Java on UDOO
Discussion in 'Application & Utilities' started by xwalter, Oct 1, 2014.
  1. xwalter
    xwalter Member
    Sep 8, 2014
    89
    I have installed eclipse from the lubuntu software center , and I wrote a simple GUI application using awt package .
    It's working
    But now I would like to install rxtxcomm for java , famous library to handle the serial port .
    Reading the documentation about rxtxcomm , they say that I have to install rxtxcomm.jar and rxtxcomm.so into the java home directory
    At the moment I did these operation to know where is my java openjdk and to set up the JAVA_HOME path .
    By the terminal I tape
    which java -> answer /usr/bin/java
    export JAVA_HOME =/usr/bin/java
    export PATH=$JAVA_HOME/bin:$PATH
    these operations were done without any pronlems
    But before to install rxtxcomm.jar and rxtxcomm.so I want to know if my procedure is correct ...
    Somebody know if I'm doing right ?
    Thanks
    Walter
  2. indianerjones
    indianerjones New Member
    Mar 10, 2014
    18
    Does not seem wrong. However, there are two things to consider:
    1. Have you downloaded an actual ARM library? Or did you download an x86 one?
    2. A quick googling tells me there is a package in the Ubuntu software repo. Have you tried that?
    http://stackoverflow.com/questions/1138 ... 4-netbeans
  3. xwalter
    xwalter Member
    Sep 8, 2014
    89
    yes, I know what you mean .......
    I already had installed x86 and i32 version of rxtxcom but as I wrote in a post , they doesn't work because these library are done for iCore , ia32 and other architecture of processor different then ARM .....
    I have seen the stack overflow article and I'm trying to download the corret version of the library because the original web site is off.
    I think the correct library is used by the freedomotic ...I have downloaded freedomotic-bender-5.5.1
    The rxtxcom library I have downloaded is for ARM processor
    librxtxSerial.so -> 166 k
    RXTXcomm -> 59 k
    I hope to do right .... :?
  4. xwalter
    xwalter Member
    Sep 8, 2014
    89
    I solve some problems but now when I start my application I have this error message
    run:
    Stable Library
    Native lib Version = RXTX-2.2pre2
    Java lib Version = RXTX-2.1-7
    WARNING: RXTX Version mismatch
    Jar version = RXTX-2.1-7
    native lib Version = RXTX-2.2pre2
    gnu.io.NoSuchPortException
    at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:218)
    at netbeans1.TwoWaySerialComm.connect(TwoWaySerialComm.java:12)
    at netbeans1.Netbeans1.main(Netbeans1.java:14)
    BUILD SUCCESSFUL (total time: 1 second)
    Maybe now I have two RXTXcomm library .... :?
    This error because I have added the RXTXcomm.jar from a folder (/home/ubuntu)
    But How can I find the other RXTXcomm.jar , if it exist ?
    If I find the other jar file I can remove this from the project and to add the other one
    Well , I don't know .....
  5. xwalter
    xwalter Member
    Sep 8, 2014
    89
    for me is impossible to solve this problem , udoo use the serial port ttymxc3 with other application such as Arduino ide , but I don't know where to find this library .when I try to install RXTXcomm.jar and librxtx.so and I launch a simple application there are several problems and arduino doesn't work anymore .........
    Two weeks to understand this problem without success , and after I saw milion of web pages, Raspberry books also but there are some differences between the two systems , I don't know in the 2014 is difficult to use a serial port
    I don't want to use Android adk just for a serial port .I want to use ubuntu on my udoo but this is not easy
    Very bad situation
  6. xwalter
    xwalter Member
    Sep 8, 2014
    89
    using these commands by the terminal ....
    sudo find / -name RXTXcomm.jar
    I have discovered that Arduino IDE (which it works over java) uses already this library , as I thought ......
    Pratically the answer of terminal is
    /opt/arduino-1.5.4/lib/RXTXcomm.jar is the location where the library is registered .
    Now I want to reinstall Netbeans and I add the library from this directory ....
  7. iNura
    iNura New Member
    Feb 18, 2015
    10
    hello xwalter :),
    i'm having the same kind of problem, yet when I have written the same command of the terminal I found that there are many RXTXcomm.jar files in the system .. even when I added the file which you have specified I'm still getting the same error.
    could you please help? how did you fix it :) ?
  8. Andrea Rovai
  9. xwalter
    xwalter Member
    Sep 8, 2014
    89
    the rxtxcomm is already installed , you are right mr Andrea ....because Arduino IDE use that library .
    But the problem is how to use rxtxcomm in java code becaus ein eclipse for example I have added the external library but when i compile I get the same problem
    Also Eclipse is running slowly and the quad core cpu over the heat sink is hot ....
  10. Andrea Rovai
    Could it be that you're linking not the right library in Eclipse?
  11. xwalter
    xwalter Member
    Sep 8, 2014
    89
    the problem is where to copy the ".so" file ....I think ".so" is like ",dll" in windows , pratically is the compiled library which connect directly to the driver ....isn't?
  12. Andrea Rovai
    Yes, you're right, .so is the equivalent of dll in Windows
    Check: http://superuser.com/questions/71404/what-is-an-so-file
    Have you followed this tutorial? In particular, this part:
    If you are in a UDOO DUAL/QUAD distribution with the Arduino IDE preinstalled(UDOObuntu 1.0, Debian Wheezy 1.1) use the library contained in the /lib folder(this recompiled library handles properly the /dev/ttymxc3 internal serial of UDOO DUAL/QUAD):
    sudo cp /opt/arduino-1.5.4/lib/librxtxSerial-2.2pre1.so /usr/lib/jvm/java-7-openjdk-armhf/jre/lib/arm/
    sudo cp /opt/arduino-1.5.4/lib/RXTXcomm.jar /usr/share/java/
    cd /usr/lib/jvm/java-7-openjdk-armhf/jre/lib/arm/
    sudo ln -s librxtxSerial-2.2pre1.so librxtxSerial.so
    What error are you getting?
    What part don't you understand or it's explained badly?
  13. xwalter
    xwalter Member
    Sep 8, 2014
    89
    Dear Andrea .....
    sudo cp /opt/arduino-1.5.8/lib/librxtxSerial.so /usr/lib/jvm/java-7-openjdk-armhf/jre/lib/arm/
    ....better....
  14. xwalter
    xwalter Member
    Sep 8, 2014
    89
