If anyone is still using Udoo for this purpose here is the image. With very limited support. Two known bugs: 1) it doesn't work with some TV's (no signal) 2) LVDS display doesn't always start(system is automaticaly restarted in this case after 30 seconds) LibreELEC-imx6.arm-7.0.0-udoo.img.gz https://drive.google.com/file/d/0B4FdVu0-fJt6YUtMcTBnQkFLVHc/view?usp=sharing (new version with fixed uEnv.txt - HDMI is set by default)
Tried installing an booting it today. No success no first try with HDMI -> VGA converter. The USB serial connection showed the video output was LVDS15, which I do have. Changed the video settings in /flash/uEnv.txt to a workable setting for my (non-hd) monitor (# HDMI video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32) rebooted and it worked Thank for your work Peter
Great a new "elec-build" BUT No signal for me on my Philips Television (HDMI - full hd - 1080p), not a singel signal... hdmi does work op openelec, the daily driver for me at the moment (Thanks VPETER). I've got no knowledge editing settings like the post from jdewilde, Anything i can do or any place to get started? I really like to get this running. Thanks!
Okay, i learned and tried some things; I'm on Windows 10 and accessed my uEnv.txt file with help from this sites: http://www.howtogeek.com/112888/3-ways-to-access-your-linux-partitions-from-windows/ Downloaded: https://sourceforge.net/projects/ext2fsd/?source=typ_redirect Edited the uEnv.txt file like under here, but no signal (i saw the fix from jdewilde was for his non-hd monitor but i give it shot. Any suggestions?
Nevermind, got it working! How i fixed it? Thinking that my Openelec installation is working fine i opened the uEnV.txt file from that installation, copied the part and it worked! 1920X1080P resolution and a updated Kodi, i'm happy The sound is going through USB for me that works fine. Under here my file, i hope it helps other users. # enable only one video line # HDMI video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 # 7" LVDS #video=mxcfb0:dev=ldb,800x480M@60,if=RGB666,bpp=32 # 15.6" LVDS #video=mxcfb0:dev=ldb,1366x768M@60,if=RGB24,bpp=32 # make boot more quiet #console_arg=quiet morequiet # or having quiet and serial console console_arg=console=ttymxc0,115200 quiet morequiet # show messages in serial console #console_arg=console=ttymxc0,115200 no_console_suspend=1 # enable ssh #ssh_arg=ssh # enable debugging (kodi debug) #debugging_arg=debugging zImage=/KERNEL bootfile=/KERNEL mmcargs=setenv bootargs "boot=/dev/mmcblk0p1 disk=/dev/mmcblk0p2 ${ssh_arg} ${console_arg} ${debugging_arg} video=${video} dmfc=3 consoleblank=0" p.s. I know it's 3 posts, but i think it was clearer to make a new post then to edit my post 3 times. THANKS FOR EVERYTHING VPETER, MY DAILY DRIVER IS UPDATED
Thank you, so what It means is that I have to ceate my own biuld, I alreadyhave the u-boot and kernel compiled 3.14.28 and 3.14.56 that both work with the IMX6 in my UDOO neo, but how can i extract the LibreElect root file system to be used in my biuld?
You need to build libreelec - you can't just combine different parts together At least different kernel must be used than what is included now.
Hi, i got it working on the quad as you can see, BUT on some video's playback is slow (looks like a driver issue...) Same video's working smooth on the openelec 6.0 build, any idea's?
Can you share a sample to test? Btw: I already have Krypon working and will share image when I find some free time.
Searched for a sample, seems to be the x264 h264 Codec (I can P.M. a uploaded example if really needed) Sound works good, but video playback superslowmotion. I already tried with all the video/audio settings. Remember at first i had no signal at all, "fixed it" myself (a few posts back). - https://www.google.nl/webhp?q=mkv+x264+slow - http://forum.kodi.tv/showthread.php?tid=167317 For now my Openelec runs smooth and I'll wait for a update from you VPETER Thanks!
