I bought the new Board but not boot
Discussion in 'Troubleshooting' started by blueslee, Jul 2, 2014.
  1. blueslee
    blueslee New Member
    Jul 2, 2014
    HI
    I bought the new Board(UDOO-Quad) but can't not boot
    I use 12v and 2A power
    and install ubuntu udoo os to SDcard
    My board green led is light but the board is not to work
    So What can I do to Troubleshooting?
    thanks
  2. peter247
    peter247 Member
    Mar 10, 2014
    263
    1 / Use a serial cable ( cn6 ) , which should give you a clue , what and a what stage you have the fault .
    2 / remake a new sd image and try a different method , eg use a different sd card and image.
    3 / Use win32diskimager it works for me.
    4 / Monitor the current the udoo is using
    With the serial terminal set up correctly ( cn6 ) , you should it least know it you are getting to the uboot stage , which you should see 4-3-2-1 now I`m going to boot , and now it should show you what the kernel is doing while it starting .
    If you don`t get any message on the serial terminal it could be it not read from your sd at all .
  3. fabio978
    fabio978 Member
    Jul 2, 2014
    51
    Had the same problem. My SD wasn't written correctly, so I agree with peter's suggestions
  4. shivas
    shivas New Member
    Nov 19, 2014
    i am also having same problem uboot stage itsef is not coming when i compile the uboot and ported on to the sdcard as given by the strat up pdf
  5. ekirei
    ekirei Administrator
    78
    peter247 and fabio978 got the point, try to check also the sha1 value of the .zip file you downloaded to verify if it's not corrupted. You can easily found the sha1 under the download link in the Downloads section.
    There have recently been cases of downloads corrupted.
  6. ekirei
    78
    the u-boot is compiled without any error? Did you launch the compiler menu with ./compile.sh -c to choose the right CPU target DUAL or QUAD?
