Hello guys, Just wondering if anyone faced this problem before. The CN6 usb micro connector used for the usb-to-serial convertor suddenly stopped working. This seems to be a hardware defect as the PC to which i connect does not even detect the serial port. I have tried with all binaries that are available on the UDOO site but it's the same behaviour with all of them. Everything else works fine except this. The J18 jumper is shorted as required to use the iMx serial instead of the Arduino. I have used CN6 only once... There is no indication in the kernel dmesg logs that the cp210x USB-UART bridge chip was detected...
