Hello, I am having a hard time finding a connector for the LVDS port on the NEO (CN3). It looks like a PHDR-30vs but alot smaller. I have contacted DigiKey to no avail. Any help is greatly appreciated!!
Did you look in the Neo bom ( bill of material) that you can download on the resources page what article the connector is?
Agree very difficult to get hold, here is the spec for the connector (1.0mm), you will find links to distributors. It may be easier to get hold of the 7" LVDS cable for the NEO and mate with the connector on the other side which is 24 pin (2x12 female 2.0mm) connector. The 24 pin easily mates with a standard 2.0mm dual header (like this). Shame they didn't use a standard 2.0mm connector for LVDS. In fact it would have been better if they had broken out the LCD pins so either a HDMI shield or an LCD panel could have been used. There's plenty of the cheap LCD panels unfortunately they can't be hooked up.
After digging into the schematic, I found the connector. It is a A1014H-2XNP15 (Male). I just need to find a distributor that doesn't want me to order 10000 pieces... Most likely i will order the LVDS cable for the NEO and hack it up.
Looks like MOLEX pico clasp is the same range of connectors so perhaps you have more luck with that. http://www.molex.com/molex/products...oducts&chanName=family&pageTitle=Introduction
