Issue with Serial0.write(0)
Discussion in 'UDOO NEO' started by knick, Nov 4, 2016.
  1. knick
    knick New Member
    Nov 1, 2016
    29
    I'm having issues with the Serial0.write() function when trying to write 0x00 to the serial port.
    Example - the following code produces NOTHING on the serial port.
    uint8_t val;
    while (1)
    val = 0;
    Serial0.write(val);
    val = 1;
    Serial0.write(val);
    val = 2;
    Serial0.write(val);
    But if you change val = 0 to val = 3 then it works as expected.
    I came across this issue while trying to use the ModbusMaster library. I'm missing bytes from the Modbus packets because any 0x00 bytes are getting dropped.
    Does anyone have a fix for this?
    iz0abd likes this.
    2,312
  3. knick
    knick New Member
    Nov 1, 2016
    29
    Thanks waltervl.
    Udoo team: Is there an estimated timeframe for when this will be fixed? I need a working serial port for the product I am working on. I have to decide whether I can wait for the fix, or try a different platform.
  4. knick
    knick New Member
    Nov 1, 2016
    29
    Is this something I can potentially fix myself?
    On my windows development machine I have a folder AppData\Local\Arduino15\packages\UDOO\hardware\solox\1.6.7\variants\udooneo. Inside this folder are a bunch of source files - some of which look like they are related to the UART. If I spend time digging through this am I likely to find the source code that is getting called when I invoke Serial0.write() ?
  5. waltervl
    2,312
    Yes you could try to fix it yourself in the sources in that folder. That would be highly appreciated!
    Be aware that there is also a MQX part in it that is proprietary software of NXP. So only compiled versions of that part.
    Andrea Rovai likes this.
  6. wertiti
    wertiti New Member
    Mar 28, 2017
    Knick,
    Did you succeed to fix it?
  7. iz0abd
    iz0abd New Member
    Jun 17, 2017
    This is exactly the same problem I have using Modbus RTU. Unfortunately I designed a board to host a Udoo NEO and now I discovered this incredible issue.
  8. preechaim
    preechaim New Member
    Oct 6, 2017
    I have the same problem.
    Any fix or update?
  9. waltervl
    2,312
    Not that I know of.
  10. preechaim
    Oct 6, 2017
    Got to workaround by putting Serial0.flush() after writing a byte.
    while (true){
    Serial0.write(0);
    Serial0.flush();
  11. waltervl
    2,312
    Nice work! At least a work around found. Do you have to flush after every write() ?
  12. preechaim
    Oct 6, 2017
    No, you will need to flush just when sending a zero.
    I think the problem can be from somewhere in the serial buffer which assume that data is always a string.
  13. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    158
    17
    It would be better if you cast to byte too.
    Serial0.write((byte)0x00)
    even if it doesn't solve the problem but flushing does.
