LibreELEC (Krypton) v8.0.1 MR
Discussion in 'XBMC' started by vpeter, Mar 25, 2017.
  1. vpeter
    vpeter Active Member
    Nov 29, 2014
    303
    62
    Did you change video output in uEnv.txt file?
  2. idorel77
    idorel77 Member
    Jul 25, 2014
    131
    No. i have this:
    mmcargs=setenv bootargs "boot=/dev/mmcblk0p1 disk=/dev/mmcblk0p2 ${ssh_arg} ${console_arg} ${debugging_arg} ${enable_giga_arg} video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 dmfc=3 consoleblank=0"
    this is hdmi, right?
    hdmi i need.
  3. vpeter
    Nov 29, 2014
    303
    62
  4. idorel77
    idorel77 Member
    Jul 25, 2014
    131
    Working , Thanks a lot.
    Do you know if support the resolution 1280x800 ? i changed on uEnv.txt to this res but on kodi is 1280x720.
  5. vpeter
    Nov 29, 2014
    303
    62
    I wouldn't know.
  6. Viper780
    Viper780 New Member
    May 5, 2014
    19
    Hi Vpeter
    Do you have a Image with the latest 4.1.15 Kernel from Freescale and a 8.0.2 LibreElec build for due Quad?
  7. vpeter
    Nov 29, 2014
    303
    62
    No, I don't use this kernel. Only 3.14 from solidrun and 4.4, 4.8 and 4.10 from xbian. But for udoo I'm using only 3.14 (didn't update device trees for other versions).
    And why would you need any different kernel anyway?
  8. Viper780
    Viper780 New Member
    May 5, 2014
    19
    Sorry for my late answer - lost a bit Track of Udoo.
    There a major Changes in the Version 4 Kernel. Like the self patching, better NFS support, Support for newer SMB, faster en- and decryption,...
    Also the latest Video Driver (and GPU SDK) needs this Kernel.
    I saw that your git repo is still active, did you tested the latest LibreElec 8.10 Beta with the new SMB implementation?
  9. vpeter
    Nov 29, 2014
    303
    62
    I'm sure there are lot of changes in kernel v4. And I already using 3 different versions of them. But not for Udoo because I had some issues (forgot what - I think it was something with LVDS display).
    No, I didn't use LibreElec 8.1.0. Will skip it because final version is on the way.
  10. localhost
    localhost New Member
    Aug 30, 2017
    Hello there!
    First: Thank you for your work!!!
    Second: Anyone experiencing a Boot-Slpash Stuck?
    My Quad boots for the first time and tells me something like "Resizing.... and so on... wait for reboot". After the auto reboot the Quad stucks at the Libreelec Splash Screen. I wasn't able to pull any Logs due the missing of a Linux PC for mounting the ext Partition.
    Any hint or a tip what to do?
    Cheers
  11. vpeter
    Nov 29, 2014
    303
    62
    Probably issue already noticed with 4.4 kernel where black screen happen. There is no solution.
  12. localhost
    Aug 30, 2017
    So I have to use an older Version or should I use my quad as a door stop?
  13. vpeter
    Nov 29, 2014
    303
    62
    What you will do it's up to you :confused:
  14. localhost
    Aug 30, 2017
    mkay, I will try some 7.x Versions. Maybe I'm lucky enough to get this bitch working.
    Thanks for answering!
  15. waltervl
    2,260
    564
    Did you use this image where you experienced those problems? LibreELEC (Krypton) v8.0.1 MR
  16. localhost
    Aug 30, 2017
    Yes Sir.
    Yesterday evening I tried version 7.0.0 (Jarvis) and it works like charme. But having Krypton as an option would still be great.
  17. Viper780
    Viper780 New Member
    May 5, 2014
    19
    @vpeter is there any update for the Udoo Quad and Kodi/LibreElec?
    For other imx6 devices there are newer roms availible
  18. vpeter
    Nov 29, 2014
    303
    62
  19. Viper780
    Viper780 New Member
    May 5, 2014
    19
    Many thanks I'll test it and come back to you.
    The 3.14 ist a rather old Kernel. Isn't there any update for the imx6 Plattform.
    I belive the Cubox i2/i4 and Hummingboard are using a newer Version
    From NXP there is a Kernel Version 4.9 out https://boundarydevices.com/imx-linux-kernel-4-9-for-nitrogen-platforms/
    Hopefully Udoo Maintainers will upgrade soon
  20. vpeter
    Nov 29, 2014
    303
    62
    Old but working :)
    Yes, cubox is using 4.4 version. Just few days one guy used even 4.9. But because of very low imx6 users I don't do much anymore in this area because it is waste of my free time for almost nothing in return. That's why I keep 3.14 kernel for udoo because it works. There will be no more any updates in Kodi Krypton for imx6. For Kodi Leia there will be mainline linux used (4.14 or whatever will be at the time of making image).
    Viper780 likes this.
