Installing Qt5.15
Discussion in 'UDOO BOLT' started by Nigel Brown, Apr 20, 2021.
  1. Nigel Brown
    Nigel Brown UDOOer
    Apr 14, 2021
    Could not find a lot of help with this and I am still working on the solution but here is what I have found so far:
    Note the ip address, we will require this later for SSH.
    sudo apt install net-tools
    ifconfig
    Enable SSH on the Udoo. After completing this stage you will be able to connect remotely using "ssh <user>@<ipaddress>" and also by using FileZilla.
    sudo apt install openssh-server
    sudo systemctl status ssh
    sudo ufw allow ssh
    Install Qt5 some prerequisites using the following from a ssh terminal.
    Install g++
    sudo apt install build-essential
    Install OpenGL libraries
    sudo apt install mesa-common-dev
    Use the qt-unified-linux-x64-4.1.0-online.run which can be download from https://www.qt.io/download-thank-you?os=linux
    copy the file to to /home/<user>
    chmod +x qt-unified-linux-x64-4.1.0-online.run
    sudo ./qt-unified-linux-x64-4.1.0-online.run
    Install some missing modules.
    Serial
    sudo apt install libqt5serialport5-dev
    sudo apt install libiw-dev
    Bluetooth
    sudo apt install qml-module-qtbluetooth
    sudo apt install qtconnectivity5-dev
    QML
    sudo apt install qtdeclarative5-dev
    QtQuickControls2
    sudo apt install qtquickcontrols2-5-dev
    Multimedia
    sudo apt install qtmultimedia5-dev
