Intel AC9260 WiFi/BT5.0 M2-2230 Card supported?
Discussion in 'UDOO BOLT' started by hhtmp88, Aug 4, 2018.
  1. hhtmp88
    hhtmp88 UDOOer
    May 24, 2016
    48
  2. hhtmp88
    hhtmp88 UDOOer
    May 24, 2016
    48
    Dear Udoo Development team,
    any updates?
    Thanks!
  3. linkhunter
    linkhunter New Member
    Jul 15, 2018
  4. hhtmp88
    hhtmp88 UDOOer
    May 24, 2016
    48
    Do you meam Intel AC9260 will not be supported by Udoo bolt?
  5. linkhunter
    Jul 15, 2018
    i don't really know depend on the board only thing that can happen when you're booting up the bolt you get boot message saying wi-fi card not supporting it btw did you buy it from kickstarter you can always ask there
  6. ccs_hello
    435
    163
    Pretty nasty related to that board interaction with Ryzen.
    See
    Don't know the actual issue, but
    somewhat related to device driver and possibly some hardware related issues.
    See this messy conversation
    https://communities.intel.com/thread/121592
  7. David Rad
    David Rad New Member
    Jan 10, 2019
    The manufacturers BLOCK hardware in specific brands.
    Not kidding here - you have to buy the correct wifi card to the correct laptop.
    Had huge issues with HP machines as an example.
  8. jfs10
    jfs10 UDOOer
    Apr 16, 2019
    22
    I purchased
    Intel Wireless-Ac 9260, 2230, 2X2 Ac+Bt, Gigabit, No Vpro
    from Amazon with some hesitation. The description gives me the idea that it will not work, but I read a post from another user who was using it. At the time it only cost $12, so I gave it a try. I am using Fedora 30. Both wifi and bluetooth recognized. Wifi sees our wireless networks and bluetooth sees devices. I have not actually tried connecting to anything yet, however.
    GerbenT likes this.
  9. GerbenT
    GerbenT UDOOer
    Apr 17, 2019
    24
    will be waiting patiently for an update :)
  10. Xanatos
    Xanatos UDOOer
    Jun 5, 2013
    I can confirm that the Intel AC 9260 works for the Udoo Bolt:
    [​IMG]
    hhtmp88 likes this.
  11. shokwaav
    shokwaav New Member
    Aug 1, 2019
    I can confirm it is working for mine as well.
  12. hhtmp88
    hhtmp88 UDOOer
    May 24, 2016
    48
  13. hhtmp88
    hhtmp88 UDOOer
    May 24, 2016
    48
    Hi!
    Are you actually installed AC9260 M2 module, and tested both WiFi and BT?
    or simply believe it works with Bolt?
  14. Xeyrruken
    Xeyrruken UDOOer
    Jun 6, 2019
    37
    Did you use any specific antenna? Do you have any warning at boot screen?
  15. Anthony Burow
    Anthony Burow New Member
    May 11, 2019
    I have yet to come back and test the VPro version I have - I removed it while trying to resolve other issues with the BIOS and Windows setup.
    What I can input to the discussion here is:
    - Bluetooth worked without issue
    - Couldn't detect any Access Points for WiFi on 2.4. or 5GHz band
    - Device appeared to be disabled as though "switched off"
    - I didn't have any antennas attached, but this should not matter and has not been an issue on other setups, beyond reduced RF performance. I will attach antennas in the final built.
    - The Intel drivers downloaded from their website adds a performance reporting component as a process. It shows a 5 - 10% performance hit on the CPU during performance testing.
    Xeyrruken likes this.
  16. WisdomWolf
    WisdomWolf UDOOer
    Aug 21, 2019
    12
    I can confirm that it works for me too on a V8 board. No warnings at boot and no need to install anything special. It was recognized when I booted up and I managed to connect to my WiFi in spite of the fact that I don't even have antenna connected to it yet.
  17. fxlevy
    fxlevy UDOOer
    May 23, 2019
    19
    Hello i have installed a 9260 and then installed a Ubuntu 18.04.3. The wifi card was recognized automatically during the installation process and without any antenna connected to the UDOO BOLT (but the motherboard is not inside a Bolt Case). I didn't test the BT. For french Udooers, the card can be found in amazon.fr
  18. ehf
    ehf UDOOer
    Oct 18, 2019
    It would be also nice to see if someone tested AX200, the more recent equivalent of AC9260.
    Theoretically, it should be no different from AC9260 on a recent Windows 10, but who knows?
  19. FastFreddi
    FastFreddi UDOOer
    Jun 20, 2017
    13
    I have the AX200 in mine, no issues, just works. (Windows 10)
  20. fxlevy
    fxlevy UDOOer
    May 23, 2019
    19
    I update my remark. I have now the Bolt installed in its Metal case with dual antennas connected to the AC 9260. My system is as standard Ubuntu 18.04.3 IMG_3459.JPG .
    The WiFi connection works perfectly. I reach the maximum speed delivered by my wifi router. But the BT doesn't work properly. I can connect in standard BT a Sony DualShock V2 with the standard drivers delviers by the Ubunut 18.04.3. But the pad doens't work anymore if the distance is longer than 50cm. I'm currently investigating the issue.
    watertank likes this.
