Issue installing Windows 10 Pro on eMMC
Discussion in 'Other OS' started by Jonathan MA Tech, Aug 6, 2018.
  1. Jonathan MA Tech
    Jonathan MA Tech New Member
    Aug 2, 2018
    I am trying to install Windows 10 Pro on an UDOO X86 Advanced Plus. I have created a bootable USB drive and started the installation process but when I get to the format screen I get a message saying "Windows can't be installed on this drive. (show details)." When I click that message a dialog window comes up and says "Windows cannot be installed to this disk. This computer's hardware may not support booting to this disk. Ensure that the disk's controller is enabled in the computer's BIOS menu." I have looked in the BIOS and searched the internet but have not been able to find the issue. Please let me know what I should try or if it is not possible to install Windows 10 Pro on the eMMC.
  2. Jonathan MA Tech
    Aug 2, 2018
  3. waltervl
    2,136
    539
  4. Jonathan MA Tech
    Aug 2, 2018
    Thank you waltervl! The error the original poster of that thread had is different than mine but posts #10, 11, and 12 of that thread helped.
    I had to go into the boot manager in the BIOS and select the EFI USB Device as opposed to the Legacy one. See picture.
      File size:
      224.6 KB
    Cakers and waltervl like this.
  5. uhtceare
    uhtceare New Member
    Apr 18, 2019
    I have burned a Windows 10 USB but the installation windows won't open. How to fix this?
  6. waltervl
    2,136
    539
    First gues is that you did not burn it correctly. Does the USB stick work on another PC?
  7. Sailler
    Sailler New Member
    Mar 27, 2019
    In general,once the boot disk is successfully created, the computer is booted by it,if not......i suggest you check the Windows 10 USB.
  8. uhtceare
    uhtceare New Member
    Apr 18, 2019
    I don't know what it means for burning correctly. I am using RMPrepUSB to burn ISO to USB.
    The ISO is downloaded from Microsoft website
  9. waltervl
    2,136
    539
    The process of downloading an ISO and burning it to a bootable USB is often going wrong. You can check if your USB is correctly burned by trying it on another PC to see if that one will boot from it. If that also fails you have to do the process (including new download!) all over again.
  10. uhtceare
    uhtceare New Member
    Apr 18, 2019
    tried on another pc. still not working
  11. waltervl
    2,136
    539
  12. Sailler
    Sailler New Member
    Mar 27, 2019
  13. Rohan Daga
    Rohan Daga New Member
    May 12, 2019
    Hi buddy, the best way will be to get a replacement via windows (similar version) as of now.
  14. Rohan Daga
    May 12, 2019
    Did you try any out as of now?
  15. foasolution
    foasolution New Member
    May 19, 2019
    Computer is not supporting booting format or image created does not have booting file.
  16. Kabir Singh
    Kabir Singh New Member
    Jun 9, 2019
