Hello, I will buy a J-Link debugger for UDOO Neo. Could you recommend an adapter for it if you use it? Thanks, -D
You will need to wire up your own cable, they type of connector you require on the neo side is described in this post and pin out in this post. BTW the A9 needs to be running before the M4 can be debugged using JTAG.
