. his
    his New Member
    Sep 8, 2015
    24
    Firstly, thank you very much for your detailed description. I did recompilation of kernel in ubuntu thanks to your topic.
    How can we recompile the Android kernel sources(kernel_unico) from udoo?
    I mean not using computer. I would like to just copy kernel_unico to android filesystem, and using terminal emulator(a program can be used in Android) i would like to recompile the kernel just above your tutorial. Is it possible in android?
    If is, how can we do that?
    (Both adb or terminal emulator, i can use some commands in Android.)
    Any help greatly appreciated.
  3. Andrea Rovai
    @his
    It's impossible this way, you'll miss packages and stuff to accomplish what you aim.
